Perpetual Motion Machine
Introduction: Perpetual Motion Machine
See step 1 for intro
Step 1: What Is a Perpetual Motion Machine
Perpetual motion is motion that continues indefinitely without any external source of energy,theoretically!
A perpetual motion machine is a hypothetical machine that can do work indefinitely without an energy source
For more information check this link:
If we had one,we could have infinite energy without spending fossil fuel , nuclear or using wind, or solar power
It would be free energy....
Step 2: Does It Work?!
Well,unfortunately no :(
It violates first & second law of thermodynamic
But it never stopped people thinking how to build one, and not just thinking but they even tried to make it
If you do a google search for perpetual motion you'll seen thousand of ideas
Step 3: Here Is My Design
Step 4: How Does It Work?
I thought this idea
I thought that gravity and air pressure( caused by gravity too) can do this job
Air pressure and gravity are to forces that operate continuously but we are adept to them so we don't fell them
The pool is filled with water and it's linked with a pipe that goes up to vacuum chamber
So the air wants to fill every place and it makes pressure to the water pushing it up ( valve 2 is one way valve it allows water to go up but not down) and this water fill oval container ,when it reaches a certain lever Valve 1 closes the vacuum, and then technically the gravity will pull down the water thought valve 3,which lets water to go down but doesn't let air to fill the vacuum chamber
Thus the water goes again in the pool and valve 1 opens again, so it suck water again in oval container and falls down again and this cycle continuous,hopefully!?
Step 5: Where Is the Problem
The problem can be that water doesn't go down because there is no air to let water down, it's vacuum
So i thought to make larger tube as it seems in the design photo maybe the gravity will pull down it and defeat vacuum
I hope this projects was educating and I hope it will spark any idea into your brain
I didn't have money to put my project from design to reality but im wondering what you think about this project
I know what thermodynamics laws say
Am 18 year old now
And sorry for my English !
    • Epilog Challenge 9
      Epilog Challenge 9
    • Paper Contest 2018
      Paper Contest 2018
    • Science of Cooking
      Science of Cooking
    Perpetual motion/super-unity is an interesting concept. Perpetual motion is theoretically possible if you remove all friction (which is impossible, unfortunately) but super-unity (energy from nothing) isn't. Your machine would stop because: fluid friction at the valves and in the pipes will use your energy, mechanical friction opening and closing the valves, the valve seals wouldn't be perfect, and worst of all : the water would boil and destroy the vacuum! The lower the pressure, the lower the boiling point of everything. An absolute, theoretical, vacuum gasifies metal and will also draw air through the metal (nothing is impermeable). (I didn't know that until my dad told me about how tricky some of the things he'd worked on were, such as this test that involved a near-perfect vacuum)
    if super unity as you explained it is imposible then so was the BIG-Bang as it currently is theorized....imposible to get something from nothing....;) i have my own theorys that excludes time itself from being born of the Big-Bang as the event needs a moment in time to occur first. that means time exited first before the event, meaning it wasnt the begining.
    hahaha you are so ... good one ;)
    Maybe only to work, would be to use 2 water tanks and switching valves on one vacuum tank- one then the other.
    the vacuum would neither pull water nor push water so this is an invalid theory like all "perpetual motion devices"
    A Vacuum can indirectly cause force to something, and there is capacity to do some work, certainly not perpetually, because as work is done, the stored pontential energy is exasted and cant supply the force anymore.
    It's not that vacuum would pull or push water,but air pressure 101325 Pa would do that
    It would push water up to fill the vacuum
    this is not perpetual motion as they is an outside force gernarating the vacume
    The vacuum is generated only once,and is kept in system
    yes and no matter how big the outlet the vacume will keep the valve sealed and not allow the water out
