Upcycled Parts Pencil Cup
Introduction: Upcycled Parts Pencil Cup
These ideas come only from people that like keeping the junk* from taking apart electronic devices...
How can you make a pencil cup from a drill motor? Keep reading to find out!
*Your mom's point of view
Step 1: What You'll Need:
What You'll Need:
A drill motor
A Hot Glue Gun (You can use other adhesives such as: Silicone RTV, Epoxy, Sugru, And More)
A Drill
About one meter (~1 yard) of rope, string, or wire
A flat and hard piece of any material you want (I used a ferrite, If you don't have one, It's your time to improvise!)
A Screw
A sharp metal object (A Phillips Screw-Driver can work)
The pens or pencils you want in the cup
Step 2: Where Do You Want to Put It?
Choose a place where it will be comfortable for you to reach when you need a pencil,
I chose to place it under my Magnetic Pegboard.
After choosing the place, I marked a hole in the wood with a small Phillips Screwdriver.
Step 3: Insert a Screw
Next, With my drill, I inserted the screw in the hole that I marked earlier
Step 4: Take Apart the Motor
The motor is made out of two main parts (the Shaft and the Frame), I separated them by sliding them apart.
Step 5: Hot Glue Time!
I hot-glued the ferrite to the bottom of the frame of the motor, This is to form a cup shape which won't let the pencils fall out through the bottom.
Step 6: Make a Loop
After that, I made a loop with magnet wire and hot glued it to the the motor's frame
Step 7: You're Done!
Place it on the screw. Don't forget to put your preferred pens or pencils inside! ;)
I might change the way that it hangs in the future, But for now, It's good enough...
Step 8: Thanks for Watching!
I hope you enjoyed my Instructable, If you wan't to see more projects like this, Don't forget to visit my Instructables page and subscribe for more future projects!
If you find a that I made a mistake please point it out so I can fix it!
I'd also really appreciate it if you vote for me in the contests I've entered :)
If you build a one that is similar to what I built, Please post a picture in the comments to show everyone!
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    • Science of Cooking
      Science of Cooking
    You seem to be very organized, focused, and thrifty, all are good character traits in life, keep up the good work.
    p.s. show this observation to mom!
