Perpetual peppers, how to grow chilipeppers
It all started when I received a present of dried peppers from South Africa.
These peppers are really great, both is size and flavour so I decided to grow them myself and make pictures for this instructable in the process :).
Its my first instructable, it took a year to grow...
Step 1Collecting seeds
Collecting seeds
To get the seeds just open up the dried peppers
46 comments
1-40 of 46next »
Nov 25, 2011. 5:45 AMtim_n says:
Peppers do actually form a bush and will happily grow onto their 2nd year, but the results aren't as prolific. No reason not too... I've done it a few times :)
Mar 6, 2011. 9:40 AMTheBlackSharpie says:
I followed this instructable last year and ended up with like 10 peppers from 2 plants. This year I want to try it again but i have a little problem. Aside from cayannes I also grew hungarian wax peppers. I dont know if they cross pollinated. If i took a seed from one of my largest dried peppers will it grow or will it be unstable and cause problems?
Nov 25, 2011. 5:44 AMtim_n says:
we get a mix of peppers with our saved seeds - who cares they all taste good and it's chili roulette :)
Oct 26, 2009. 12:37 AMsecretsoto says:
thank you for taking the time to share.  i have  a question can i get seeds from any vegetable i buy from the market and grow it
Nov 25, 2011. 5:41 AMtim_n says:
Yes. http://www.realseeds.co.uk/seedsavinginfo.html
and more importantly: http://www.realseeds.co.uk/whyseedsave.html
May 16, 2011. 8:16 AMsleeepy2 says:
I have successfully grown grape tomatoes from seeds taken from tomatoes at a salad bar.
Actually, almost every seed I have tried sprouting from a grocery store has worked, the only exception being dried hot peppers in a bag of parrot treat.
Nov 25, 2011. 5:42 AMtim_n says:
There are some promiscous veg such as squash which more often than not do not breed true - but this often doesn't matter because you'll be creating your own varieties.
Jan 9, 2010. 3:57 PMroadieflip says:
I have tried growing from seed from store bought produce, but have had trouble getting them to grow.
My friends mum said that because store bought produce is "forced", they tend not to give good seeds...
I don't know if there is any truth in that, or I just have the knack of killing everything I try to grow. Maybe one of our green fingered friends could comment.
Jan 14, 2010. 11:16 AMJonny Katana says:
 In addition to the produce being "forced", I've heard that some growers genetically modify their plants so that the fruits contain seeds that will not germinate, effectively sterilizing the plant. After all, they can't have us laypeople doing something as self-sufficient as growing our own produce, that would drive them out of business!
Jun 21, 2011. 6:25 AMshvanbommel says:
You have to be careful when you are trying to germinate seeds from produce you buy in a store. Unless it's specifically "heirloom" and "organic" (which has a very loose interpretation) it won't germinate easily and if it does, and it produces flowers, there is a good possibility that the other plants it polinates with will not produce either because they will mix it's sterile genetics within it's systems... Does that make sense?
Jun 4, 2010. 5:31 PMSilence says:
Hybrids apparently have difficulty germinating to start with. The prob with most produce is that its picked early and ripened on the road. This in my opinion is probably the biggest factor in low germination rates.
Oct 26, 2009. 9:46 PMsecretsoto says:
thank u
Jun 5, 2010. 9:03 AMsherlocksbumstead says:
any good ideas on how to keep ants from eating my peppers' leaves? they're bhut jolokias (ghost chiles) and i REALLY want some fruit this summer.
Nov 25, 2011. 5:40 AMtim_n says:
Are you growing in pots or in the ground? I would recommend pots if you have ant issues
Put the pot in a water tray on a brick or two.
Keep the tray filled with water and the ants will be unable to swim accross. Unless you have particularly clever ants who build bridges. They do exist...
Otherwise you can use ant killer
Or permiculture approach would be to plant more ghost chilis!
Jun 19, 2011. 8:55 PMbajablue says:
Ghost Chilis? You're a brave person or you have taste buds of steel... or both! ;-)
Aug 19, 2010. 9:56 AMpatito says:
Try with some natural insect deterrent, no chemicals. I use dark tobacco: take the tobacco out of a cigarette and let it soak in 1 liter of water overnight. Then you'll have a brown liquid. Strain it, and pour into a spray bottle. The tobacco is a natural insect killer, and it does not harm the other plants.
Sep 2, 2010. 3:29 PMzexy says:
Thanks for this great Instructable! I think it would do good for everyone to get back in touch with nature and the planet a little and this is just the type of excercise to get it going. :-)
Apr 18, 2009. 6:08 PMsherlocksbumstead says:
i got some bhut jolokia peppers that were dried and i think smoked from india. does the smoking kill the germ or whatever, preventing them from growing?
