Phone Controlled Computer Starter
20,194
526
51
Posted
Introduction: Phone Controlled Computer Starter
Have you ever wanted to start your computer while you are away from home to access some files? Or maybe you wanted to start a download of a new game, so that it would be done when you got home. This project will show how to start and control your computer from anywhere in the world.
We will use a NodeMCU and the Blynk app to start the computer. After it has been turn on, the TeamViewer App will be used to control the computer.
Step 1: Parts & Programs
Parts
  • A computer to turn on
  • NodeMCU (or ESP8266)
  • Project enclosure
  • Cables
  • Optocoupler (Opto-isolator) i used "Sharp PC817"
  • Resistor 200ohm
Programs
  • Blynk App (on Phone)
  • Arduino IDE (on Computer)
  • TeamViewer (on Computer and Phone)
Step 2: TeamViewer
Download the TeamViewer software on the PC that you want to control. Create an account and add your computer to your list of computers. You can control your computer from another computer or by phone.
Step 3: TeamViewer (To Control Computer)
Also download the TeamViewer App from the store, it is free. Login and go to your computers and from there it is just to click on the computer that you want to control.
Step 4: Blynk (To Start Computer)
The Blynk App will be used to trigger the NodeMCU board that will start our computer. Download the app from the store and make an account. Create a new project and add a button to pin 4 (if you use that pin).
Step 5: Program the NodeMCU With Arduino IDE
The pictures contains most of the information in this step.
Arduino IDE
https://www.arduino.cc/en/Main/Software (Here We can download the Arduino IDE)
Blynk
https://github.com/blynkkk/blynk-library/releases (Here we can download the code library for the project)
Add the ESP8266 board to the Arduino IDE
https://github.com/esp8266/Arduino (This is the website where we find the following link)
"http://arduino.esp8266.com/stable/package_esp8266com_index.json" (We will need this link)
Step 6: Make the Hardware
solder the optocoupler as the schematics show.
Step 7: Power the NodeMCU
The board needs power and I do not want to cut open the wires on my power supply. I added a usb power plug to the back of the case to make it easy to supply the board with power.
Step 8: Connect the Wires
This part is quite easy. Dissconect the cable that goes from the power button to the motherboard and plug in one of the two cables from the NodeMCU instead. Now connect the power button cable (that you just dissconected) to the other cable from the NodeMCU board and you are done.
Remember that the current can only flow in one direction in the optocoupler so if it does not work, then you have plugged the cable in the wrong way. (This is not harmful to your computer).
Step 9: The Build in Moving Pictures
I provided a short video of the build. If you want to see a test of the build, there is some at the end of the video!
Thank you for reading my instructable!
2 People Made This Project!
  • MohdH64 made it!
  • serkanö12 made it!
  • Remote Control Contest 2017
  • Arduino Contest 2017
  • LED Contest 2017
    LED Contest 2017
Questions & Answers
51 Comments
PLEASE HELP ME, I DONT KNOW WHAT IS THE NEXT PROCESS IS? ASAP URGENT..... PLEASE MESSAGE ME IF U KNOW SOMETHING ABOUT THIS PROJECT
I will send you a pm
i cant use for esp standalone why ? cant upload
I guess this answer is a bit to late. But I might be able to help you now, but you will have to provide me with a bit more information about what you have done and what isn't working.
Lovely, always fun to see pictures of other peoples work :)
Hello and thanks for good news here, I like use alternative LiteManager software for free and fast remote control computers into local or Internet, cross-platform \ Windows, Android, Mac. It's very simple and secure. All the best!
Would it be a bad idea to use a transistor in place of the octocoupler?
Using an octocoupler allow me to power the nodeMCU from an external
power source (the 5v phone charger), while controlling the computer
connected to another power source (the computers psu). You can use a transistor with two sources of power like I did, if you connect the grond
of the power supplys together. You can also use a transistor and do it
like "kpqowieuryt" did, only use the internal power supply of the
computer. Read his comment for more info, hope this helps.
thanks. I think I'll attach the high side of the on button to the collector and and the low side to the emitter in parallel. I think it would also be a good idea to attach a digital pin to the power indicator light, then map that to a blynk virtual pin.
