Photo Collage Art
Published
Introduction: Photo Collage Art
About: Hello there, my name is Delanah pronounced "Del-Ann-uh" like "Banana"...hence the "DelanahBanana" references. I am a mother to three amazing kiddos and wife to a loving and supportive husband. I'm a hairstyl...
Ever wonder what to do with all those extra photos you have laying around?
Look no further!
DelanahBanana.com
Step 1: Gather Materials
Plexiglass (We used a 6ft by 32" sheet, extra thick)
Backing (Wainscoting same size as the plexiglass)
Photos (140+)
Scotch Tape
Hex Nuts
Hex Bolts
Washers
Razor Knife
Step 2: Cut Plexiglass and Backing
The plexiglass and the wainscoting backing need to match exactly.
Step 3: Backer Board
Found a scrap piece of wainscoating at Homedepot that we cut to match the size of the plexiglass.
It doesn't matter what it looks like because it will be completely covered!
Step 4: Sort Photos
Decide which photos you want to use and lay them out across the backing (wainscoting).
This is just to give you an idea of where you want each photo and also how many you will be needing.
Step 5: Photo Layout
Begin placing photos and secure with scotch tape. You want to be able to move the photos around if need be so only add one piece of tape on the back of each photo.
(The plexiglass and backer board will be secured together which will hold the photos in place once you are finished. )
Step 6: Check Check
Once you have placed and secured all your photos, make sure you have everything right where you want it.
Make any changes BEFORE you place the plexiglass because some photos will stick to the glass.
Step 7: Place the Plexiglass
Find a "helper" and carefully place the plexiglass on top of the collage. Make sure you match all corners etc.
Step 8: Cut Edges
If any of the photos are hanging out of the plexiglass, you will need to take the razor knife and cut them even with the plexiglass.
BE CAREFUL!!!
Step 9: Measure and Drill Plexiglass
Measure where you want your bolts in the plexiglass.
Drill a small hole where you want your bolt.
Step 10: Secure Plexiglass to Backing
Take a washer, hex nut and hex bolt, secure the backer board to the plexiglass.
(If your lucky, maybe you too can have a "screw nose")
Step 11: Secure to Wall
You will need to decide what works best to secure your "artwork" to the wall.
We wanted it to set off the wall a bit, but you can also secure it flat against the wall as well.
Step 12: Finished!
Enjoy your collage artwork!
    • Woodworking Contest
      Woodworking Contest
    • Pets Challenge
      Pets Challenge
    • Oil Contest
      Oil Contest
    2 Comments
    How fun for everyone to try to find themselves! This is a nice way to actually do something with all those photo memories. I'd like to see this in my workroom to remind me just why I do all the stuff I do - the happy faces!
