Personal Bluetooth Speaker
3,965
100
8
Published
Introduction: Personal Bluetooth Speaker
Making a bluetooth speaker isn't that hard and it even hasn't to be that expensive. With basic soldering skills and knowledge about electronics you can make yours in one day!
Step 1: Gather the Parts
  • A rechargeable battery, I used an old cell phone battery of 900mAh which gives me about 6 to 7h of music.
  • A charging module, I bought one for €1,32 one DX.com (charging module @ DX.com)
  • A power switch, you can use almost any power switch. I used one of a nightlight.
  • (OPTIONAL) An LED light, I used this as indicator if the speaker is turned on.
  • An amplifier, you best check which one is best for your speakers. i have 2 1W and 2 2W speakers so I went for a 2-channel 3W amplifier. I first bought a cheap one of DX.com for €2,10 (the red one - Amplifier @ DX.com but this one died on me after a week so I bought a better one for about €11 in a local electronic store (the blue one from adafruit). If you want more control and an overall beter performance you shouldn't go for the cheapest options. Although the first (red & cheapest) did perform rather well, better than I expected.
  • A bluetooth audio receiver, I also bought this part on DX for about €6 (Bluetooth receiver @ DX.com).
Step 2: Solder the Circuit
The circuit is very easy to make. You can see two drawings above. Just make sure to wire it correctly and use good cables. For power I used basic copper cables. For the audio I used old audio cables I recycled from old headphones. They are shit to solder but deliver the best sound.
I've placed my power switch in the center of my circuit. Everything before is for the battery so you can charge your battery when the power isn't switched on. With the power switch you enable the bluetooth module, amplifier and LED. In a future project I'll add an extra switch for the bluetooth module becaus even when I'm playing through the audio jack my bluetooth module is consuming power.
Step 3: Make a Casing
My first idea was to 3D print a casing but it would be much more expensive than make a casing out of wood. I paid €10 for a piece of wood at my local hardware store. The hardes part is the drilling of the holes but you'll figure it out.
For my paintjob I first putted a primer on it, then I painted it in dark blue and at the end I painted it with light blue grafitti. I then directly pressed a crumpled newspaper against it which cracked the paintjob. A nice and easy effect I often like to use.
Step 4: Glue All the Parts Inside of the Casing
Now the easiest part. Just glue all the parts inside of your custom casing and seal it!
Enjoy your personal wireless speaker!
    • Planter Challenge
      Planter Challenge
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    8 Comments
    Have you taken off the Bluetooth modules plastic casing? And where do you solder the wires to on the Bluetooth module?
    the top hole is for an LED. just to indicate if the speaker is on. the other is an aux port. the Bluetooth module comes with an aux port, I've soldered wires for the audio so I could use the aux port. you can see this from the inside
    okay, and where have you put the charging module?
    on the right side seen from the back. if you watch the inside picture you can see the powering at the right (with the battery glued to the side) and the sound on the left. I used an old cell phone battery but be careful when soldering the battery!
    In the circuit diagram you haven't shown that where do the 1 Watt speakers go?
    the speakers are connected with the output from the amplifier board. each speaker has a positive and negative, so does the audio output of the amplifier board. I used a stereo amplifier board so I've Left and Right. this is a closer look of the amplifier
    have you got any groundloop noise with that bluetooth module and amplifier combo?
    i used the same amps on one of my projects and a different Bluetooth board module and got a crap load of groundloop problems. Had to use separate batteries for bluetooth and amplifier.
