The result is a small, long and modern-styled personal tea tray.
Step 1: Needed Stuff
- mini door handles,
- wood bard,
- 3mm thick plywood.
- wood glue, linseed oil.
Tools:
- router,
- drill press,
- saw, sander.
Step 2: Make Grooves
Use a bit for 4 mm wide and 10 mm deep grooves.
WARNING! a router is an extremely dangerous tool. It rotates much faster than a drill, and can cause nasty wounds.
- Wear protection glasses and work gloves
- Tighten wooden parts in a very stable vise
- Hold router with both hands
- Exercise on some scrap wood
Step 4: Glue
When dry, rectify with a sander. Optionally fill the holes with some wood filler or putty.
Step 5: Make Holes
Drill a blind hole on the bottom side for the screw heads.
Step 8: Finished Product
Wrap it in a nice present paper, together with some tea blends, and make someone happy!
Visit Our Store »
Go Pro Today »
For the glass, I guess you can just insert the glass on top of plywood! it gives your plywood a protection, but also can see the plywood through it. :)
Sunshiine
I am very fond of linseed oil, for wooden objects, used indoor. It protects well enough against liquids, and gives a silky aspect.
