Introduction: Philly Cheesesteak Hoagie
Philly Cheesesteaks are amazing. In this Instructables I am going to show you my way of making the most savory and decadent one. This my version of this beloved sandwich.
The key is to get a good maillard reaction on the beef and toasting the buns!
Step 1: Ingredients
You have to have good ingredients to make a good cheesesteak, with the cut of meat, cheese and the bun being the most important.
- A good cut of steak - rib steak, rib eye or strip-loin. Also rib roast is probably the best buy if you plan on making a bunch and you can have the butcher cut it up for you too.
- Red pepper
- Onion
- Shredded cheese of your choice
- White bread sub bun
- Butter
- Beef broth or chicken broth or water
- Oil with a high smoking point and neutral tasting: canola, corn, peanut, etc..
- Salt and pepper
Step 2: Watch the Video
Check out the video too, the written steps follow
Consider subscribing to my YouTube channel if you like this video.
Step 3: Prepare Your Ingredients
To prepare the ingredients:
- Dice the red pepper and onion, not the whole pepper or onion is needed. For one cheesesteak you need about half a hand full of each.
- Cut up the steak, first length wise and then slice the pieces against the grain of the meat. How much meat you need depends on the size of the buns. I like to use around 1/4 pound per medium size bun. I am using smaller buns so I will divide the portion into two once cooked.
- Butter the bun, this is an important but overlooked technique.
Step 4: Cooking the Cheesesteaks
To make the filling you need a frying pan, preferably a cast iron pan as it holds the heat which will allow you to get a good sear on the beef.
Ensure the meat is dry before you put it in the pan, there is two reasons for this: keeps the splatter down and wet meat will cool the pan down and can prevent a good browning.
- Preheat your pan and add some neutral tasting oil with a high smoking point.
- Wait until the pan is super hot, basically to the point when the oil starts to smoke
- Add the meat to the pan and spread it out. Leave it alone at this point until you see the edges start turning to a grayish brown color. Then flip the meat and brown the other side.
- Add some red pepper and onions and stir, let them brown for a minute. Adjust the heat as required. At this point some salt and pepper can be added if you like.
- Push the mixture to the side of the pan and cover with the cheese of your choice. The more cheese the better!
- Pour in some chicken broth and cover, this will make steam and help melt the cheese and add some extra flavor. Water can be used as well.
- At this point in another pan, grill the buns on both sides.
- Once the cheese is mostly melted, uncover and let the broth steam off.
- Spoon the meaty and cheesy mixture our the buns,
- Enjoy!!!!!
Careful if you make these for your family they will request them often!
