3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Perfume Filled Locket (with Customizable Perfume Recipe!)
Perfume is a thoughtful and classic gift. It's even more thoughtful when it's a custom fragrance blend poured into a locket necklace. It's also versatile - you can wear just the perfume, just the necklace, or both. There are so many pretty lockets available - this one is new and made from brass, but you could also use a vintage locket. I've experimented with a lot of recipes and developed this one that is smooth and creamy but stays solid at body temperatures. It also solves the "I love this locket but I just don't know what I would put in it" problem!
Step 1Supplies and Equipment
- a locket - new or vintage will work, and a larger locket will be easier to fill
- beeswax - pastilles or granulated is best, otherwise be ready to grate some off of a block
- petroleum jelly
- essential oils and/or cosmetic grade fragrance oil (be careful to read the label as candle fragrances can irritate your skin)
- an eye dropper for fragrance
- a few measuring spoons
- a toothpick or something similar for stirring
- a small metal container to melt things in
- a candle warmer or double boiler
- heat proof glove or tongs to handle the heated metal
- a small tin or other container (optional) for any extra perfume
If you're making this for yourself you can choose whatever you want for fragrance. I used Amyris (about 8 drops), which is related to pine but doesn't smell like a cleaning product. My locket does smell nicely like walking through a forest when I wear my it.
If you're making it for someone else and unsure about the what oils to use, a good place to start is with a classic floral like lilac, then adding a hint of a citrus or spicy note. You can also find a lot of pre-mixed oil blends if you don't feel like experimenting. If you come up with a blend you love WRITE IT DOWN - including the number of drops of each oil - so you can easily make it again in the future!
8 comments
Feb 22, 2012. 6:18 AMMsJaxFla says:
Oh I love this. I can not do it now, but I sure do want to in the near future! Thank you for the idea/instructions.
Feb 22, 2012. 8:17 PMsunshiine says:
Very clever, Thanks for sharing. Perfect gift idea!
Sunshiine
Feb 27, 2012. 6:17 AMsabu.dawdy says:
such a great idea.. however i have a question. cant we add few sprays of our own perfume? because essential oils are not present in my country.
Feb 21, 2012. 10:01 PMbajablue says:
What a wonderful perfume sachet instructable!
How did you fill the locket? With an eye dropper?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
203
Author:technoplastique(Technoplastique Blog!)
I'm making something new for every week of 2012. Check my blog to see what I'm working on!
