Perfume Filled Locket (with Customizable Perfume Recipe!) by technoplastique
Contest WinnerFeatured
Perfume is a thoughtful and classic gift. It's even more thoughtful when it's a custom fragrance blend poured into a locket necklace. It's also versatile - you can wear just the perfume, just the necklace, or both. There are so many pretty lockets available - this one is new and made from brass, but you could also use a vintage locket. I've experimented with a lot of recipes and developed this one that is smooth and creamy but stays solid at body temperatures. It also solves the "I love this locket but I just don't know what I would put in it" problem!
Step 1: Supplies and Equipment
- a locket - new or vintage will work, and a larger locket will be easier to fill
- beeswax - pastilles or granulated is best, otherwise be ready to grate some off of a block
- petroleum jelly
- essential oils and/or cosmetic grade fragrance oil (be careful to read the label as candle fragrances can irritate your skin)
- an eye dropper for fragrance
- a few measuring spoons
- a toothpick or something similar for stirring
- a small metal container to melt things in
- a candle warmer or double boiler
- heat proof glove or tongs to handle the heated metal
- a small tin or other container (optional) for any extra perfume
If you're making this for yourself you can choose whatever you want for fragrance. I used Amyris (about 8 drops), which is related to pine but doesn't smell like a cleaning product. My locket does smell nicely like walking through a forest when I wear my it.
If you're making it for someone else and unsure about the what oils to use, a good place to start is with a classic floral like lilac, then adding a hint of a citrus or spicy note. You can also find a lot of pre-mixed oil blends if you don't feel like experimenting. If you come up with a blend you love WRITE IT DOWN - including the number of drops of each oil - so you can easily make it again in the future!
Krismiha says: Jan 23, 2013. 6:16 AM
Great idea and well documented. Thank you. Guess you can also do similar with lip balm with or without and gentle essential oil like chamomile.
btenriqwez says: Jun 21, 2012. 4:10 AM
My problem is that i dont have that kind of necklace :(
Neon Panda says: Jun 10, 2012. 12:43 AM
This is a brilliant idea : )
MsJaxFla says: Feb 22, 2012. 6:18 AM
Oh I love this. I can not do it now, but I sure do want to in the near future! Thank you for the idea/instructions.
technoplastique (author) says: Feb 29, 2012. 8:23 AM
Thanks! I hope you get to try it soon!
sunshiine says: Feb 22, 2012. 8:17 PM
Very clever, Thanks for sharing. Perfect gift idea!
Sunshiine
Thank you!
sabu.dawdy says: Feb 27, 2012. 6:17 AM
such a great idea.. however i have a question. cant we add few sprays of our own perfume? because essential oils are not present in my country.
Thank you! Many perfumes contain alcohol, and I don't have any specific science to back me up but alcohol and melting wax sounds potentially dangerous. I would think that if you sprayed the perfume onto the wax and left it alone for a few minutes until the alcohol evaporated off (the perfume dried) that it would be safe.
You could also consider using flavorings or even make your own extract (Kiteman posted this instructable on the topic: http://www.instructables.com/id/Be-a-Romantic-Scientist%3A-Distill-your-own-perfume-/)
Let me know if it works out!
bajablue says: Feb 21, 2012. 10:01 PM
What a wonderful perfume sachet instructable!
How did you fill the locket? With an eye dropper?
technoplastique (author) says: Feb 21, 2012. 10:13 PM
Thanks! I really should have addressed that more clearly - I just picked up my little metal cup and poured from it!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
