Photograph Water Splashes
3,306
89
15
Published
Introduction: Photograph Water Splashes
About: I'm a retired IT consultant. Besides answering questions on StackOverflow I play around wth Atmels in various home projects. Recently I played a lot of Minecraft but since the hardcore mode does no longer th...
This is another of my pre-Instructables projects. Again it lacks some documentation but still I think it's a nice one to share.
Taking a photo of a water drop splashing on a water surface isn't too difficult - if you invest a little time. And the results are quite stunning. There are lots of people driving this to some excess or doing it professionally. This was not my intention. I just wanted to explore how difficult it is to catch this splash-moment.
Edit: I have added the renamemetogif file with a sequence of drops (as suggested in the comments). You need to download and do as the name suggests since the build-in view does not show animation in gifs.
Step 1: Catching the Moment
The first thing to do was to recognize the single drop falling from a certain height, ready the camera, wait a short amount of time, flash and close the shutter. This could be controlled by my Arduino. It just needed the input about the drop passing a point, a trigger for the flash and another for the camera.
Passing drops
I simply mounted a yellow LED (because I had one lying around) and a LDR (light dependent resistor; because I had a dozen of them lying around) opposing on a 3 cm PVC tube in holes that fit. A drop created from a syringe falling down the tube had to pass the light/resistor gate resulting in a change of the LDR resistance. A few tests showed that this worked - oh kay - so to say. Definitely a laser from a laser pointer would have produced much better results. But for my tests I decided to leave it this way. I just shortened the PVC tube later to just hold the light gate.
Flashing the light
The next step needed some watching on eBay. I shot a flash for about 6€. That was simply perfect. Instead of the 4 AA batteries I connected my lab power supply. The trigger only needed a simple transistor driven by the Arduino. I opened the flash casing and soldered two wires for the trigger. Just to find out later that there was a phone jack which had the two pins already connected. Anyhow, my Arduino was able to trigger the flash - even multiple times per second depending on the needed strength (so having a possible stroboscope!).
Having said strength, opening the case was not that fruitless. The sensor which shuts the flash after enough light has been shed, had a loose cable. So that was fixed on the go.
Pressing the trigger
Operating the camera to open and close the shutter at the right time was more a challenge. I have a very old Casio where I once made a frame to trigger it with a servo. This worked quite nicely but for this project I needed some better camera. So I borrowed my son's Canon. Not a professional device too but more than good enough. Most of the Canon cameras can be hacked to be remote controlled via USB power. Find out more at CHDK (Canon Hack Development Kit). Basically you load a new firmware temporarily into the camera and get tons of new features. I just needed the remote operation via USB. I chose the mode where the first trigger readies the camera (setting focus etc.) and the second actually opens the shutter for the preset time.
Putting the basics together
Now, when the Arduino detects the falling drop (which worked in about 30% of the cases) it sent the first ready signal to the camera. A short delay later the shutter was opened with the second trigger. And finally the flash was triggered to take the photo. This way I got my first falling drops banned on camera chips.
Step 2: More Drips
Since taking photos this way was very cumbersome, I decided to add a motor-driven syringe to produce the drips. Luckily I have a set of Fischer Technik which is ideal to build prototypes. With a few bricks and cog wheels I created a syringe press that allowed to create lots of drops rather precisely. But of course the manual way was not what I was after. I needed to got for "The Full Monty".
Step 3: The Fully Automatic DPAPT (drop-producer-and-picture-taker)
So here is the complete setup. The lab power supply is just used for the flash light. This and the camera are on a small mount that came with the flash. I used some aluminum foil as diffusor for the flash. The mount is fixed on my Dremel vise which allows a nice positioning towards the target. The target is a small egg cup made of glass and filled with water. I placed a piece of white paper behind to get a better light. Unfortunately paper soaks up the drips that splash out and are visible later. Better would be some white plastics you could clean easily.
A bit higer on a stool I placed the rest of the setup clamped to a wooden plank. The syringe press now has a stepper motor driving it. It would turn the motor until a drop has been presses out of the hose and been detected by the photo gate. Now the press motor is stopped and the before mentioned photo process issued. First I had a lot of bad photos until I discovered that the camera needs quite some time to process the photo before another one can be taken. Being too hasty results in bad/black photos. So after a short pause the drop creation is continued until a certain amount of turns of the motor. The motor then turns backward these turns and the syringe can be reloaded (manually). So the only thing to do was: press the start button, wait for all drops to be fallen, clean the camera/spilled water and eventually unload the camera chip to my computer where I had to revisit the photos for good and bad (not so easy).
