loading
Digitally addressable RGB LED strips are becoming more available and less expensive through hobbyist electronics stores and direct from factories in China, so it's time to update your holiday house lighting!
This project uses an Arduino to control strips of digitally addressable LEDs, and the idea is to put them up once, and then use different programs for each holiday throughout the year.
In a previous project, I added permanent analog LEDs. Those are good, but the whole strip is always the same color. With digital LEDs, you can do a lot more animation effects since each individual LED can be controlled.
There are many Instructables on using these LEDs - the main effort in this one was finding a way to easily mount them on the outside of the house, while still being able to remove them for repair, painting etc.
The LEDs used were strands of WS2812b LEDs, which is a combination of a 5050 RGB LED + a WS2811 controller chip in a single surface mount package. These are very bright LEDs! You can buy them in 5 meter strips, and they can come with a silicone jacket for waterproofing.
Programming them is easy with a few free Arduino libraries. For this one, I used the "Neopixel" code from Adafruit. FastSPI is another popular library.
One big caveat - this was not an easy project! The Arduino coding part is relatively easy, but there is a lot of soldering of connectors and planning involved. Also, the LEDs are somewhat sensitive to power fluctuations, and seem a bit prone to failure. Even with the precautions mentioned here and elsewhere, I still ended up taking down portions of the strings several times and eventually replacing about 10 of the individual LEDs. Now that they are up and working (so far!), they are very cool - much more interesting than those boring static lights! :-)
Step 1: Parts
The main idea was to come up with a way to mount the LED Strips easily, be able to work on them as needed, and take them down for painting. So, I used some plastic molding as a backing to make the strips rigid, and cup hooks and screw eyes to mount them to the house. That way, each strip can be taken down as needed for any work.
Electronics and Wiring Parts
  • LEDs - WS2812 or better WS2812b strips (better reverse polarity protection and slightly brighter). Waterproof - this is usually a silicone jacket for these types. I recommend 30 LEDs per meter since more LEDs will require a lot more power! Also, more than 30 LEDs per meter ends up blending together from a distance. Adafruit has them (called Neopixels). You can also get them at Ali Express (the Ray Wu store is popular, but there are many stores selling them). They come with white or black flexible circuit boards. You can also search for WS2811 since the WS2812 LEDs use the WS2811 chip + a 5050 LED. The other way to go are strands of WS2801 LEDs would also be fine, and since each LED is typically separated by a couple inches of wire, they draw a lot less power and still look great. Get extra LEDs since you will be fixing some of them.
  • JST-M 4 conductor connectors - you will need one male and one female per strip, plus a few extras. You only need three conductors. When I built my project, I did not see any 3 pin JST-M connectors for sale, but I see them on AliExpress now, and they should also be good, without that extra wire. The LED strips have different connectors depending on where you buy them, but some of them come with three pin JST-M connectors already soldered on which you may be able to take advantage of if you use those. I live in a fairly dry location, so if you live where it rains a lot, you may want to use waterproof connectors. There are ones that are made for LEDs like these.
  • 2 conductor connectors - I used some JST-M 2 conductor connectors first, but then found these Deans type connectors and really prefer them since they are easy to solder, and have obvious polarity, where the JST-M connectors with black wires require you to remember how you used them. Don't forget the mating plugs. These are used for the power connectors. The Deans type connectors allow 18 gauge wire to be soldered directly to the connectors. There are also auto ones like these that might work.
  • An Arduino Mega to control the LEDs. Most of the LED libraries use an array to store the pixel values, so the Mega is required so it has enough RAM to hold the array for all these pixels. The array is 3 bytes (R, G, B each 1 byte) per pixel. There are ways to do this without the array, so a simple Arduino could be used.
  • Power supplies - 10 amps, 5 volts. You will need about one of these for every 150 LEDs. I used these, or you can use ones like this one. For long runs, though, there will be too much voltage drop on the lines, so I ended up using higher voltage power supplies, and DC to DC step down (buck) converters at the strips, which worked very well. You can also use 5v power supplies with lower wattages, and just use them to run fewer LEDs. The advantage of this approach is that they cost less, and you will need less "power injection" wiring (see next step). The disadvantage is that you will need to run those wires around more unless you have a lot of outlets available along the installation.
  • Wire - 18 gauge is recommended, especially for longer runs. 20 gauge can be used for connections from the strips to the 18 gauge wire since the heavier gauge is mostly to minimize voltage drop over longer distances.
  • resistor - one 300 to 500 ohm resistor.
  • fuses - adding inline fuses at the power supplies may help if you accidentally mis-wire anything.
