so it can fit in any pocket boil water in less than two minutes keep you warm and it makes a great light backpacking stove.the pot fuel and windscreen can't fit in the pockets :( I did NOT come up with this i saw one at scouts and dicided to make an instructable!You can use Denatured alcohol HEET or nail polish remover for fuel.You can put this in your igloo, quinzee, lean-to for heat when not cooking.This stove uses 50% less fuel than others
the taller the can sides the longer the stove will stay burning. Cut two cans at the same hight.Sand the edges so you dont get cut if you want You can sand the paint of the side if you want a silver finish.Cut a strip of can from the middle of the can for a inner wall.cut a ridge out at each end on opposite sides then slid the ridges together to form the inner wall.
THANKYOU....
NICE PROJECT FOR SCIENCE FAIR.
BUT HOW TO USE IT?
You may not use kero.
the holes are to big, use a pushpin to make them, and use a nickle instaid of a quarter, it seals better.
dont use the inner wall it isnt doing anything for you execpt making it harder to prime.
leave the stove fiberglass free, the insulation dosnt do anything for your gain.
hope this helps
junits 15
