Penny Battery
3,309
51
9
Posted in TechnologyElectronics
Introduction: Penny Battery
About: Hello, my name is Andrew, I have recently decided to start posting Instructables, I do projects all the time and I would love to get in on some of these contests. Programming, Circuitry, and Robotics are my...
Hello and welcome to my first instructable!!! I want to start posting all my projects on here so I figured I would post one of my favorites, the penny battery!!!
This is a great project to know for those into survival. What I have done to expand this project is hook my homemade penny battery to a joule thief(coming soon) and I can run my higher brightness LEDs off the power it generates.
I know this has been done before, I just wanted to post my version.
Now let's get on to the project!!
Step 1: Gather the Parts
Tools used :
-Hot glue gun
-Scissors
-100 grit sandpaper (I used my dremel set that had a sandpaper tip. )
Alternative option is to use aluminum foil instead of sanding down the pennies, I did that in some of the pictures, but I prefer the sanded option, cutting tin foil into little circles sucks.
Materials needed :
-Pennies newer than 1983( the newer years penny's consist of around 98% zinc. )
-Cardboard ( I cut mine off a box, but I have used tissue paper, and wet wipes with success also. )
-Some form of electrolyte, I used salt and water, but I still haven't found the perfect mixture yet. (Still in testing stage)
Step 2: Prepare the Case
I used an old Chapstick container I found in my room that I had cleaned. I drilled a hole straight down the middle, then I took some wire and coiled it inside the container and hot glued the holes closed.
I have found that this container fits 6 penny's at a time which is enough to get at least 3 volts. I'm still toying around with it though to squeeze out all the volts I can.
Step 3: Setup the Penny's
This is the stage where you grind one face off the penny to expose the silver looking zinc inside. The copper side is your negative and the zinc top is your positive. So you stack the penny's in order of:
(I like to put aluminum foil on the bottom to make testing the voltage easier, but that depends on preference.)
copper bottom -> zinc top -> cardboard -> repeat
That order equals out to one "cell", so you can stack up as many cells as needed. I have found I can get up to .7 volts each cell.
With how easily obtainable penny's are, I'm going to see how much voltage I can pull out of something like 50 penny's. =D
Step 4: Test Voltage.
This is the stage where I use alligator clips to hook my multimeter up to my homemade penny battery. I have been writing down all my readings and times, hopefully I can figure out the best mixture to pull the highest amounts of voltage I can from this project. I have found that these batteries can last weeks powering LEDs and low voltage circuits. I will update with all additional information I collect.
Thanks for checking out this project!! I will be working on posting more soon!!
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Microcontroller Contest
    9 Comments
    Hi, I tried making one of these from european 5 cts coins, aluminum foil and vinegar. My multimeter tells me that my voltage is at 2.3 V which should be enough to light up the led I'm aiming for, but its not working. Any clues to what might be wrong?
    if you put a stronger acid in the battery like hydrochloric acid would it give stronger voltage?
    Very helpful and clear instructable. Thank you.
    seen this before but never on instructables you got my votes and my follow
    Hey man, very cool. I'm looking forward to what else you come up with. I'll give your voltaic pile a try soon and let you know how it turns out. Same goes for your thief project once it's up. Welcome!
    I'm still testing with the time they last, but so far I have gotten a led to stay lit for about a week before dying out. But all I had to do was add more water/salt, or lemon juice, or vinegar, and it would light again.
    They seem to go from full voltage to dead pretty quick when they do die.
    If you liked this instructable please vote for me in the contest!!!
    for about how long does it take for the voltage to lower 50% from full?
    This is of great interest to me. I look forward to you completing this with the joule thief inclusion.
    Very educational! Thank you for the simple and illustrated instructions!