Mechanical Parts
Step 2: Planning the Layout and Wiring
For my single story house, I decided to follow the roof line. So, it made sense to have a separate strip for each section of roof line, and on the longer runs, a couple of of the 8 foot strips end-to-end. Each strip can be taken down to make way for painting etc., or to work on the strip itself. This happens a lot since the LEDs do go bad from time to time (see the Troubleshooting section).
For the electrical wiring, the WS2812b LEDs have a +5V, Gnd, and a data line. Since the digital commands are passed down the data line from LED to LED and strip to strip, that wire needs to form one continuous circuit from the beginning to the end. You can still light up the LEDs in any order, but the single control line will connect them all.
Similarly, all the strips should have their ground wires connected to make sure the signal has the same ground reference across all the strips.
There is some great info on how to handle these LEDs at Adafruit and Pololu. In addition, the Do It Yourself Christmas site has a lot of very helpful info - especially on their wiki.
Power
Since each strip needed to wired and tested individually, I used the same input connector for each strip, wired in the same way, even if not all the input pins were needed in normal operation. That way, I can pull and test any strip with the same signal and power connector from the Arduino controller. As mentioned before, I had a few bad LEDs, so I used this system a lot - highly recommended!
The WS27812b LED strips have three wires, and come with a variety of connectors. I ended up discarding all of those and using JST-M 4 conductor connectors on each strip. The lead-in connector only uses three of the wires for testing, and the fourth was sometimes used to bring power from the end to the start of the segment (or a separate 2 pin connector was used). Standardizing on three pin connectors would be fine too, and if I did this project again, I would probably do that, especially if the connectors had color coded wires to make wiring easier. The output connectors were wired differently for each strip - to match the power requirements for the subsequent strip.
For example, if one strip is at the end of a set on one power supply, and the next strip starts a new power supply, the output of the first strip would not connect the +5 wire across. The second strip would have a separate connector for power to come in, and also the main input connector would have the power line connected for testing only.
At the very beginning, use a small resistor in series with the signal wire from the Arduino - 200-500 ohms.
Make sure to use capacitors at the power supplies!
Generally, the female connectors are used as the input side of the strips.
So, all the ground wires for everything are connected together, and the data line runs between all the LEDs in order. The +5 lines should only be shared between sets of LEDs using that power supply - it is best to not cross the +5 lines between the power supplies since they are not all exactly the same voltage and can oppose each other a bit.
Getting enough power to all the LEDs is the hardest part of this project. Since each 5050 LED module can use 60 ma of current, 150 LEDs will draw up to 9 amps. 150 LEDs are what you would get with a single 5 meter LED strip with 30 LEDs per meter.
I highly recommend the Do It Yourself Christmas web site RGB power discussion for it's excellent coverage of power issues with LED lights for houses. I found it after I did my initial work, and it would have saved me a lot of time debugging the system. One key piece of advice is that you should be adding power every 50 LEDs or so since the voltage drop on the strips themselves is significant. I had some runs of up to 76 LEDs, which seemed OK. It might be good to test this before wiring everything up - use bright white (all LEDs on full) to test - see the Troubleshooting section for more info.
For longer runs, power will need to be added at a few places, even if it's from the same power supply as "power injection". Power Injection simply means running multiple wires from your power supply to sections of the LEDs to have less voltage drop than running the power through the strip itself. So, for 150 LEDs in three sets of 50, you can use a single 10 amp 5v supply, but should run power lines to the start, two middle sections (every 50 LEDs) and the end of that string. So, that is 4 power lines - each optimally using 18-2 wire, so it's a lot of wire and connectors. I chose to run those lines along the LEDs, adding connectors at the beginning and end of each strip so I could take them down easier. That was a lot of soldering, but the Deans style connectors are pretty easy to solder (wish I had them at the start!). There are some YouTube videos with demos on how to solder them. You could also run the power wires separately in longer runs independent of the strips. The strips would still be removable and testable individually.
So, you will see a mix of JST-M 2 and Deans style connectors in the photos since I switched in mid-project. I found the Deans style connectors easier to work with - easier to solder, and the polarity was obvious.
For my house, I only had a few locations where there were power outlets available, so I had to carefully plan out where the wall adapters were located and which LEDs they would supply. For my wiring then, I had power going in a couple directions, and the attached diagram shows where I ended up at the planning stage.
Since I had to add power over some long distances, the other technique is to use higher voltage wall adapters and DC to DC converters to convert the higher voltage to 5 volts right at the strips. This seemed to work well, and power injection was still used from the converter to the surrounding LEDs. One trick with the DC to DC converters is keeping them waterproof while allowing them to dissipate heat. I will try a pill bottle and see how it goes.
