loading
Step 2: Build or Select Forms to Be Used.
I have made bricks with names also, so have shown some brick forms. For the stepping stones shown, I used a commercially available "walkmaker". These can be found at big box stores. The last time I checked, they were about $13.00. I want to use the largest of the stone shapes as my form. As shown, the form is oriented the way it would be if I wanted to pour a section of walkway. For this use,however, the form is inverted, so that the molded edge will be on the correct face of the stepping stone.
You could also dissolve the styrofoam easily with lacquer thinner.
What is lacquer thinner? Is it methanol or acetone or something else? Mineral spirits perhaps?
Lacquer thinner is an acetone based solvent. Nail polish remover is essentially lacquer thinner. (which would work too.) It might save you quite a bit of time picking at the foam. A dip in some acetone solvent, and a rinse with water, and you should be done. It's probably worth a try on a small project.
Regular Styrofoam will dissolve easily in gasoline, as well.&nbsp; I think that would be even cheaper than lacquer thinner or mineral spirits.<br />
Yup, and you'd be left with a little backyard napalm.
I wasn't planning on making an Instructable about it, but yes, that's true!
What is the difference between cement and mortar?
Hi Creativeman If you put a bit of peat/soil in your concrete mix it would look a lot more natural--weather'ed, I've done this with an old sink in the garden (put sand, peat, concrete mix on It).............Very good idea, I like your way of lettering the concrete I'm going to give this a go. Graham56
Thanks Graham56...I like your idea, any chance of seeing a picture of that sink? What are the ratios/volumes of the mix? Sounds good. Cman
Hi Cman The mix for the sink are 1 part cement 1 and a half parts peat 1 and a half parts sand (sharp if you've got it) I'm having a bit of trouble uploading the pic's but you will get em--- er hang on----
Looks really good, but i don't know what a hot wire is.
Search for Hot Wire on Instructables. There are Instructables on how to make one.
O.K thanks :0)
Has anyone tried doing it right-side up and pressing the foam letters in (forward-facing) and smoothing the surface? I am wondering what the avantages of doing it upside down are? Terry
I think the advantage to doing it upside down is that all the bubbles float to the top. If you want a perfectly smooth surface, put the foam pieces on the bottom of the mold.
Now yanno CMan you put my garden stones to shame here. You did an excellent job on this, professional appearance. V+5. You can make one with my name on it anytiime (hint, hint - jk)
Outstanding.
What is the Mighty Goliath? This sounds like something I could do. I am 70 yrs. old, but would love to make these for my garden.
Photo 5 of this step shows the hot wire machine, Mighty Goliath. Cman
Cman - I am assuming you used mortar cement (1 part mortar to 3 parts sand) and not the cement with gravel in it? thanks!
You are correct sir! Cman
Very cool, I also like your painted rocks; the bunnies, cats, tomato and mouse, they are adorable.
Thanks Chrys. Cman
I see some wonderful Christmas gifts coming my friends way. Thanks so much and I am going to give the acetone idea a try. Keep the great ideas coming.
You are welcome....let me know how the acetone thing works. I tried it a time or two, and it leaves a gooey, gluey mess which was harder to clean out than the foam, alone. (It melts and doesn't "evaporate".) Cman
Very cool. We have been using old pizza boxes for forms to make square stones and painting them. I love this way to add names to them. I have lots of sheets of foam I have saved for various other projects. I see Christmas presents ahead:) Thanks for sharing. (BTW I got the pizza boxes free at the hotel where I worked. If you have a friend that works at one just check in on the morning after a bunch of kids in sports or church groups have been in. They get stacks of them out of every room. Also a great source for light bulbs and toilet paper rolls.)
Thanks VC...thanks for the suggestions as well. Cman
Forgot to mention, I line the pizza box with butcher paper.
You know a Sheri and a Shari, and they both garden?
Very nice, This is an awesome instructable! Where did you get the foam cutter? Thanks.
Thank you so much for this creative use of concrete. Many printers have a "mirror image" setting in the set up screen. This setting makes it easier to do the letters if you could cut the letters and foam at the same time. Even if that would not work, you could use it to make the template for attaching the foam letters to the backer board. If the message size is larger than your printer format (in most cases 8 1/2" X 11",) many printers have a "tile image" feature which will allow you to tape together two or more pages making this step easier. As you have probably figured already, I have no creative ability so I have to use these workarounds to compensate! Thanks again for this great article.
Great stuff as usual. Very well done! I will try this out.
sweet! I would recommend a pressure washer for the foam removal, and you can easily paint the inside of the letters for some contrast (:
Many thanks. And beautifully illustrated with pics. :-)
SWEET! I have to do this.
About This Instructable
47,619views
197favorites
License:
Bio: Retired, doing art work now. Great. Have the time and the money to spend doing what I want to do.
More by Creativeman:SKULL STAND(S) FOR BUDDING ARTISTS The Art Of Reclaiming Oak Flooring:Upcycling Shop Workstand Model Your Before and  After Project
Add instructable to:
