Let me start by setting the scene: your jerk roommate is in his/her room asleep or otherwise not paying attention; their door is closed. You are about to exact revenge with ninja stealth.
Step 1: Lock Without a Key
Start by pushing in the door near the top. Slide several pennies into the crack between the door and the jamb molding about 18" above the handle. Repeat process below the handle. Keep adding pennies equally to the top and bottom until you can't squeeze another one in.
Step 2: Final Touches
When done properly, the doorknob will not budge.
NOTE: If the door is crap or the frame is loose-fitting, you may be S.O.L. This prank tends to fail in these cases and the prank-ee just opens the door and pennies rain down. It works awesome on heavy, dorm-style doors.
OTHER NOTE: Obviously don't walk off and leave the person stranded. For one, you don't get to hear the frustration or panic in their voice as they try to get out. Also, you don't want them to be stuck in there in case of emergency. Don't be "that guy" on the 10 o'clock news should all hell break loose.
Visit Our Store »
Go Pro Today »
L
