Introduction: Phil the Skating Frog
Picture of Phil the Skating Frog
This happy frog with the orange roller skates is Phil, a character from my iPad interactive picture books, the Phil and Freddy Series. Phil always wears two yellow buttons and as you can see, he’s partial to candy canes. Hang Phil on your Christmas tree, stuff him in a stocking (just be sure to let him out by December 25th) or put Phil anywhere you want a little whimsical touch for the holidays!
Step 1: Materials
Picture of Materials
·      Sculpey III (2 oz.) Oven Bake Clay in the following colors:
             Leaf Green (dark green)
             Granny Smith (light green)
             White
              Red
              Black
              Yellow
              Just Orange
·      Clay Sculpting Tools – one tool with a curved end, one tool with a sharp point
·      Straight cutting blade
·      Clean smooth surface for hand rolling clay- I like using a thick sheet of clear acrylic
·      1 brass 1-1/4” eye pin – ornament hanger – find in jewelry section of craft store
·      Gold metallic ribbon – narrow (32.918 m)
·      Studio by Sculpey – Glossy Glaze
·      Small paintbrush
·      Glass pie plate (only use plate for cooking clay)
·      Kitchen oven or craft oven
·      Potholder
·      Cooling rack
Step 2:
Picture of
To prepare clay, remove from the package and knead until it's soft and easy to shape.
Step 3:
Picture of
Phil’s body: Roll a 1¼-inch oval-shaped dark green ball, approximately ¾ inch thick.
Step 4:
Picture of
Eyes: Roll two ½ inch oval-shaped dark green balls.
              Next roll two thin ½ inch oval-shaped white balls and press them onto the dark
              green balls to form the whites of the eyes.
Step 5:
Picture of
Pupils: Roll two small oval-shaped black balls and press them onto the whites of the eyes.
Step 6:
Picture of
Place the eyes on the body.
Step 7:
Picture of
Smile: Insert the tool with the curved end into the body to make a crescent-shaped smile and then gently pull down on the tool to open the mouth.
Step 8:
Picture of
Buttons: Roll two small yellow balls and press onto the body. Using the tool with the sharp point, make four buttonholes on each button.
Step 9:
Picture of
Legs:  Roll out two 2 ¼-inch light green logs (approximately ¼ inch thick.)
                Attach legs under frog by pressing them into the body and then bending each leg into a loop.
Step 10:
Picture of
Candy cane: Roll out a 5 ½-inch red log and then roll out a 5 ½ inch white log
                          Twist the red and white logs together and then roll the log on smooth
                           surface to blend the stripes.
                           Using a straight cutting blade, cut candy cane to 4 ½ inches.
                           Curve roll on one end to make candy cane shape.
Step 11:
Picture of
Roller skates: Roll a ½ inch orange oval-shaped ball.
                           Cut in half lengthwise.
                            Press skates onto ends of legs.
                           Wheels: Roll 8 tiny black balls and push two onto each side of both
                            roller skates.
                            Mark little "x's" for ties on the skates.
Step 12:
Picture of
Arms:  Roll out two 1½-inch light green logs (approximately 3/16 inch thick).
                Attach to sides of frog, gently pressing into the body.
                Etch little fingers with a pointed tool.
Step 13:
Picture of
Push an eye pin between the top of the eyes (if using as an ornament).
Step 14:
Picture of
Put completed clay piece in a glass pie plate.
 Bake at 275 degrees F for 1 hour (15 minutes per ¼ inch thickness).
 Set pie plate on a cooling rack until clay is cool to the touch. Gently remove.
Step 15:
Picture of
For a glossy finish, paint on Studio by Sculpey and let the frog dry.
Step 16:
Picture of
Cut an 8-inch piece of metallic ribbon, thread through the eye pin, and tie a knot in the two ends to form a loop.
Now Phil the Skating Frog is ready for you to enjoy!
About This Instructable
719views
2favorites
License:
Bio: Check out our iPad apps--the Phil and Freddy series of interactive picture books--for children ages 3 to 7.
More by authorswithapps:Christmas Angel Ornament3D Clay PaintingMorphing Pumpkin Patch
Add instructable to:
