Pencil Crossbow
Introduction: Pencil Crossbow
This is my entry in the Instructables Launch It Contest.
It is a simple and powerful pencil shooter/crossbow
Step 1: Safety Gear
You WILL NEED safety equipment when building and using this device.
When building this device you WILL NEED safety goggles when using the saw and the Exacto knife
When firing this device you WILL NEED safety goggles.
Above all: use common sense.
Don't fire things at the cat.
Don't aim things at your self.
Don't give this to someone that you would not trust with a book of matches.
Step 2: Gather Materials
2 Pencils (1 sharpened, 1 unsharpened)
1 Rubber Band
Safety Gear
Exacto Knife
Small Saw
Step 3: Remove Erasers
Remove the erasers and the metal piece from the ends of both pencils using the pliers.
Just pry them off.
You can save them if you like but they are not needed in this project.
Step 4: Notch Ends of Pencils
Use the saw to cut a small notch in both ends of the unsharpened pencil and the unsharpened end of the sharpened pencil
Step 5: Carve the Arrow Rest
Use the Exacto knife to carve a dent/notch in the middle of the unsharpened pencil to act as the arrow rest.
Make sure that when carving the arrow rest the notched in the ends of the pencil are vertical so the elastic will fit properly.
Step 6: String the Bow
You can either String the rubber band once or twice around the unsharpened pencil.
String the rubber band through the notches in the pencil
Step 7: Firing!
To fire your crossbow pull back all of the elastics insert the sharpened pencil.
Make sure that the notch in the back of the pencil has the elastics in it
Pull back the pencil and release it.
The ealstic will not go back very far if it is doubled
  • Pro Tips Challenge
    Pro Tips Challenge
  • Science of Cooking
    Science of Cooking
  • Paper Contest 2018
    Paper Contest 2018
This is no crossbow but a catapult. The defenition of a (cross)bow is that the potential kenetic energy is stored in the elastic limbs of the bow, and not in the elastic string.
Secondly if it were a bow that stores elastic energy in it's limbs, this would be a bow and not a crossbow. Becouse the defenition of a crossbow is a bow mounted on a stave with a mechanical device to hold and release the string. while this device lacks such a stock and triggerdevice.
why does some !d!ot have to be a smart@ss
Super easy and fun.
thats bull in your video you probably just had the pencil there cause there were no waves from the pencil in that pool
Actually, you are wrong. The pencil did fly over the building, and it did, in fact, land in the pool. You could not see any waves because (a) they were very small and dissipated before the camera got to the pool; and (b) the camera filmed in very poor quality. To give an idea of how much power this device had, the pencil with the elastic snapped because of the force applied by the elastics. Cheers!
Ignorance, ignorance, ignorance... This is not a crossbow at all. In fact, this is a shortbow on its side. On a full scale size, a bow of any kind can perform better at certain shots, possible aim, and trajectory for beginners I'm not sure exactly how you would make a real crossbow with pencils but you would need more than one pencil. In fact, I'm sure, for a simple crossbow, you would need at least five pencils. One for the stock, one, possibly two, for the lathe, something for a the catch, one for a trigger, and another for a bolt. and thats a simple one... a full one would include a crannequin and stirrup
big 10-4 ya pile o monkey nuts
Yesterday I made a really good crossbow, it doesnt get very good distance, but thats just because i messed up the rubber band and it is kinda loose, but it has a trigger mechanism allowing for easy firing, and I put in a crosshair XD. Im going to post it on instructables soon, when i have the time. By the way, that little crossbow has some insane power for being so small.
i have a improvement that might be a little better and durable
mi pic is da crossbow
