Introduction: Re_write the Organizer
Step 1: Watch These Instructions
Step 2: Get a Lot of Used Pencils
You will need a lot of pencil tips.
First cut them to the same size : approximatively 2,5 inches
Then, sharpen the tips just a little bit. Just to remove the corners. (this will help you fix them into the hole)
Step 3: Get a Cheap or Used Cutting Board
Step 4: Make Sure You Have Everything
Step 5: Print the Drilling Template
If you don't have an 11x17 (A2) printer, just print two 8.5x11 (A3)
Step 6: Stick the Sheet to the Cutting Board
Step 7: Drill Holes 0,25 Inch Deep
Step 8: Insert the Pencils in the Board
Step 9: DONE
4th Epilog Challenge
