Pet Ramp
45,376
149
23
Posted in HomePets
Introduction: Pet Ramp
About: I am currently a full time Engineer with a Mechanical Engineering Technology Degree, hence the "eliteMET". I really would like to do, make, create, and experience large projects but I seem to MAcGyver things...
My fiance's dog is 11 years old now and he was starting to have a hard time jumping onto and off of the couch.  So I decided that before something bad happened (he could seriously injure his back jumping off the couch), I would build him a ramp. He actually learned how to use it within the first week. We just say "Newman, use your ramp"
I had the wood, carpet, and supplies laying around the house so it didn't cost me anything to build, but if I were to guess, I would say around $25.
Step 1: Gather Tools and Materials
Wood List:
(Please see pictures for drawings of wood lengths)
- Approximately 15 feet of 1/2 plywood at 2 inch width
- One 5 inch section of 2x4 or scrap wood
- 32 inch by 10 inch piece of 1/4 inch plywood
Carpet List:
-Any thick carpet (the shaggier the better for grip) approximate length at 50 inches and width of 10 inches
Tools List:
- Hammer
- Nails
- Table Saw (for 2 inch width pieces)
- Circular Saw
- Wood glue
- Pencil
Step 2: Cut the Wood
The first set of cut wood is pictured on step 1. All of those require 2 of each piece.
The Wood cuts on this page only require 1 piece of each. I hope that everyone can read my hand writing clearly.
On the wood cuts marked with a Question Mark (?), on step 1, please keep those whole because we need to ruff assemble some pieces to get their exact measurements/cuts later.
So first, cut out all of your pieces but avoid cutting out the triangles on the Question Mark marked boards.
Second, lay out one side of the ramp with the 31.75" piece, 25.5" piece, 16" piece, and the 4" piece. The 16" piece and the 4" piece should be on the bottom. Then, mark the correct angle on the 16" and 4" pieces of wood so that you can finish cutting those pieces.
All of your pieces of wood should now be cut and ready for assembly.
Step 3: Assemble the Wood
Begin by laying out your two halves of the ramp making sure you have the pieces cut correctly and that they all fit. Assemble the two halves individually with a small amount of wood glue and small finishing nails.
Secondly, install the 8.5" cross members with glue and nails. One cross member is easily seen in the picture at the base/corner of the ramp. The second cross member is at the top of the ramp to hold the lip (10" by 2.5" flat 1/4" plywood). You can kind of make it out, its under the carpet.
Thirdly, nail down the small 5" inch piece of 2x4 (or scrap) at the bottom (front - underside) of the ramp so that you can wrap the carpet around it and nail the carpet down in the next step.
Step 4: Install the Carpet
First, lay the carpet shaggy side down and nail down one side. You may need to trim the corners of the carpet so that it fits better.
Finally, pull and stretch the carpet to the other end and nail it down. A second person works well, have them put one foot on the ramp while pulling the carpet so that you can nail it in.
Note: I left the nails a little exposed and then bent them over so that it holds the carpet better and so that we could change out the carpet easier if this one did not work.
Step 5: Test the Ramp
Make sure the pet can move up and down the ramp easily.
Notice that my measurements made the ramp fit exactly. Its the width of their ottoman and height of the couch. That way you are less likely to stub your toes.
Room for improvement:
- I might install small strips of wood horizontally across the ramp so that Newman can grip it better on the way up and down. But, he likes to slide down the ramp when he is sleepy.
Thanks for looking! Please add any Comments or Questions!
"If it ain't broke, make it better!" - Chris W.
Pets Challenge
Finalist in the
Pets Challenge
    • Spotless Contest
      Spotless Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    23 Comments
    I have a 15 year old pug chihuahua mix who recently had to have his acl replaced i was looking for something so he could get up on the bed and i ran across this. Thank you my dad and i built it from stuff i had in my garage and he loves it.
    That's awesome! Send some pics! :)
    Thanks for the comment.
    Regards,
    EliteMET
    Awwwww! Your baby is adorable!! :)This is great. We are looking to build something similar for my golden retrievers to get in and out of my truck... its a very large dodge ram 2500 with some lift. I will be using this as a guideline, however making it collapsible so that I can take it with me to get in and out of truck:)
    I super love this! I have my own family of 4 weiners & already have had back problems with 1 . I'm gonna try to make this the weekend.
    Yes it worked pretty well. My suggestion is to try and make it longer or use a rubber mat instead of carpet. Neuman had a harder time as he got older to climb up, though it was easy for him to slide down when he wanted to. I hope your puppies enjoy it!
    I love this! I have a little dog and this would so help her, thanks!
    Thank you very much!
    This project is excellent! I just ordered some steps for my 14 yr old dachshund but I think I'm going to return them and make my own. This is better for him, since dachshund have long bodies. Great job!
    Just gave me a bright idea for an indoor toddler slide. My son is always trying to build slides out of inanimate objects. I'll just replace the carpet with some smooth board or laminate plastic or something and make a few more adjustments for safety. Walah.
    Make sure to post that, I want to see how it turns out!
    Brilliant! I have 3 Dachshunds (red, 15 yrs old, sisters) that could use something like this! I've noticed for Dachshunds ramps work better than steps because of their long, low body structure. Thank you for sharing!
    No problem! And don't forget, you could always make the ramp longer (gives it a less steep of an angle). A smaller angle will make it easier to get up and down, just watch out for your toes if you make it too long.
    Did you mean to not enter in the pet challenge? Definitely a contest entry!
    Yup, I did enter. I actually just got accepted. It took them about 24 hours to process I guess. Thanks for the reminder though.
    I absolutely love this idea! Much nicer than those steps you can buy. :D
