3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Personal Applause Sign
Step 16Build the circuit
Build the circuit
  • last photo ←
Build a Hackduino board as explained here.
Cut the speaker off of your wireless doorbell receiver. Leave as much wire connected to the receiver as you can.
Wire that as analog in to the Arduino. See the schematic for what parts are necessary for this and what wires go where.
Program the Arduino with the following code (source file attached below):
* Based on:
* http://www.arduino.cc/en/Tutorial/Knock
int relayPin = 13; // led connected to control pin 13
int ringDetect = 0; // the knock sensor will be plugged at analog pin 0
byte val = 0; // variable to store the value read from the sensor pin
int statePin = LOW; // variable used to store the last LED status, to toggle the light
int THRESHOLD = 50; // threshold value to decide when the detected sound is a knock or not
void setup() {
pinMode(relayPin, OUTPUT); // declare the ledPin as as OUTPUT
Serial.begin(9600); // use the serial port
void loop() {
val = analogRead(ringDetect); // read the sensor and store it in the variable "val"
if (val >= THRESHOLD) {
digitalWrite(relayPin, HIGH); // turn the led on or off
delay(8000);
digitalWrite(relayPin, LOW); // turn the led on or off
delay(100); // we have to make a delay to avoid overloading the serial port
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
2360
Author:randofo(Randy Sarafan loves you!)
I am the Technology Editor here at Instructables. I am also the author of the books 'Simple Bots,' and '62 Projects to Make with a Dead Computer'. Subscribing to me = fun and excitement!
