Tools required:
Bench grinder
Hand drill (preferably cordless)
Belt sander (optional)
Remove these ads by
Signing Up
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
Noah
Have not switched on my TIG since 2005, hope it still works, as I may use it soon. Not sure of all current "good TIG welding practices", as I am out of it, & mostly retired. For stainless, I have allways preferred a long taper on the thoriated tungsten, & lots of sharp ones in stock, for good controll of the arc.
A few years ago, I found out that the thoriated tungstens are radioactive, and the grindings are carcinogenic. In NZ, at least, there is a limit of how many of these can be stored at 1 location.
Have not done much TIG welding of Ali, but was taught to use a zirconated tungsten, started on thick copper, forming a "ball" on the tip.
Have a bit of thin wall titanium tube in hand, 19 mm O/D, 0.019 " wall, and have welded some. Suppressors are not regulated, here in NZ, and I have been involved with the use, and manufacture for many years.
Cheers.
When you are done sharpening your cone should be three times longer than it is wide, and score marks in it should be radial, not spiraling.
Other than that you're doing a good job though :)
I've never seen anyone grind an electrode backwards.
I stated that a dedicated grinding wheel be used.
I'm pretty sure AWS spec is 2x diameter, at least that's what it was when I was trained by an AWS CWI (stands for American Welding Society Certified Welding Instructor).
The tooling marks are left lengthwise, spiraling isn't an issue unless you spin the drill too fast, so I'll give you that one ; )
-BM
There's always three ways to do everything, the right way, the wrong way, and the Navy way!
