Remove these ads by
Signing UpStep 1Find yourself a laser cutter
For right now, there are a number of services that you can go to who have laser cutters. In the Bay Area we have Tap Plastic or East Bay Laser & Water Jet. Once you've tasted this tool you will never be happy without one.
In our case we have a 45W Epilog Mini 24. Shown here:
![[blog 2006-04-19] Laser-engraved Leathermen](http://img.instructables.com/files/deriv/FNZ/HPPQ/BAFEP27X1MZ/FNZHPPQBAFEP27X1MZ.SQUARE.jpg)
Nice work.
2. Make your design in your preferred graphics program
3. Go to your local sign making or promotional services company
4. Have your design printed and cut out on a printer cutter onto vinyl sticker material (i'd suggest a 7mil cast, higher quality, lasts longer)
5. BE VERY CAREFUL
-use a mild solution of soap and water to spray item lightly (this allows you to move and reposition decal when your placing it)
-after you have it positioned properly use a plastic squeegee or a credit card starting at the middle of your decal and working out to remove the water from beneath your decal and to flatten out any bubbles.
-If you have beveled edges on the item your wrapping, you can use a heat gun to shrink wrap the vinyl decal around the edges (BE VERY CAREFUL , do not hold the heat gun in one place for too long, especially with electronics) use the lightest setting on the heat gun.. This works better with higher cast vinyls, than with cheap.
DISCLAIMER: I'm not responsible for damages to whatever your wrapping, BE VERY CAREFUL!
chances are they'd only have standard sign shop materials available for skins (read: strong adhesives on these materials) -- but if you're willing to clean off adhesive when you're sick of the skin, go for it -- just request that they print it on a vinyl with repositionable (not permanent) adhesive
as far as i know, that'd be the easiest and likely cheapest way you can go about that
