Photographs included throughout this guide may not exactly depict what you will see in your vehicle, however, the same general instructions should apply to almost all vehicles. Refer to the owner's manual for your vehicle for additional information.
The checks outlined in this Instructable may be performed in any order. The recommended frequency for performing each of the checks is also provided.
These steps do not replace your vehicle manufacturer's recommended maintenance schedule. This guide should act as a supplement to the vehicle maintenance schedule outlined in the owner's manual for your vehicle. |
Additionally, some steps require that you open the hood of the vehicle. Details on performing this task are provided in step one; however, you may need to refer to your vehicle owner's manual for additional information specific to your vehicle.
Remove these ads by
Signing UpStep 1Opening the Hood
When working under the hood of a vehicle several precautions must be taken to avoid the risk of serious injury:
1. Release the Hood Latch Ensure the vehicle is off and the parking brake is set. Locate and pull on the hood release handle inside the vehicle. This is often located underneath the instrument panel or near the driver's seat inside the vehicle. The hood should pop up slightly. |
2. Release the Safety Catch and Open the Hood Lift up on the hood and carefully slide your hand underneath. You should feel the safety latch, typically located near the center of the vehicle. Lift up on the safety latch and the hood should be free to lift up. The owner's manual for your vehicle should identify the specific location of the latch. |
3. Prop the Hood Open with the Prop Rod Locate the prop rod and use it to secure the hood. An indicator will often be found on the bottom of the hood to indicate the correct location to place the prop rod. Additionally, some vehicles may be equipped with hydraulic hinges that do not require a prop rod to keep the hood open. |
Add Comment
