Remove these ads by
Signing UpStep 1Why does this music stand fail?
More specifically...
The bolt that connects the base of the music stand to the shaft, has too much lubricant on the threading. Although it initially allows for easy assembly, it also allows the bolt to back out of the shaft.
[see picture #1]
The pivot section of the music stand (in back of the music stand's face) relies on inferior washers, which slowly deform from regular use. The deformity of these washers causes a lack of tension, which then causes the face of the music stand to sag (this is why your music keeps falling down). Also, the inside of the nut may not have a nylon component, which allows the nut to back out at times.
[see pictures #2 and 3]
The connection between the shaft and pivot will sometimes slip out. Overtightening can deform the apparatus, so I will suggest using epoxy and a nylon nut instead.
[see picture #4]
Students are to blame for most of the wear and tear. They stand on top of the music stand base, wiggle it around, constantly adjust the face, etc. Students will have a difficult time destroying your music stands after this instructable.
Bravo on specific replacement for the hardware to improve performance.
We had one that the base would hold the entire thing at a 45* angle and still no one would fix it.
Any idea how to adjust the inner spring? We also have a stand that every time you push it down, it will slowly slide itself right back up.