Jun 4, 2010. 5:23 PMSilence says:
Most likely. Smoking involves heating with temperatures around 275 to 300 degrees (according to the recipe i found) the seed germs will more than likely have been cooked thoroughly.
Jun 18, 2009. 8:43 AMchardster says:
I tried to grow some red habeneros , along with some pepperonchinis, and neither on will grow! they dont die, the just dont get bigger and wont produce peppers or flowers! i got them at a herb festival in little 4-inch pots, and they just wont grow! everything else in my garden is flourishing. i dont have a clue whats worng. maybe overwatering???
Jan 14, 2010. 5:29 AMWILL62 says:
How long we're your pepper plants in those little pots? your plants may be root bound. (roots all growing together in a tight ball) As soon as possible take your plants out of the pots and plant in the garden to avoid this, as it will stunt your plants. and don't fertilize until you have fruit then" let em have it" otherwise all the fertilizer will go to the foliage(leaves & Stems)and sometimes you will get no fruit at all!   Fertilize one time when you plant them, then not again till you get little peppers about a 1/2" long, and full sun for peppers.water as needed
Jan 14, 2010. 5:02 PMoutandabout says:
With any chile peppers the wearing of some type of plastic or latex glove prevents any unwanted irritation to the eyes and other sensitive tissues.
Jun 28, 2009. 2:37 AMawang8 says:
Last time I handled a fresh pepper my nose became slightly snotty and I... umm... stuck my finger up the black hole. 5 minutes later my nose began to burn as though it was on fire (don't ask me how I know what that feels like) and stayed that way for hours... I tried to avoid cooking my own meals with chillies after that...
Jan 9, 2010. 3:59 PMroadieflip says:
Think yourself lucky you didn't go to the loo with chilli fingers. I have done that after handling habanero chillis, and I'll never do it again!
Aug 17, 2009. 7:04 PMexplosivemaker says:
....ohhh, I have done the exact same thing....hurt like crazy....
Aug 16, 2009. 10:35 PMairexurb says:
I'm glad you posted a picture of the flowers. Mine just started to flower and I was worried because they are pointing downward.
Jul 8, 2009. 4:20 PMmrjacobagilbert says:
if you find your peppers are not hot enough for your liking, abuse them a little bit. give them a few short droughts with lots of direct sunlight etc...
Apr 18, 2009. 2:09 PMgardenpat says:
Just keep in mind that if you are planting more than one variety of pepper to keep them away from the other varieties. They are highly promiscuous and you can end up with some that look like your bell peppers and taste like your jalapeno! Ask me how I know! LOL!!
Jun 20, 2009. 5:32 PMRotten194 says:
That's awesome, unless you're like me and can only eat bell peppers.... "Hey look! A bell pepper! Om nomnom. ARGH!"
Jun 24, 2009. 10:47 AMkitsuken says:
That would be an awesome prank XD
May 25, 2009. 2:29 PMpoi_pai says:
I dunno, I kinda want giant jalapenos...
Jun 3, 2009. 4:13 PMIan1104 says:
dude i love hot peppers!! i grow tabasco, white habanero, red habanero, anahiem chile, jalapa mild peppers, rio grande chile, hot paper lantern habanero,chiletipin, peach habanero!!! i think you are growing jwala peppers my friend!!
Apr 16, 2009. 7:24 PMpeacenique says:
When I went to visit someone in Toronto a couple of months ago, I bought a small bag of Habanero peppers. They are never available in this small town I live in. I brought them home then thought it would be nice to grow some. DUH, I was wondering if I'd be able to find seeds for them... I HAVE seeds... right here in the peppers I had just bought. I cleaned a (fresh) pepper and set them on a paper towel to dry in a hot sunny window. As it was getting too close to being too late for this summer, I only dried them a week or so before planting them in small peat pots. Now I have about a dozen Habanero plants growing in my window! As soon as it warms enough, they're going out to my flower beds. I think I read somewhere that you can bring the plants in in the fall and keep growing the plant indefinitely. I'll sure be trying that! Imagine.. a hot pepper tree!
Apr 12, 2009. 10:31 AMiMac says:
Nice instructables! Nice to see theres more pepper instuctables out there ;) Your peppers grew pretty tall and thin from being planted so close to eachother, i would have transfered them once they hit 2-4 inches into a larger seperate pots... it'd keep em more shrubby. Neway, Very cool!
1-40 of 46next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:romaine
