Pentax DSLR cable shutter release from hands-free cell phone kit
I'm trying to get into HDR photography, which usually requires some very long exposure shots. The best way to do this is with a tripod and a shutter release. I got the tripod off Craigslist, but the shuuter release was too expensive for me, so I set off to make my own. This is inspired by this tutorial for a Canon DSLR.
Step 1Materials & tools
Materials & tools
To keep this on the cheap, I kept it minimal. The most expensive item was the hands-free phone kit; on sale for $10. Check the comments. One was found at a dollar store. $1!
(1) Hands-free cell phone kit
IMPORTANT: The DSLRs take a 3/32" stereo plug. See the picture for details.
(2) Momentary buttons (two colors)
(1) Mini micro switch
(1) Enclosure, for me a wonderfully ironic 35mm film canister
extra wire
tape
Tools:
Drill & bits
Soldering iron and solder
Wire stripping tools
Mad Skillz (which you have, because you're cool enough to find this)
57 comments
1-40 of 57next »
Jul 29, 2008. 7:29 PMShadist says:
Here is mine. For reasons unknown I am being told to not take it to the airport.
May 5, 2011. 1:27 PMjdlee77 says:
haha looks like a "clacker"
Oct 27, 2008. 8:43 PMabadfart says:
lol just remember to take off your shoes
Jul 29, 2008. 7:42 PMShadist says:
And, since I forgot to say, this was really rather easy and I think you for posting it. . . worked out beautifully.
Mar 22, 2011. 12:10 AMbtmnet says:
Is it work with Canon D60?
Jan 30, 2010. 11:07 AMDrGabriel says:
 Thank You.  I couldn't use it because the Pentax k-x doesn't have a physical shutter release input.. but the instructable led me to search Ebay where I found a new infrared one for 4 dollars.
Jul 21, 2009. 6:19 AMbeshur says:
Great tutor! :))
Thank you so much!
I have had so much fun yesterday ))
Just have a look at it: http://www.flickr.com/photos/beshur/3742845860/
Jul 2, 2009. 9:54 AMoppizzippo says:
Excellent! Will be working on this over the July 4th weekend.
Feb 24, 2009. 12:30 PMMother Natures Son says:
Bloody brilliant. Those things are ridiculously overpriced...I can think of many uses for this--setting up auto-triggers and such.
Dec 24, 2008. 2:45 PMrhiro1926 says:
I just finished mine in time for a Christmas present for my girlfriend. I tried it out on her Pentax K10D, and it works as advertised. I wasn't willing to shell out $30+ for the commercial one. I had all the parts on hand in my junk box, and mounted these in an empty Oral-B "Satin Floss" dental floss container that I thought several months ago was too cute to throw away. The ergonomics of the dental floss case by itself felt a little uncomfortable, so I grafted on a smaller matching dental floss container that I got as a freebie from my dentist. The 3/32" cable assembly is from a broken set of headphones, and is a generous 4+ ft long. I decided to connect this to the case via a standard 1/8" stereo plug and jack. This allows the cable to be replaceable as well as allows the use of a standard stereo headphone extension cable. Plus I can use the cable assembly with a time lapse shuttle release gizmo (also on Instructables), which is probably my next project. Nice Instructable. Thanks!
Feb 15, 2008. 5:51 PMwingman358 says:
Unfortunately, my Pentax IST *dL does not support manual shutter release, even with a remote. It does, however, support autofocusing and timed shutter release with remote. I was hoping I would be able to gain the ability to leave the shutter open indefinitely with this remote, however, that is not the case. Oh well. Thanks for the cool instructable that saved me $30 and will improve my photography!
Nov 10, 2008. 7:49 AMLaminarin says:
I just made one for my *ist DL and it works fine on the bulb setting for me (open shutter indefinitely). I don't know if it eventually times out but it works just like the shutter button on mine. One button for half press, the other button for full press. Thanks for the instructable.
Jul 24, 2008. 11:04 PMScromple says:
Wow.... Wingman, I also run a Pentax *IST DL and have built several of these for myself and a few friends who also run Pentax *IST DL and Pentax K10D cameras. I can verify that this will work with the camera. The circuit works an absolute treat. I normally buy the parts from Jaycar here is AU and build them from scratch.. On the camera, opposite side to where you put the memory card, there is another door. Open the door and there inside are three sockets. The top one is for the external cable release. Also if you ever need a replacement IR remote you can get one of those programmable television ones and set it to a sharp television. (I think. Been a long time since I programmed mine) This will also control the camera through the IR port.
Jul 26, 2008. 9:35 AMwingman358 says:
The key tidbit that I needed to know was that the camera must be on "bulb" mode. Once I figured that out, my cable shutter release worked perfectly.
Jul 27, 2008. 8:12 PMScromple says:
Okedoke... Yep would definitely need bulb mode to use the toggle switch in the circuit properly.
Mar 19, 2008. 8:47 PMsilvernotes says:
haha, mine is not nearly as pretty or crafty as y'all's models. but this is the first time I've ever done anything like this. I can control the shutter, but whenever I flip the switch, the camera auto-focuses and takes whenever it's ready. IE the black switch has NO function whatsoever :-) Pero, Gracias para tu buena idea!!
Mar 18, 2008. 7:35 PMsilvernotes says:
H'okay, so: 1) The colors of the wires inside my 2.5mm cable are different from the listed ones. Green and Blue wires were connected to the speaker, and the large covered red one (with a copper and red wires inside) were connected to the microphone. ...After testing, the bulb switch worked by switching on and off (this was the green cable w/ the big red ones as ground). The Auto Focus was also connected to the green one and worked whenever the bulb switch was on. The blue cable does nothing. ????????? 2) I'm using 3 switches, instead of one switch and 2 buttons btw anyone know what went wrong?