One other idea is to run separate power adapters or DC to DC converters for each set of 50 or so LEDs. The cost of the converters and power supplies would be lower since they would not need to handle as much power, but the wiring would likely end up being as complex.
The attached plans show what I was thinking before I started wiring, and what I ended up with.
Step 3: Mounting the Strips and Waterproofing
The molding was attached to the eaves with screw eyes and cup hooks. That way, each segment can be taken down as needed for repair or to move for painting etc.
To mount the LED strips, I attached them to thin plastic molding to give them some rigidity. Each strip was cut to the proper length for the portion of the roof they were to go on. I kept them from touching each other since there will be connectors on each end.
The cup hooks go on the house at places that make sense - every few feet. I spray painted mine to match the house. I drilled pilot holes to make it easier to screw them in. Then you can hold the strip up and mark the locations in the bottom of the strip for the screw eyes. I drilled a small pilot hole at the marks (see pictures), and screwed the screw eyes in.
Now, you can cut the LED strips to match each plastic strip. The LED strips have certain locations with solder pads where they can be cut, so the plastic strips may be a bit long in some cases, which is not a big problem - barely noticeable that the LEDS have a small gap with so many lit up. I used zip ties every few inches (every three solder pads) to attach the LED strips to the plastic strips. You will need to solder connectors on the end, so don't put zip ties at the very end until you are done. Leaving a couple off for now will make the soldering easier, and you can add the end zip ties after the soldering is complete and the strip is tested.
Once all the connections were made and the LEDs tested, I used RTV silicone to seal up the ends of the strips.
I used water tight kitchen storage containers to hold the power adapters with holes drilled for the connectors to pass through. I sealed those holes with RTV silicone also.
Step 4: Troubleshooting
Fixing LEDs
I had a number of LEDs that did not work at all or had one color broken. I am not sure if it was inherent in the quality of the LEDs, or from bad voltages/signals in my system.
The first LED can burn out more often than others, especially if you are not using capacitors on the power supplies. If you have a bad LED, generally all LEDs after that one will not go on. To test this, power up just that strip, and use a breadboard jumper wire to connect the data out copper trace from the previous LED to the data input copper trace of the next LED. I pushed the jumper wire pins right through the silicone jacket to make these connections.
Sometimes, a lit LED does not pass the data, and needs to be replaced. Sometimes, the first dark LED is the one that needs to be replaced. By jumping the data line, you should be able to decide which case you have.
Once you have identified the LED to be replaced, cut the silicone jacket between the LEDs next to it - using the space between the LEDs will keep the LED clear when you glue the jacket back together. Cut out the LED at the cut marks - you will want the copper pads of the two surrounding LEDs on the strip to be cut so they are right at the edge so solder can bridge to them. Cut a new LED in the same way - with the copper right up to the edge. Then, solder a bridge for the three lines (+5, Gnd, and Data) to add the new LED to the string.
It is possible that UV light will affect the lifetime of the LEDs.
Power Issues
I had some power distribution issues. Although I spent time making sure I was not exceeding the 10 amps available with each adapter, there was more voltage drop in the wires than I expected.
One symptom for this issue is seeing some flashing lights in random colors in the string. A second, more subtle symptom of power issues is when you have the LEDs on at full white, and some of them seem more orange in color - typically near the end of a string.
One way to verify this as a power issue is to run the strips at low values or brightness for the LEDs, then try them at full brightness, including white. If the dimmer level works while the brighter flickers, then it's most likely a power issue. I also wrote a program to make the whole strip fade from zero to all colors full on in a slow loop to look for those effects.
If you have any of these issues, you will need to improve the power wires, or add more power supplies in the strings. If the power supply is relatively close (a few feet) to the set of LEDs, you can use power injection to help - see the planning step and links.
If the power supply needs to be farther away, you can use a higher voltage power supply and DC to DC converter to step the voltage down nearer to the LED strip.
I used a combination of these techniques to enable full white on my LED strips.
Step 5: Programming
To control the strips, I used an Arduino. In my case, I had 500+ LEDs, so I needed an Arduino Mega to have enough memory to hold the RGB array (3 bytes per LED for the R, G, and B color byte values).
For the LED control, I used the Adafruit Neopixel library, and added a few new animation routines. The code is attached. The signal wires for the LED strip was connected to pin 6, and the ground wire needs to be connected with the Arduino for the signal reference. In addition, I just used the 5 volts from the strip to power the Arduino, so the Arduino is powered from the 5v pin.
There are other libraries like FastSPI and one from Pololu. There is also an Arduino code sample that only needs an Uno since it does not use an array.
You could also use a controller like the T-1000s and LED Edit, though I had a lot of trouble getting that working with the Java version on my machine, so I would not recommend that unless you like to tinker.
Now that I have the LEDs up, the real art is in the programming and animations!
Step 6: More Ideas
Pulling out the Arduino, and downloading a new animation for each holiday can be a hassle, so you could add a panel of push buttons for each holiday. I have now posted another Instructable on how to make this project controllable from the web to make reprogramming easier.
<p>Great idea, and I know how much pain it is to get adequate power to the larger displays. The WS2812b is a great performer. lots of lumens, and it has reverse voltage protection. The biggest problem is that it runs on 5 VDC. Its forebearer , the WS2811 is a 12 VDC device, and if you are into big displays, a wiser choice, that is if you want to compromise on the lumens, and the fact that if you misconnect it, the strip(s), are toast. Before I forget, thanks to LaserDave on his suggestion of a a filter on the DC input of each strip, my pixel failure rate has dropped to 0 since I implemented that change. I also have a spike supression filter on the output of each supply to manage the turn on disturbances. I can't tell you the exact circuitry as I bought them from China and they are epoxy encapsulated, they were $1.50 each, but they have helped with the pixel failures as well. They appear to be a an inductive/capacitive/ resistor device. </p><p>I am using the strips year round for architectural lighting as well as displays for special occasions. Each mounting device is a 1 meter aluminum strip which can be screwed or glued in place, the led strip is laid in place, then a translucent cover snaps over the whole thing. The cover protects the strips from the degradation by filtering the suns UV light. The first part of my array went into service 5 years ago, and I have not suffered any LED failures. The covers have yellowed slightly, but there seems to be negligible reduction in light output. </p><p>The channels also make power distribution much simpler, I am using low voltage #16 fine stranded PVC control wire, which I lay in the channel behind the LED strip. I find that by doing this I can daisy chain 2- 5 Meter 30 LED/M strips and still have full white illumination. The mid point connection ties both strip + &amp; - connections together and to the 16 ga + &amp; - conductors. </p><p>The channels are not cheap. I found a 100 piece lot with covers in China for $1.39 ea. which is worth the money for the protection. Larger lots bring the prices down. I have seen them as low as 0.75 ea US for a lot of 300.</p><p>I believe they are available from Holiday Coro, but I am not sure of the price.</p><p>See the pics. </p>
Great info - thanks!
<p>Great idea and clever mounting methods!! I feel your pain with having to deal with power distribution, colour variations, and LED failure. I went through all all of that too, and pulled out all of my hair in the process.</p><p>One of the biggest problems people are facing with these strips is the obscenely high resistance of the cheap copper tracks on the lengths of circuit board. To keep costs minimal they use a very thin copper foil that is adequate for the requirements of the strip, but not for daisy-chaining them. This results in requiring the multiple power injection sites.</p><p>The way I have been able to solve both issues was to use 14 AWG building wire called NMD 14-2, which is a stiff, vinyl-jacketed wire, white in colour, that makes a rigid substrate for LED strips to be stuck onto. The wire has three conductors within the vinyl sheath (despite the 14-2 designation), a black, a white, and a bare wire. I used the bare as ground, white as +5v and the black as data.</p><p>The major benefit to this arrangement is that one large power supply can easily power the entire system's length due to the almost-zero voltage drop. If the LED load requires more power than one supply can provide, additional supplies can be merged into the wire run wherever most convenient. Such arrangement might be both supplies at one end, one at the start and at the middle or the end. Each LED strip's beginning is marked on the wire, and using a hobby knife I stripped 1/4&quot; from the wire's sheath and removed 1/8&quot; of insulation from the individual wires, to which I soldered the GND, +5v and DATA wires that go to the start of the LED strip, then covered it all in silicone sealant. (The DATA connection is only once at the very beginning, and only the GND and +5v from the next strip and beyond)</p><p>One thing that I did that seems to have been a great investment, in view of the system's zero-failure rate of the LEDs, was to install a 100uF electrolytic capacitor, a 10uF tantalum capacitor AND a 0.1uf mono capacitor (all in parallel) across the GND and +5v feeder points at the start of each strip.</p><p>I used acrylic tubing cut lengthwise down the center to give two lengths of &quot;C&quot; channel that fit over the wire and LED strips for weather and UV resistance, and used silicone on the back to seal it up. Installed in 4' and 6' rigid sections clipped into place, I used &quot;bullet connectors&quot; (Panduit) to connect the NMD wire conductors between sections.</p><p>Hope this helps anyone with power problems, I find it MUCH EASIER than having colour issues and multiple power sources to deal with.</p>
