iImage Information
Cheap, easy to make personal lubricant. Start to finish is about 10 minutes without cooling time. I'm assuming this is water based, since all it is is water and corn starch. If you are allergic to water or corn starch, do not use. USE EXTERNALLY! Also, since the comments are talking about this being glue, YES, you can glue things together with this, but it is a VERY weak bond since the promintent ingredient is water. The proportions are not correct for making a glue, and it takes a while for this stuff to dry out. I glued two sheets of printer paper together with a tiny dot of the stuff, but I separated the sheets like they were not glued once it dried.
Step 1Gather Materials
iImage Information
1 cup (8 oz.) water
4 tsp corn starch (I do not suggest putting the corn starch in a container. It tends to stick to everything. For the purpose of this guide, it is shown in a small bowl)
A cooking pot
If your corn starch skins over, you're using too much starch. Cut the starch WAYYY back, use more sterile water, and cook it longer. The longer you cook it, the more the "stickies" stick together. A little vitamin E will help preserve it.
The slipperiest stuff I've ever tried is J-Lube. Google j-lube for a LOT more info, and farm supply places that sell it. Veterinarians use it to help calves out, and get their hands in the animals "business".
It's 25% some super molecule polymer and 75% some kind of sugar. It comes as a 10 oz squeeze bottle of dry powder. You don't need much. Three pinches will eliminate all friction in the known universe. You can sprinkle a *tiny* amount on "critical areas", then sprinkle or spray sterilized water on your junk, and slide right in. If she's completely clean (otherwise, it hurts), you can probably get away with it by telling her you're not "in" yet.
(Ladies, you ought to know by now that all men lie, always. Even this is a lie.)
You can also premix it. Sterilize everything (NOT the same as"neuter"). Then nuke it until it boils like Old Faithful on anabolic steroids. The microwave will require cleaning. Water and salt takes it right off. You can store this in the refrigerator for a week or two. I'm experimenting with preservatives. Vitamin E and just a little 91% alcohol kills all varmints I've exposed it to, but CAREFUL - alcohol also burns your junk! I have citric acid (AKA kosher salt), and am looking for a deal on bulk potassium sorbate.
All products made without preservatives woud be contaminated in a few days or hours.
So, the best is to prepare the lubricant shortly before use and discard the remanent. It is so cheap that it has nosense to keep it for long time
Just let a 1/5 teaspoon of Guar Gum to hidrate in 250 ml. of tap water. Shaked the bottle for a minute and let it stand. !0 minutes after that I shaked ir again and that was all.
A perfect lubricant for a ridiculous price. Compared to KY gel this is a a steal. Also, I could made such a quantity to soak all the body of my girl and mine for a very fun and exiting night.
The remaining gel was discarded.
Are adhered belly-to-belly.
Because sad to tell, we used Guar Gum gel
Instead of Petroleum jelly.
Did you make it too hard? Or perhaps you let it dry after some hours. Since it is water based, evaporation of water would make the stuff more and more sticky.
Make the lubricant with plenty of water, it will function very well always
Petroleum gelly is not safe for condoms,
Just tried this recipe (http://www.instructables.com/id/Personal-Lubricant) along with this self-made toy: http://www.youtube.com/watch?v=9e5GoVciKZA. Wow, what a joy! 8-))
You don't need to boil the water for long, just a few seconds will do.
I'll try xanthan and maybe xylitol later, and I will report back if I remember.
Btw, I also tried this, but with little success: http://www.youtube.com/watch?v=Fbc-En-a1Bw. The consistency was a little too friable/crumbly; maybe I'll try again later.
It really works great, xanthan and water make for a superb lubricant! There was only one minor issue: It was not easy to dissolve the xanthan entirely, but maybe I took a bit too much of it for the given amount of water.
Sex parts are not even remotely free of microorganisms, however, so within reason microbes in the lube wouldn't necessarily cause any problem (because the body is equipped to handle such things).
I do wonder, however, if this recipe could benefit from a few drops of apple cider vinegar or something else to make it slightly acidic like a natural vagina.
The vagina is designed to be able to accept a guy's penis... and as we all know, guys' penises tend to not be as clean as one might like. Yet, healthy women generally don't get infected from having sex.
A small amount of a flavor would probably be fine, but to be safe, avoid ones that are alcohol-based since alcohol apparently can be drying or stinging up there and also could disrupt any natural bacteria inside the vagina that help protect from yeast.
Also, peppermint oil shows up in many store-bought lubricants, but some people find the sensations it causes too strong.