The schematic is rather simple, so I just attach a picture of it. The same goes almost for the sketch. Initially it waits for the button to be pressed. A short press just produces a single drip and a long press will repeat until the syringe is empty (number of motor turns). The timing values were found empirically and need to be adapted for each setup. It's quite interesting to modify the actual point in time to see different splash-phases.
Step 4: The Last Drop
Yep. That was one of my last photos. It was fun but I'm not addicted. Maybe with lessons learned I will create a new machine in the future. I also know that it's fun to use milk and color instead of simple water. I did not try that, though.
Once again apologies for missing parts and especially the video with the operating machine. Maybe with the next one :-)
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    15 Comments
    I did mine manually, water, food coloring, a dropper with a hose connected to a bulb, camera with flash.
    Can't remember what they are called, the image next to my name, avatar, maybe? Is one of those pics.
    takes a bit of patience, I took more then 20 shots got 2 or 3 that I liked.
    Yes, it's called avatar :-) I'm pretty sure I used many more before even catching the first drop. I have seen a guy in a documentary who had a whole professional studio with lots of colors in syringes mounted on top, flashes and a pro camera. He was also doing it more or less manually. But he had invested (as it seems) many years of experimenting.
    when doing it manually one gets the hang of the delay till it hits the water fairly quick, but still takes patience and a lot of luck to get the perfect crown, I never got one, my daughter took a dozen of pics and she got one almost perfect!
    That's what I thought seeing the guy in the documentary. My final construction was able to produce about 30 drops or more from one syringe filling. And most of them were fine (except those missed on my badly constructed light gate). So finally the main task was to sort out the bad ones. I also had a program modification to shift time a bit more each drop. So I could see different phases. Since all were from the same perspective it was possible to make some sort of film by fast sliding the pictures. I'll see whether I can make a tiff out of some of those.
    But, all the work preparing it all for a picture is half the fun!
    I'd say it's by far more than half of the fun :-)
    Thanks :-) You haven't seen those tons of pictures where nothing is seen at all because of the flash starting the wrong time ;-)
    Probably not. Though it seems to be feasible as another poster pointed out.
    See also the comments of zyck below. Seems he actually did it that way.
    Hehe. Photographing water is easy. But getting the right moment is tricky. What you can try is to mount a camera in a dark place (or at night) open the shutter and produce some drops with a syringe free hand and then also flash free hand. If you got some rhythm you might find the right moment for the flash when you hear the splash. Just try a drip/flash sequence without camera and you eventually will see the falling drop.
    No, this will not work. Except you have a some 10k $ high speed camera. The moment is very short so you need a flash (probably a lot of light an an exact shutter control could also work). What you need to do at least is a photo gate to trigger a timed flash light. But getting the right timing is very tedious and you would need to create everything manually.
    I did something very similar. The LED ed worked out better than the laser for me.
    I took the tube of a pen and cut it in half. An IR LED was mounted in the end of one half of the tube. An IR transistor was mounted in the end of the other half. The two halves were mounted so the LED faced the IR transistor and the 2halves of the tubes were separated just enough for a drop of water to fall down in between them. I decided to use the IR LED/transistor setup because water is very effective blocking IR light.
    The other difference between your setup and mine is that I used a solenoid valve to release the drops. This one http://www.amazon.com/Vdc-Normally-Closed-Solenoid-Valve/dp/B007D1U64E/ref=sr_1_19?ie=UTF8&qid=1451273739&sr=8-19&keywords=solenoid+water+valve
    I used a DSLR so driving it was quite easy using a manual bulb release driven by the microcontroller to trigger the camera.
    Ah, cool :-) I hardly can imagine how the valve can produce so little amounts of water. Or is it that you produce more like short "shots" of water?
    The valve is fed from a soda bottle with water, so no high pressure.
    The benefit of the valve is that you can time the drops using the uC. If you time it correctly, you can have a drop fall on the splash of another.
    I see. I might try that with my next approach. Thanks for sharing :-)