Feb 18, 2008. 7:40 PMtobrew says:
It works great with my Pentax K100D. Thanks for the Instructable.
Jan 6, 2008. 12:07 PMGorillazMiko says:
Nice job, this is great. I love small stuff like this, great job. (added to favorites)
Nov 1, 2007. 10:02 AMeasyrider1 says:
made one for my canon rebel xti,it works great! i used some pvc pipe with a cap on each end and the switches on the side. took some haloween pictures with it. went to the cemetary the other night and set a flashlight up behind a headstone facing toward me with my scarey face on. i then had my wife switch on the camera (bulb exp. about f4 iso 100). after about 8-10 seconds i ducked down,turned off the light then ran out of the frame of the camera,went back around behind the camera and shined the flashlight briefly on the headstones to make them show up and look a little creepy. total exposure time about 2-2.25 minutes.also took ones of my wife too. these made real cool haloween pictures. and to think i was afraid of the dark when i was a kid. thanks for the instructable.a+++
Sep 20, 2007. 9:55 PMtheyangster says:
I have an rebel xti, which uses the same plug and wiring.
I modified mine a bit to make it "nicer", though at the same time, I've made it look more "deadly".
I used:
1 2.5mm/ 3/32in headphone jack from mobile phone headset
2 radioshack momentary switches $4
1 Radioshack blinky led module ~$4 (comes with intergrated OFF/On switch which we can use to our advantage ;) )
1 screw in terminal (or you can just solder them all together)
random wires
Tools:
Solder iron
solder
pliers
precision screwdrivers
boxcutter/ exacto knife
Basic instructions
take blinky led module, rip out all metal inside, though carefully remove the OFF/ON swtich (top is held by "melted" pegs, just chop off top of peg, keep that cover), you'll need it later
Also cut off center divider in box, you'll need some room...
You'll need to make some room for the momentary switches, so you'll need to cut into where the "metal terminals" used to be, to get a flush mount.
and follow the wiring diagram in this instructable
I wired mine as:
red is autofocus
black is shutter release + bulb (ON/OFF switch)
Bulb exposure is under the "M" mode and you'll need to scroll to "BULB"
if you flick switch to ON in any other mode, it'll just do burst until buffer fills
I swear, be careful when you use this in public, it looks like a um....yeah..remote detonator?
Here's the pics
Jun 1, 2007. 1:11 AMruzter says:
Thanks for the info! I build one for a friend but couldn't decide how long to make the cable so I wired it with 4 wire phone jacks and he can use whatever length he wants!
May 23, 2007. 9:20 PMamateur6 says:
This is the first instructable I've followed -- easy to understand and cheap! I didn't need a long cable, just wanted to keep from holding the button down on the IR remote for long exposures. I also wanted something other than the film canister (ironic though it is), so I hacked together two bic lighter bottoms as shown below. I couldn't be happier! Thanks for the confidence-builder.
May 11, 2007. 7:48 AMgpaterson says:
I finally got around to making one of these for myself as taking long exposures with my <a href="http://www.instructables.com/id/SG3LDKWWJMEUBHTMQP/">ir remote</a> was an exercise in finger cramp.
I cannibalised an old PC headset/microphone for a nice 2.5m length of cable, combined it with the requisite switches in a tiny plastic project box I had and bob's your uncle!
Thanks for the great instructable.
Mar 22, 2007. 1:49 PMjesusali says:
I've made two of these for my Canon Rebel XT. They work great. I go to the thrift store and get old "Airplane" style joysticks though. They usually have a "trigger finger" switch and a top thumb switch. You can play, using one or the other to be your FOCUS button and the SHUTTER RELEASE. You can also drill a hole to add a toggle, but this is only necessary is you want long Bulb exposures, (for twirly pictures of stars and stuff).
Mar 27, 2007. 8:21 PMnewuser says:
If you want to get rid of the "twirly" part of your star photos, have a look into "barn door tracker". If you can't find a link I have one saved somewhere.....
Tom
Mar 22, 2007. 3:24 PMoscarpt says:
Hi I have a Canon Rebel XT and would like to build one, do you have instructions to make one? thanks Oscar
Mar 23, 2007. 7:17 AMAnotherBrian says:
You can get the jack here (at Mouser) for $1.35. They are also known as 2.5mm plugs in case you want to go searching.
Mar 19, 2007. 5:20 PMquicumque says:
Good instructable. I was planning to make one of these a little while back for my Pentax. One note: if you use the cable release you are going to want to have a viewfinder cover. My K100D came with one, but pretty much anything black over the viewfinder will do the trick.
Mar 20, 2007. 8:56 AMnewuser says:
Not too stupid. The viwfinder lets light in from the back of the camera and can throw the automatic exposure off. Covering the eyepiece prevents this. A inch of black electrical tape or gaffers tape will prevent this. This applies to any make/model of camera.
Mar 23, 2007. 5:22 AMArtemisthephoenix says:
most SLR's come with a little black bit of plastic that slides into place
Mar 23, 2007. 12:51 AMhernanai says:
I like the fact that he has iTunes playing in the background while he's doing this... Note: the second picture (the one where he shows the hands free headset.)
Mar 22, 2007. 2:12 PMShadyman says:
You're going to smack me, but the dollar stores around here carry a $1 cellphone headset. Cheap, but it does the job. (with a 3/32" stereo plug)
Mar 22, 2007. 5:18 PMtheRIAA says:
this isnt possible with an A series canon is it...
1-40 of 57next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:eagleapex
I'm a digital artist from South Philadelphia. I love to make things and share. I hope you dig my stuff!
