3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Perfect (med/rare) campfire roast
Step 1Season the beast
season the beast
Unroll some wax paper and plop the roast on to it. Don't be afraid to season it a lot. Some ideas might be to stuff some garlic inside some holes in the roast or just to rub some spice into it.
21 comments
Apr 28, 2012. 8:56 PMl8nite says:
that roast looks so............... good ! That really is a LOT of wax paper, is it for insulation purposes or for cooking? Have you considered or tried aluminum foil as the initial wrap
Apr 29, 2012. 3:09 PMl8nite says:
lol.. that's true
Apr 28, 2012. 2:34 PMpmiller20 says:
Now I have done steak, burgers, & brats when camping, but whodda thunk you could do a roast this way? I love a good roast anyway and the smoky flavor of an open fire can only make it better! I didn't read ALL the comments so I hope this is not a duplicate question, but what cut did you use? This looks like a sirloin tip. I am guessing that would be a great cut to use for this. Thanks for sharing. ... it is on the menu for our next trip!
Aug 4, 2011. 8:32 PMunaffiliatedperson says:
looks really good. ill do it in my alley way.
Aug 4, 2011. 12:45 PMfox212 says:
Awesome 'ible! I second the parchment idea though, just in case the wax does melt into the meat a little. Also, I add a layer or 2 of foil and use a few less layers of parchment. The foil retards heat better so there is less need for all that parchment 'insulation' to protect the meat. Your pic of the finished roast sliced open should be on the cover of a summer grilling magazine! Man that looks good...
Jul 26, 2011. 9:04 PMiminthebathroom says:
interesting, I'm sure a little wax would be no big deal, but... have you thought of using parchment paper instead? Heat resistant to 450 and if you buy institutional grade like I have used in bakeries, it is good till 600 degrees
Jul 27, 2011. 3:19 AMiminthebathroom says:
Cool, that's how we do a lot of camp cooking, wrap in parchment, then in foil. That way you get the benefits of foil type cooking with a no stick coating, you can cook scrambled eggs on a sheet of parchment. But keeping in mind, if aint broke... your idea seems to work just fine
Jul 26, 2011. 1:07 PMLorddrake says:
does all the wax evaporate off or does some of it soak into the meat?
Jul 26, 2011. 11:01 PMiolaniann says:
Thia sounds like an old camping trick we used when I was a kid. (i have more) In answer -or sort of one-to a question asked.
you could use a brown paper bag wrapped with the newsprint, or alumiumn foil, or just about anything and it won't burn. The reason? When red meats are wrapped tightly the natural dampness and juice from the meat will keep the interior of the wrapping from catiching fire.. When wrapped the blood seeps out , or if you are wrapping before you thaw,,That moisture will keep the inner wrapping from burring. I might suggest that if using waxed papper you might concider wrapping the roast with a "plastic wrap" first. This would take the problem of wax away. Be sure take the time to make sure your wrapping you usecan be used in the microwave and that should protect it from melting in the heat.
Jul 26, 2011. 9:12 AMTechDante says:
what was the weight of teh joint before cooking
Jul 26, 2011. 12:16 AMsunshiine says:
Nice ible! Thanks for sharing. Last year we made our entire thanksgiving dinner outside. It was amazing! Wished I made an ible while we did it. Maybe this year!
Jul 24, 2011. 10:49 PMeldad.korah says:
wow, this made me so hungry.
A wonderful instructable, :) the only thing I regret is not having one right now.
thanks, I will try on my next trip.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:combatbootboy
