Remove these ads by
Signing UpStep 1Make the rim
So, I took a 4' diameter tabletop that was kicking around, and drilled a 1/2" hole near the side, and tied a bit of rope around it, as shown. Next, I laid my channel iron face down (the open side - the side you want facing outwards) down on the ground, put the table on top, looped the rope over the end of the iron (of which I had about 16'), and began to pull back as shown. This little piece of aluminum I'm using in the picture is obviously much easier to bend than the channel iron; be strong!
The steel will spring back a bit, so on a 4' table, I got about a 6' circle of steel. I stretched it down to be just under 5', cut and welded.
You can also see me at http://facebook.com/timothywooi for some Penny Farthing built
how it coming along?
I'm curious if you got two aluminum wheels and bent them into semi circle' and welded them together if that could work... I think I'm going to experiment
Using a Tube Bender in order to get a Tube circle of 50" 0 60".
The size of whell that you want.
Once bended, cut in half in order to get the "U" Shape, with a band saw.
Sweet great start, wondering if you've gotten anywhere since '07. And if anyone has an idea where to get the tire material. I've heard something about using some type of wheel chair tire material that comes in long lengths, but my google research has yet to come up with anything.
HUrry Up!!!.
Here are a lot of people interested in make one for oneself.(Included me).
I love this Kind of Bike, and I want it desesperately!!!!.
Thanks in Advance :D
