Percussion Ring Shaker
PlayMusic by
2,213
38
Posted
Introduction: Percussion Ring Shaker
Have you always wanted to add Percussion to your favorite Ukulele song,or just want to be part of a jamming session with friends.
If yes, 3D print the STL files attached as part of the ible and use some metallic beads or some broken parts from old broken Artificial/imitation jewelry.Or use pepper seeds, if pepper does not make you sneeze !
My motivation for this was to use it with my Ukulele which I have been learning for about a couple of weeks now, and I also printed couple for a friend who loves to play tap drums.
Step 1: 3D Print the Ring-Lid
Download the 3D printing software that you printer supports, in my case i am using the Printrbot Simple Metal which use Repetier-Host as a software to
  • Slice the STL files attached,which basically means cutting the part into various layers
  • And send commands to the 3D printer while printing
In my case I am using the following filaments
HATCHBOX 1.75mm Green and Orange PLA
Download the RingLid.stl file attached and slicing the STL should take about 12-14 seconds and printing the STL file should take about 45-50 mins, which depends on your printer settings.
Step 2: 3D Print the Base
For the base in my case I am using
HATCHBOX 1.75mm Transparent White PLA
Download the ShakerBase.stl file attached and slicing the STL should take about 38-40 seconds and printing the file should take about 35-40 mins, which depends on your printer settings.
Step 3: Adding Metallic Bead
Add the metallic beads to the base or use some chain links from some old broken artificial/imitation jewelry.
Now before you super glue the base and lid together , run a quick test by shaking the contents by attaching the lid as shown in the video above.
Also add and remove beads till you are satisfied with the sound.
Step 4: Use Super Glue to Attach the Lid to the Base
Super Glue the Lid and the Base as shown in the picture above.
Use sand paper if required to smooth out the rough edges.
Congratulation your done !! Enjoy your new DIY Percussion Ring Shaker and add percussion to your strumming ...
  • Minecraft Challenge 2018
  • Sew Warm Contest 2018
  • Gluten Free Challenge
That's a great idea, I love it! You should try a wood one.