<p>This sounds fantastic.</p><p>I'm in the planning stages of RGB LED lights around my home's exterior as well.</p><p>Question: Would it be possible to run the entire length (20-25 meters of lights, maybe 10 meters of no lights) on a single length of NMD 14-2? Based on my estimates, isn't that like 50 amps at full white brightness? Wouldn't that be more than a single length of NMD 14-2 could handle?</p><p>I guess another way to ask this is how long was your installation?</p>
<p>Great ideas! I had not considered using the rigidity of house wiring itself as the structure. I did try 12 gauge landscape wire, which is thick, but too flexible. I now have a bunch of 18 gauge wire and Deans style connectors for power injection, and it seems to work well, but a simpler setup would be nice. </p>
<p>I got everything to get this running on my house this year. My only problem is when I ran this as a test with one strip only about 3/4 of the 5 meter led strip lights up. I was thinking it was a power issue, the power brick i have is 5V 8A, not the recommended 10A. My math tells me if each pixel only draws 20mA then for 150 pixels I only need 3 amps, but if they each pull the full 60mA then I need 9 amps, making me 1 amp short.</p><p>But I also notice in your code you have these lines: </p><p>//Adafruit_NeoPixel strip = Adafruit_NeoPixel(74+74 + 52+27+39+71 + 9+38+39+11 + 15+70+15+11+40, PIN, NEO_GRB + NEO_KHZ800);</p><p>Adafruit_NeoPixel strip = Adafruit_NeoPixel(100, PIN, NEO_GRB + NEO_KHZ800);</p><div>Is the 100 indicated in the second line telling it how many NeoPixels there are, or am I reading this wrong?</div>
<p>Yes, exactly. If they completely stop, then it's probably either the code, or a bad LED. Those numbers being added up in my code are the number of LEDs in each segment. So, at about 3/4 of the 5m strip and 30 LEDs/m, that is around 112 LEDs. If you have a full 5m at 30LEDs/m, then that number should be 150. FWIW, that also initializes an array for the RGB values of that size, so it adds up! (3 bytes per pixel)</p><p>Power shortages would result in dimmer colors near the end, or maybe some flickering in extreme cases. Most sites I have read recommend power injection every 50 LEDs. That can be from the same transformer, but with hefty wires connecting it at a couple more points in the wire. You can see how it looks and decide if you can re-wire later. If you are planning, my experience is to definitely do it.</p><p>Your math on the power is correct - if they are not all on full white, you will probably be OK.</p><p>Good luck!</p>
<p>Thanks for the write-up. I had attempted something similar last year, but was turned off due to the size of wire needed to run 5v over my house and ended up going with mono 12v LED lights instead. the in-line converters are a great idea; I am working on a re-design using some of your techniques. :)</p>
<p>These are awsome.But to complicated for lil ol me.</p>
<p>B&ecirc;n m&igrave;nh cũng đang kinh doanh đ&egrave;n led http://kingled.vn/ nhưng thực sự xem những video tr&ecirc;n của bạn thấy thực sự chuy&ecirc;n nghiệp v&agrave; rực rỡ. Rất đ&aacute;ng học hỏi ạ!</p>
<p>SELLERS:</p><p>You might prefer a US based seller (may only cost 50&cent; more), so that you get the product in a week instead of a month, and fast returns if there are problems. Be sure to take a good look at seller ratings before buying, and post negative seller feedback if you are treated badly... Some of the cheapest sellers have only 50-60% positive rating, while it is normal to see 90% positive.<br><br>1-MODE VS. 3-MODE:<br>The cheapest sellers are typically offering the 1-mode light, so expect to pay a bit more for a 3-mode. You should also realize that 3-mode isn't always a good thing... Several reviewers have complained that they don't like the extra complexity and confusing (memory) behavior, so consider your needs carefully. As bright as this is, I insist on 3-mode so I can dim the light (about 40 lumens), and get several times longer battery life. The combination of high/low and flood/spot very effectively covers the full range of flashlight usage scenarios. I do wish LOW was the first mode in the cycle... you can't un-blind yourself after the fact. And I'd like an even-lower brightness mode, ~5 lumens.