Phillips Bluetooth Speaker Transformation
936
10
Posted
Introduction: Phillips Bluetooth Speaker Transformation
With this Instructable, I will show you how to repair a Phillips BT2500, or any other Bluetooth speaker.
Mine wasn't working any-more because the micro USB de-soldered itself from the main board.
Step 1: Take Appart the Bluetooth Speaker
First thing, you need to remove all the screws from the speaker.
You can then unplug all the components:
- Main board (Amp + Bluetooth interface)
- Speaker
- Battery
- Potentiometer
You need to identify the problem at this moment.
Step 2: Gather Replacement Parts
Instead of soldering a new Micro USB to the board, I decided to pump it a bit, and change it's form factor.
I took a battery I got from an old asus tablet pc. I bought a micro USB 5V 1A battery charger ( https://www.amazon.fr/XCSOURCE-chargeur-batterie-... ).
I also got a power switch from and old ATX psu.
Finally I used a old philips radio that my dad use to have when he was young!
I used it's original speaker and potentiometer.
The bluetooth speaker was 8 Ohms and 3 Watts and I replaced it with a larger 8Ω 2W speaker.
The battery is also 3000 mA/h, way bigger than the previous 750 mA/h one.
Step 3: Put Everything Back Together
Now, you just need to adjust the old radio. I cut some slots for the micro usb and switch with my dremel.
Soldered everything and testing it along the way.
It's now over you have a brand new "retro" looking bluetooth speaker!
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    Little advice. Perhaps you might want to tell people how to get "into" the Phillips BT 2500 initially. I destroyed mine going in through the speaker screen. I had the micro USB detach also and that is all I wanted to repair. Now I'll just trash it and buy something else. FYI to others...pry the back of the speaker cover off.
