Perler Bead Ring
977
Posted in CraftJewelry
Introduction: Perler Bead Ring
About: I like to make perler bead patterns, make smoothies at home, program stuff on Scratch.mit.edu, and I really like to watch some of my favorite TV shows like Stranger Things, and Project Mc2 Sorry if I'm not p...
Hey everyone! Today i'm going to show you how to make a perler bead ring!
Step 1: What You Need to Make the Ring.
An iron, a small circle perler bead board, E-6000 which is an over night glue, a gold pearl striped perler bead, a sky blue striped perler beads, parchment paper (which is not in the picture), and a blank ring! [Mom says: you can find ring blanks at most craft stores nowadays. We use a cheap iron from WalMart, no water inside. We use E-6000 because it is a strong glue- hot glue will pop off after a couple days. The glue pictured here is black, but we usually use clear glue And obviously, you can use whatever colors of Perler beads that you want.]
Step 2: Add the Beads.
add the sky blue stripe beads onto the circle board and make it look like a small circle, and then put one gold stripe bead in the middle. this makes it look like a flower! Make sure your flower is big enough to cover the flat part of the ring blank.
Step 3: Iron the Beads.
get parchment paper and iron your perler beads.[Mom says: our iron is set a little lower than medium. Press down while you iron, and iron in a circular motion. When the beads are melted to your satisfaction, flip over and iron the back side as well. Let cool.]
Step 4: Glue on the Ring.
Use your glue to glue the ring onto the flower. Let it dry overnight. P.S. this glue is stinky!
Step 5: Your New Ring!
put on your beautiful new flower ring!
    • Slow Cooker Challenge
    • Flowers Challenge
      Flowers Challenge