<br><br>BATTERY/RUN-TIME:<br>It is a waste to buy 14500 Li-Ion batteries... Most of them cost ~$4/each, and have just 10% more power (Volt*Amp/Hours) than a $2/each LSD NiMH rechargeable, which withstands much more use and abuse (and Li-Ions are notorious for vastly exaggerated specs). Contrary to some other reviews here, I've seen absolutely NO difference in light output whether my lights are driven by 1.5V or 3.6V, so the regulator is doing a superb job. Although a hot-off-the-charger Li-Ion battery, briefly at ~4.2 volts might over-drive the LED for a small increase. If weight was critical, I would prefer disposable Lithium AAs to Li-Ions. Also, a single AA is much cheaper, smaller, and more convenient than 3xAAAs, yet both provide nearly the same amount of power. In a pinch, this flashlight even runs reliably on a single AAA battery without modification. So this unit is superior to most other (18650) small flashlights.<br><br>On a single, I get 1.5 hours of run-time on HIGH before the light dims. I expect &quot;strobe&quot; mode to get double that. LOW mode lasts about 4.5 hours before the voltage presumably drops too low and the regulator suddenly shuts-off the light entirely. I measured a current of approx 1.7A@1.3V on HIGH, and 0.5A@1.3V on LOW. With a 13&cent; &quot;Super Heavy Duty&quot; AA battery, I got about half the run-time, which is decent and useful in emergencies (but starts to dim sooner than NiMH). With a battery extension tube converting this to 2xAAs, on HIGH I get 4 hours of run-time, a 33% improvement.<br><br>CLONES:<br>Most 3-mode sellers are offering cheap clones of the 150 lumen Ultrafire SK68, which is itself a very similar clone of the 120 lumen Sipik SK68which a few people have also received. You may be interested to know that the Sipik was itself originally a MUCH cheaper clone (using a different battery) of the old 220 lumen Nitecore Extreme<br>The wide array of blank/unbranded SK68 clones sold here can be different than their Ultrafire cousins... A few have a different thread diameter and the button protruding from the tail-cap so they *can't tail-stand*. Meanwhile it seems most lack proper voltage regulation (&quot;buck&quot;), so they're 2.5X as bright with a Li-Ion battery, or 2X as bright with 2xAAs using an extension tube, and may burn out the LED quickly on the higher voltage. The design and build quality of the clones is never quite as good as the Ultrafires, but they're decent lights, and typically still well-worth the price. I'd stick with Ultrafire branded lights for any critically important usage, like camping/hiking, myself.<br>SUMMARY:<br>This is nearly the PERFECT small flashlight. I always carry one in my back pocket, next to my wallet... I rarely notice it and I've always got a great flashlight with me when I need it. With an extension tube, it can fill the role of a MEDIUM sized flashlight as well. With the belt-clip turned backwards, it can clip on a hat for a hands-free headlamp. The high/low modes and flood/spot zoom lens means you get the exact lighting you want for nearly any purpose. And it makes a great lantern/whole-room light if you unscrew and remove the lens entirely (equivalent to a 15W bulb). Ultrafire rates this &quot;SK68&quot; light as 150 lumens, not 300lm as listed here, and it's pretty evenly matched with my 190 lumen DorcyCyberLight. I just wish I could find a large 2xD flashlight with all these same features, other than the discontinued Small Sun ZY-A601.<br><br>WISHLIST:<br>- The belt clip should be turned the other way around (or just drill a second set of screw holes near the head, so customers can choose). That would allow clipping to a hat or similar for hands-free headlamp use (without needing an extension tube). It would allow quick mounting under a car hood as a work-light, and more.<br>- An even lower ~5 lumen brightness mode would be great for preserving night-vision, up-close work, or indoor use, and would allow a single AA to run your light non-stop for 48 hours. I've resorted to also carrying around those $2 1xAA &quot;3W Police&quot; LED lights as well.<br>- Lowest mode first when turning-on the flashlight would be best, then cycle through higher modes as needed. Alternatively, a memory or a switch to set (and keep) the preferred initial mode might make everyone happy.<br>- An inexpensive pack of colored lenses seems like a common request. I believe most people want, in order of decreasing priority: Red, Amber, Green, Blue.<br>- Sold together with an extension tube would be a great option, like the Ultrafire C3 usually is. There's a big market for 2xAA mini-maglites, so I'm not the only one who would like the option of that larger form-factor. You CAN find extension tubes for (most of) these lights here on Amazon thanks to their compatibility with &quot;3W Police&quot; lights:<br><br>* http://denledchieusang.com/Tuyp-led-(Tube-led)/137/group</p><p>* <a href="http://denledchieusang.com/Tu-van/Cau-tao-va-cach-su-dung-bong-den-tuyp-LED-T8-1963.html" rel="nofollow">http://denledchieusang.com/Tu-van/Cau-tao-va-cach-su-dung-bong-den-tuyp-LED-T8-1963.html</a></p><p>* http://denledchieusang.com/Tuyp-led-(Tube-led)/Loi-ich-cua-den-tuyp-LED-so-voi-den-ong-huynh-quang-1947.html</p><p><br>If you have any information to add, particularly if you believe my list is inaccurate, feel free to leave a comment below. I can update it with new information as it becomes available.</p>
