Photo slide projector, lomography style
 by derte84
Featured
To celebrate one year from my first (and one of the most successful) instructable, I thought to re-design it.
The instructable is http://www.instructables.com/id/Cheap-simple-media-projector-with-a-recycled-ike/ and is about transforming an ikea lamp into a projector.
In a year a lot of things happens:
 - I get into the DIY universe
 - ponoko (the online lasercut service) open a factory in Italy near where I live
 - I bought a Lomo Camera (http://lomography.com) and discover how cool are 35mm cameras
This project reflect all these changes. I'll show you how to buil a lo-fi projector to display your photo slides on a huge wall. The lo-fi aspect is crucial to lineup to the lomography way. The fact that the project is also cheap is a plus! Sadly, the ikea lamp I'm using ( isbrytare ) is out of stock and no more produced. You have to found in used or hope that Ikea will start again producing this beautiful lamp. Its cost was about 40$.
The lamp became a present for the birthday of a very good photographer and friend: Fizza (http://www.fizza.it/)
Finally I'll give one or more patches to the best comments/improvements to the project you will post.
If you are interested, you can view the list of my not-yet-realized ideas on my blog
Step 1: Material needed
In order to build your own lomo projector you'll need:
  • isbrytare lamp from Ikea (ikea.com, no more in production.. find it on ebay)
  • plans to build the adapter (downloadable in the next step)
  • something to cut wood if you are planning to build it by yourself OR an account on an online laser-cut service (i use http://www.vectorealism.com)
  • vinilic glue
Step 2: Cut the wood for the slide holder
In order to build you slide holder download the two files attached to this step.
Now you have to choose how to proceed:
  • you can give the file to an online laser-cut services and let them to made the work for you. They will precisely cut the pieces and send them to your home. I suggest you to use 1/8 inches wood (mine is actually 3 millimeters)
  • you can print the files on paper and glue the paper on thin wood as a guide for your cutting lines
If you choose the former, I suggest you to choose ponoko.com simply because files are already formatted for that site.
If you choose the latter you maybe need some more info:
A file with SVG extension has a particular format named VECTORIAL that allows you to describe an image with mathematical formulas. In other words, you can zoom the image as you wont without loosing quality. If you do not know how to open these file just download the open-source, multi-platform and free software http://inkscape.org/
Step 3: Assemble the slide holder
Since we are using wood to assemble the holder we need vinilic glue
  • Step 1:  glue part A to part B. Be careful to not exceed with the glue and to align the center hole of the two pieces
  • Step 2: turn the obtained piece and glue part C. Be careful to align the central hole and the side holes. (the order of the wood layers should be A - B - C)
  • Step 3: glue part D over part C again being careful to align holes
  • Step 4: leave the glue to harden for 24 hours
Step 5: Assemble the lamp and focus
Assemble the lamp putting the slide holder on the rails first, then the Fresnel lens. For now you do not want to fasten the screws.
Power the lamp and point it to a big wall. Move backward and forward the 2 pieces until the image on the wall is on focus
I also added a wood floor to the lamp so that it can stand by itself.
Enjoy your new photo-slide projector
derte84 (author) says: Jun 2, 2012. 5:00 PM
derte84 (author) says: Jun 2, 2012. 5:01 PM
Featured on Make Magazine
derte84 (author) says: Jun 2, 2012. 5:03 PM
Featured on Ikea Hackers
Featured on Unplggd
derte84 (author) says: Jun 2, 2012. 5:04 PM
Featured on Lomography
derte84 (author) says: Jun 2, 2012. 5:05 PM
Featured on Vectorealism (Ponoko's partners)
derte84 (author) says: Jul 5, 2012. 4:48 AM
Featured on DIY photography
dbell says: Feb 12, 2011. 10:20 AM
The first two images in this step contradict each other!
You must put the slide holder between the amp and the Fresnel lens in order to project an image. The second image is correct.
I could read the text either way, but would more likely say to "put the slide holder on the rails first, then the Fresnel lens."
Nice project, and a very pretty result!
Dave
derte84 (author) in reply to dbellFeb 20, 2011. 2:04 AM
Fixed, thanks :)
mengsuc in reply to derte84Feb 13, 2012. 10:13 AM
Fresnel lens focal length is?
ninjarider500 says: Feb 20, 2011. 9:38 AM
i like your room design and the projector is pretty cool
derte84 (author) in reply to ninjarider500Feb 21, 2011. 12:48 AM
Deeg says: Feb 16, 2011. 7:57 AM
Very nice! Since Ikea no longer sells the Isbrytare, do you (or anybody else) have a suggestion for what I could use instead?
Callum Snowden says: Feb 12, 2011. 1:28 AM
You could drop the whole lamp and assembly into some large diameter PVC pipe to contain more light so the image is brighter and then you would just have to cut a hole for the slide to go in :)
derte84 (author) in reply to Callum SnowdenFeb 14, 2011. 5:09 AM
I tried but It doesn't works. The problem is that the lamp has no fans and with the pipe the temperature goes too high (and the slide risks to melt :)
Thanks anyway for the comment :)
derte84 (author) in reply to Callum SnowdenFeb 12, 2011. 4:52 AM
I'll try in the next days. If it works i'll give you a patch :)
Callum Snowden in reply to derte84Feb 12, 2011. 5:42 AM
Yay! Thankyou,it will be my first patch:)
arale says: Feb 12, 2011. 6:39 AM
Vectorealism.com è l'hub italiano di Ponoko. Ordinando sul sito italiano ci sono un po' di figate in più rispetto a Ponoko: per esempio la possibilità di richiedere o fornire da soli i materiali e, mica male, i prezzi in Euro.
icsnerdics says: Feb 11, 2011. 6:17 PM
bel progetto! davvero la ponoko ha aperto uno stabilimento vicino Trento?
derte84 (author) in reply to icsnerdicsFeb 12, 2011. 1:49 AM
A Milano in realtà, lo considero vicino rispetto al più vicino precedente che era in germania
icsnerdics in reply to derte84Feb 12, 2011. 3:06 AM
eh si, decisamente più vicino, l'avevo scovata già in realtà la Vectorealism, ma non avevo idea fosse affiliata alla Ponoko.
ottimo anche il fatto che fanno lavori su materiali diversi su richiesta, basta fornire un campione per le calibrazioni, davvero una bella iniziativa!
derte84 (author) in reply to icsnerdicsFeb 12, 2011. 4:53 AM
non lo sapevo.. io ad esempio avevo bisogno di tagli su pelle + sottile di 3mm ... mi hanno detto che stanno cercando una pelle adatta :)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
