3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pesto Freezing Method
Step 4Freeze and bag.
Freeze and bag.
Freeze in the tray for a few hours. Then transfer to a freezer bag for long term storage.
Its best to get as much air out of the bag as possible. Vacuum sealing would be ideal.
Anyone have a DIY for a vacuum bagging system?
Now, when you need pesto for one, two or five, you have the chunks ready to go. I buy into the conspiracy theories that microwaving kills the good stuff in veggies so I just let them thaw slowly if I cant just throw it in with the hot food. They thaw pretty quickly anyway because of the olive oil....
2 comments
Dec 28, 2006. 11:28 AMall_thumbs says:
DIY wacuum bagging? Amateur boat builders often do it. For this application, I would guess that you could obtain decent results simply by using your vacuum cleaner. I have once stripped the fan and engine from a vacuum cleaner in order to use them for vacuum bagging. Worked quite ok. Another solution, which might be more appropriate for kitchen use, is to buy/build/find one of those nozzles that you hook up to a water tap. (There is a swedish word for them, but I cannot find a proper translation at the moment.) Once you turn the water on, decent suction is "produced" in a side tube of the device. No moving parts.
Dec 28, 2006. 11:51 AMall_thumbs says:
Finally found the name of that simple nozzle thing; water aspirator!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
34
Author:ToolNut