<p>Chung cư 87 Lĩnh Nam: http://chungcugiarehn.com/</p>
<p>Show floor property Phat Dat we have more than 100 condominium apartments at Lingnan 87, sent by the host's price range from: 16-20tr / m2 (The type area of 85m, 88m, 92m, 131m .81m, 87m, 105m2) Contact me to get the cheapest: Hotline: 0983,338,268</p><p><a href="http://chungcugiarehn.com" rel="nofollow">http://chungcugiarehn.com</a></p>
<p>Hello, i use led strips like this (direct from china, much cheaper then from lady ada)</p><p>And i come up with a different fastning sollution.</p><p>I use Plastic U beams. (the ones used to make the cabinet doors sliding easyer)</p><p>they are 12mm inside wide end 10mm deep, the strips glide wright in and stay there.</p><p>U can glue the strips down before putting the led's in or use a very smal screw.</p><p>I have also made an frame for my Arduino Ambilight from the strips.</p><p>If u like i can post a picture.</p>
<p>Sounds like a good system. Do you have a link for a sample plastic u beam? A picture would be great! Thanks!</p>
This is a picture of it.<br>if the strip goes in to deep for some viewing purpose, then put somthing underneeth it.<br>i used 1 time 2 ethernet cables next to eachother and then the strip rises to the front, and the viewing angle is wider then.<br>on the far part of thd ztrip you can see the strip at the bottom of the rail/Beam.<br><br>Richard
<p>Looks good - thanks. Hiding the power wires there is a good approach. There are aluminum channels with plastic tops made for LEDs sort of like this, but they cost as much as the LEDs!</p><p><a href="http://www.aliexpress.com/wholesale?catId=0&initiative_id=AS_20141211145211&SearchText=led+aluminum+profile" rel="nofollow">http://www.aliexpress.com/wholesale?catId=0&amp;initia...</a></p>
Here is the image, i didnt know how to atach it lol<br>
<p>Very nicely done! I just ordered all (I think. Hope.) the components for implementing this project on my house. In the planning, I've incorporated some of the ideas expressed in the comments section and I hope that it turns out well. Focusing on your last paragraph; any progress on the web control aspect??</p>
Thanks - there were some great suggestions in the comments, so I would love to hear what route you go, and how it works out.<br><br>I am already running the web server based version, and hope to publish that one in a week or two. If you want to start sooner, just send me a PM.
<p>Lights are up and running. I ended buying most of my components from HolidayCoro. Very nice people. I ended up using some aspects from @LaserDave's post; specifically using 1/2&quot; PVC and, primarily, 14-2 wire, threading it through the PVC. Sorry for the poor quality of the pic, my camera doesn't do low light very well.</p>
<p>Looks great! Yes - very hard to get good pictures. :-)</p>
<p>OK - ask and ye shall receive! :-)</p><p><a href="https://www.instructables.com/id/Web-Controlled-Holiday-House-Lighting/" rel="nofollow">https://www.instructables.com/id/Web-Controlled-Hol...</a></p>
<p>Great instructable. I used your mounting setup with some strips &amp; it works great.</p><p>The difference I incorporated was the removal of the zip ties. I used the clear tape from Gorilla Glue. It's strong &amp; has UV resistance. </p><p>How did you overcome the natural gap the occurs between the difference sections?</p>
Thanks - the tape sounds like a good idea. I did not do a careful job wiring between segments, but they do not stand out as much as I would think. None of mine were that far apart, except one where I used black wires (and some heat shrink tubing as a jacket) and ran them along the siding.
<p>Excellent! I'll be checking into this shortly!</p>
<p>Love it. These individually addressable RGB LEDs are so much fun to play with. Nice job!</p>
This is very cool, wonderful work. I covered my gutters with &quot;waterproof&quot; analog RGB last year at Christmas, I thought I'd get a year or two out of them. Unfortunately the rain and sun have done some pretty extensive damage to them, including several spots where the &quot;waterproofing&quot; failed and the strips melted parts of my gutters during rain. It seems now after less than a year that the Individual LED's are losing color as well, looking washed out. I even went over the strips with clear caulking to try and keep them sealed from the elements. Please keep us posted if you experience anything like this? Your setup looks amazing, I'm truly jealous!
<p>Thanks. I have some of those epoxy waterproofed analog 5050 LEDs up for a couple years and they do seem to be failing a lot. I am not sure why. Sites like <a href="http://doityourselfchristmas.com/" rel="nofollow">http://doityourselfchristmas.com/ </a> may have some good info on long term wear and techniques to protect them. The previous comment here mentioned using clear tubes.</p><p>I have had these digital ones up for a year, and replaced about 5 of the LEDs recently, though I am not sure why they failed. I have the power working better now, so that may help. The Silicone jacket is fairly easy to work with - cutting a ring, soldering in a new LED, and using Silicone RTV to re-seal it.</p><p>On AliExpress, I saw some channels for the LEDs with snap on covers - those may help. This is definitely a hobbyist project with the current state of the materials!</p>
<p>On my setup the 5050 LED strips are mounted on right angle material. Installation; since I have vinyl siding, including vinyl covering of fascia boards under the gutters and soffit. There is a lapping where the soffit and fascia covering meet, this is where the right angle base is inserted. The LED strips are on the vertical surface that hangs down. The LED strips are attached facing the walls of my house. By doing so this protects the strips from the direct UV rays of the sun also keeps them out of the rain. If you use strips facing outward you should try using strips with the black backing they should hold up better to the UV, as to the rain you will need to apply a very thin bead of silicon sealant to the upper edge of the strips to keep rain from migrating down the back side of the strips causing tape adhesive failure. Hope this helps. </p>
<p>Good idea, replflecting the light off your house and hiding the LEDs entirely.</p>
<p>Great project man! Definetely gotta do myself one for this Christmas! =D</p>
<p>I love this idea and will try to convince my wife to let me do it. Is it possible to use an Arduino with built in Wi-Fi to send coding for different holidays or just outdoor lighting?</p>
<p>You can definitely add Wifi - I actually have that now, and am making it look nicer and documenting it to send out after the Halloween rush. I am using a CC3000 board. It's similar to my other Instructable on the LED Tower.</p>
pretty cool setup. I saw a similar mounting technique on a Xmas lighting forum and they used clear polycarbonate versions of what you have. this has 2 advantages in that you can put the strip IN the channel eliminating the zip ties and the added bonus of UV protection. I am doing my first ever Xmas lights this year with the help of arduino too and I will be using that technique. some of my strips will be vertical so I have to determine the best way to mount them in the channel still. I have a mixture of dumb and smart strips but and some other toys and it will be computer controlled. Control is VERY easy to add to your setup for only a few dollars worth of Ethernet module and free software. good work!
<p>Sounds like a good way to mount them - especially if there is a lot of rain in your area. I am planning on posting some basic web control for this in a month or so - probably using old school web server tech and Arduinos, but MQTT is interesting. It would be nice to have that as a free web service to avoid dealing with any server setup at all. Thanks!</p>
<p>Have a look in to the free software called Vixen http://www.vixenlights.com. You can use your existing arduino setup, you can control the lights with the software very easily and have some way cool effects. Not only that, you can sync to music!</p>
<p>This is fantastic. Customizable by season and holiday, not a bad look by light of day, and there are plenty of opportunities for future upgrades. You win the totally imaginary "Anti-Griswold Holiday Decorations Award"! </p>
<p>Thanks - I do not have enough LEDs to give Clark any competition, but now that I have the tech figured out, things can only go downhill from here :-)</p>
<p>Hey CarlS - Excellent Instructable. I have a similar setup where at the fascia board which is plastic snap-in covered I use a right angle piece of channel slipped in then face the LEDs toward the walls the whole house lights up for the holidays. Two other applications the first I have the LEDs set to white when I arrive home before I hit the drive way I turn on lights with wireless remote also have it wired to motion sensors anyone walking around house lights up the house. The second application I have is an input port to accept closed contact signal from my home alarm system. All LEDs flash alternating RED/WHITE for Burglary alarm and BLUE/WHITE for Fire Alarm. Definitely attention getter for the first responders when needed fortunately I have not had to use these two functions. </p>
<p>Very cool - you should do some Instructables on those! :-)</p>
<p>Nicely done! This is a great idea.</p>
<p>Thanks!</p>
<p>Great good and very well done ,</p><p>I like Your Idea for mounting the Leds very clever and very handy ,</p><p>I'v done this on only part of a house and loved it ,</p><p> but after seeing this creation I'm going to do the rest :-) </p>
<p>Thanks - I am very happy with the ability to take sections down and fix/test them.</p>
About This Instructable
78,529views
536favorites
License:
Bio: A Maker since childhood with all the classic symptoms, a robot builder, and an Internet software CTO by day.
More by CarlS:LED Holiday Tree with Shared Internet Control LED Bar Light Tardis Door
Add instructable to:
