3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Phot-o-lantern
Step 10Shaving and Shading
Shaving and Shading
Here comes the tricky part, but this is also the part that get's the most "Wow" out of people.
There are 2 ways to trim out the grey regions. If the grey is along the border of what you have already cut out, you are in luck. Just make a shallow cut along the traced line, and then stick the knife in perpendicular to that cut through the hole. You can quickly remove large strips in this manner For larger areas of grey (such as my neck section.) you will need to slowly take the top layer off bit by bit. Make shallow cuts into the surface, and then at an angle, stick the knife into the pumpkin connecting with the first cut.. Don't worry too much about it being smooth just yet, just try to get all of the grey area off.
1 comment
Oct 30, 2009. 12:53 PMguymark says:
Wow
You are one seriously skilled / talented person.
Mark
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
22
Author:cainunable
