Pepakura Tutorial, Create Awesome 3D Models With Paper
82,996
66
11
Posted in Technology3D-Printing
Introduction: Pepakura Tutorial, Create Awesome 3D Models With Paper
About: i m a web developer & a designer
Pepakura (papercraft) models are models constructed mainly from sheets of card stock. so here let me show you how to create it
Step 1: At First We Need a 3d Modelling Program Such As Maya, 3ds Max, Blender, Cinema4d, Etc
at first we need a 3d modelling program such as maya, 3ds max,
blender, cinema4d, etc (download it if you don’t have one). or you can also use the ready made 3d models if you have
Step 2: After If You’ve Finished Modelling Your 3D Model
After if you’ve finished modelling your 3D model, export it as .3ds or .obj file for best results
download a example model here-
http://www.aas9.in/pepakura/
Step 3: Now You Need a Program Called “Pepakura Designer”
Now you need a program called “Pepakura Designer”, download it from here- http://www.tamasoft.co.jp/pepakura-en/after downloading, install it, and then open it.
After opening pepakura designer, click on file>open and then locate
the 3d model that you’ve just designed(or downloaded a ready made model). and then open it in pepakura designer
Step 4: Now We Need to Flip the Faces
Now you will get an dialog box asking you whether to “flip” or “no
flip”. click on “flip”. and then click “flip” again and then click “ok”. After that, you’ll be asked to provide the size of the model that you want to create, provide the sizes as per your requirements or leave it as default and click “ok”(please note that, you’ve can also change the size later if you want)
Step 5: Now We Need to Unfold It
Now click “Unfold”, this will convert the 3d model into a printable 2d map
Step 6: Now We Need to Adjust Everything to Fit the Paore Size
as you’ve above that the 2d map doesn’t fits perfectly in the paper
size, so what do we do now?, solution is very simple, if you right click, you’ll get lots of tools such as rotate, select & move, join/disjoin, etc. to fix the problem select join/disjoin tool & then slice the large piece into many smaller pieces. then use other tools to reposition it so that it fits everything perfectly in the page
Step 7: Now We Need to Configure Printing Settings
now click on 2D menu & make sure that “Show Edge ID” is enabled.
then click on settings>printer and other settings & make sure that you’ve selected “Print lines clearly(Vector Print)” and the click “OK”
Step 8: Now Print It
Now it’s the time to print it, so now click on file>print and print
the sheets. for best results please use a “cardstock”, a cardstock is a very hard but thin paper, used for printing greeting cards & business cards, you can also use a photopaper.
Step 9: After You’ve Finished Printing, Cut Out the Sheets Like This
After you’ve finished printing, cut out the sheets like this
Step 10: Folding
Now there are two types of paper-folds that pepakura uses, that is-
valley fold and mountain fold, in your prints you must have noticed some lines that look like these., they indicate what type of fold you’ve to do.
Step 11: Now Join Them
in your prints, you must have also noticed some numbers like this, these
numbers indicated the joints. what you’ve to do is very simple, just find the matching pair of numbers and then join them together(stick them with a superglue)
Step 12: Now Assemble Them
Now assemble everything. you’ll get it something like this, all tough my
model doesn’t looks so good, cause i didn’t had a good superglue.
Step 13: Try Some More
these are just the basics, you can create almost anything with this
technique. and perhaps you can even create this futuristic city model. to make the paper ultra-hard you can use a fiberglass resin or a aqua resin(available in art & craft stores)
visit here for more- http://www.aas9.in
Facebook- https://www.facebook.com/aasblog
Twitter- http://www.twitter.com/pcx1256x
Youtube- http://youtube.com/aas9x
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    11 Comments
    nevermind. but it says that i need a registration code
    Thanks for your tutorial! It helped me with my blender files. I have now converted them into pepakura files : )
    I hope you're not the owner of www.aas9.in, were these images came from, because that site seems to be riddled with malware.
    i'm the administrator of aas9.in
    Then you have major problems, either with the site or your adverts - checking the link set off all my anti virus software, and it was still trying to download something when I closed the psge
    those are advertisements actually by some software companies so that you'll download their softwares, the site is not harmful at all, it's just an add
    You need to have a word with them, because I didn't click on any of them, and they still tried to download stuff to my tablet. That makes your page unusable.
    i'm not responsible for that kinda advertisements , if you faced any problems with those ads on the site you can contact this advertising companies- admedia(admedia.com) & madadsmedia(madadsmedia.com)
    they run the ads in my blog
    Meh, easier to just avoid the site. Sorry.
