3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Personal Wicked Laser Light Show
Create your own peronal laser light show with everyday objects. Click here to get your own Green Laser Pointer Click here to view Laser Pointer Forum
Be sure to check out the finished product in the video at the end!
Check out my other Instructables
Laserholic Pets
Laserized Music
Step 1Get all the parts needed
Any laser(s) you want
1 CD.
1 DC motor with wires - preferably with a some sort of gear attached.
1 Cardboard Box.
1 samll piece of plastic - a gatorade cap will work.
1 battery, 3.7 volts worked perfect.
1 scissor.
CA glue or any strong superglue.
44 comments
1-40 of 44next »
Apr 16, 2011. 8:21 PMorasca says:
Why is the video private?
You can change the setting on the video to Public.
Sep 23, 2009. 8:55 AMsupercrazytutorials says:
yyeaahh i made mine it works gr8
May 3, 2009. 11:29 AMuhsnamih says:
hei man i really wanna see ur video .............can u just change ur youtube video setting so that this instructable become a great one
Feb 12, 2008. 2:06 AMLaila-mbracethefreakur says:
are dc motors available everywhere?or can you break things apart and use them?
May 3, 2009. 11:28 AMuhsnamih says:
yes mainly u ca get dc motors in radios and toys with wheels.........
Feb 21, 2009. 11:29 AMSagar Gondaliya says:
man you must be nocturnal to be up at 2 am. any way, you can but its better if you get one that can spin really fast to really slow witiot buning it. i used one that was rated for only 24v but i hooked up to 50v and it still works!! and that was 2 years ago!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Mar 19, 2009. 7:18 PMeskimojo says:
This video says that you must be a friend of the user in order to view. Is this a site error or just a mistake on the users part?
Feb 10, 2009. 1:04 PMPyroMaster007 says:
i am going to use my crappy red laser, no questions. i have decided to mount my laser on something that will have it vibrate with the song.. lol, this is gonna b awsome.
Aug 20, 2008. 4:04 PMPlasmana says:
That is really cool! I like it!
Dec 6, 2007. 7:47 PMBlueFusion says:
try http://www.dealextreme.com for much cheaper and better lasers (try the <30mW True). For anyone wondering, Wicked Lasers sell the most expensive, and crappiest lasers on the planet.
or http://www.novalasers.com for some serious lasers.
come to http://www.laserpointerforums.com for a better, unbiased laser forum. Learn to build a high powered red laser or blue laser pointer for under $50!
Aug 12, 2008. 12:30 AMrathat48 says:
I was going to enlighten with this info but than i saw your post, you beat me by a year lol.
Jun 28, 2008. 2:54 PMwethecom says:
mout the lazer on a speaker coil and it will vairy to the music great post thanks
Apr 26, 2008. 11:07 AMskimboarder33 says:
if you use somthing like a souldering devise to melt your name into the cd then could you make it spin your name on the walls?
Feb 26, 2008. 7:57 PMpyroman50 says:
wow
Jan 14, 2008. 9:16 AMAdvocat says:
Can I use a laser from an old cd or dvd player?
Dec 17, 2007. 2:28 PMbowmaster says:
Get 2-5 lazers of different colors and shine them on the CD at the same time!!!!!
Dec 21, 2007. 10:30 AMbowmaster says:
Ask for more lazers for X-MAS
Dec 13, 2007. 7:36 PMcroc594 says:
so wait do you need a lazer????
Dec 13, 2007. 7:22 PMDeadlyDad says:
How about this: mount your laser(s) onto the the diaphragm/dust cap of your speakers(s) and point it/them at the CD. You could also remove the diaphragm/dust cap from dead speakers, make a permanent mount directly on the voice coil, and run them parallel with your regular speakers. By mounting the CD/motor(s) on the ceiling at an angle and pointing your laser(s) up at it, you can cover your whole ceiling with a laser light show without worrying about blinding anyone.
Dec 13, 2007. 5:29 PMredneckone says:
Wow over 10000 views already? This is a really big hit, your probably gonna end up in the finals, see you at school YEEEHAWWWW
Dec 10, 2007. 2:24 AMnatrinicle says:
What about if you removed a speaker from an amplified speaker enclosure and connect the wires that went to it to the motor instead? And maybe while you're at it connect the other speaker to the laser? That would give an awesome light show, especially if you have some good stereo audio to play through it.
Dec 7, 2007. 8:20 AMSakuyasLove says:
This is probably a really stupid question, since I am the only one asking, but I didn't see you use the laser in the build so is this something you set up stationary away from the unit pointing at the CD?
Dec 6, 2007. 7:20 PMk3s says:
Could you use just a cheap laser pointer? I have no access to 80dollars for a laser.
Dec 6, 2007. 8:45 PMmanonfire285 says:
RAAAAAAAAAAAVVVVEEEEEEEEEEEEEEEEEEE PPPAAAAAAAAAAAAAAARRRRRRRRTTTTTYYYYYYYYYYYYYYYYYYYYYY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Dec 6, 2007. 6:03 PMorigamimavin says:
sweet. i just made a similar one. i have a touch switch on the bottom, so when it is placed on a surface to be used, it automatically turns on. the switch can also be found on the drive.
Dec 6, 2007. 3:26 PMjongscx says:
You could rig up two of them to reflect on each other. Then, you could use a pot (-entiometer) to control the speed and make weird patterns. Reverse the spin of one or the other and make other patterns. I'd go for Hot Glue for step 4, since it's more suited for space-filling, since it's a wavy cd
Dec 3, 2007. 3:33 PMswargy says:
wow very cool, I have all those materials. I'm definitely going to make one.
Dec 2, 2007. 8:32 PMSolaryellow says:
Very nice! Lasers, and reflective things, make for some neat fun!! Time for the fog:)
Dec 2, 2007. 6:33 PMCaptainCrash says:
pretty cool. Have you tried it with fog?
Dec 2, 2007. 6:25 PMtrippinonshrooms says:
cool laser trick, smart using the cd to make the light bend im going to try this out for myself
Dec 2, 2007. 6:04 PMilymttybby says:
that's awesome possuem. ♥
Dec 2, 2007. 6:00 PMskarf says:
nice we will have to try it and see how it does at the lake
Dec 2, 2007. 5:45 PMredneckone says:
THIS IS SO COOL!!!! simple yet sweet YEEHAW!
Dec 2, 2007. 4:45 PMGorillazMiko says:
Wow, this is freaking awesome!
1-40 of 44next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:FathomBoy91
