loading
Step 3: Attaching a Webcam to the Microscope
Before you start, make sure your computer has drivers for your webcam.  You want to try out the camera and your webcam software before disassembling it.
1. Unscrew your webcam case and remove from the case the circuit board with the USB cable.
2. There will be a round plastic lens assembly.  Unscrew it from the board.
3. Under the lens assembly, you should find a recessed area with a very small sensor.  Keep the sensor clean and don't touch it.  I recommend keeping the lens assembly on whenever you're not actually using this.  I've just blown off dust when I needed to.
4. Remove the eyepiece from the microscope.  Place the circuit board with the sensor pointing down on top of the tube.  Try to center the sensor in the tube where the eyepiece was.  Gently tape the circuit board onto the tube, trying if possible not to attach the tape to any electronic components that might break when you remove the tape or that might overheat in conjunction with the tape.  The first time I did this, I used electrical tape.  The second time, I used paper tape.
<p>the 20 project</p>
<p>I want to build electronics microscope. For tracking surface mount circuit boards. Is this article good enough or more modifications required. Image processing probably will require. Webcam are good enough for having high resolution images? I would like to try this article with 25MP webcam. Will it work fine?</p><p>Thanks :-)</p>
do u think this could work if one just has a couple of microscope lenses? i have a lens and an eyepiece lying around and no actual microscope<br><br>other than this I can't think of any other uses for the lens
It should, if you find a way to mount the lens and eyepiece securely enough. You'd basically be building your own microscope. Maybe you can take a PVC or aluminum tube and mount the lens at one end and the eyepiece at the other. The objective might say on it how far the focal plane is from the objective (standard numbers range from 170mm to 210mm). If not, you can play around with around 180mm length.<br> <br> Then you need to suspend the tube and lens securely in such a way that you can move them up and down to focus. If I were doing it, I would consider something like my wooden&nbsp;<a href="https://www.instructables.com/id/Simple-wooden-Crayford-style-focuser/">telescope focuser</a>. &nbsp;This works better with an aluminum tube than PVC, since PVC will bend under the pressure. &nbsp;You'd need a fair amount of pressure to hold the weight of the camera in that focuser (I didn't design the focuser for holding a camera). &nbsp;There are other options, like maybe some version of <a href="https://www.instructables.com/id/Airline-portable-8-Dobsonian-telescope/#step7">this</a>. &nbsp;Alternately, you might find some way of keeping the tube fixed and moving the sample up and down.<br> <br> If you use an objective and a lensless camera (webcam or a point-and-shoot with lens removed) in place of the eyepiece, that'll reduce weight a bit.
Good point, though the newer DSLRs have such high resolution that even a small image circle is fine.<br><br>Still, maybe the best thing would be a point-and-shoot with lens removed (actually, hanging off to the side, or else the camera will think it's broken and not work), like some people use for astronomy but without the complications of timed exposures. The image sensor is bigger than on the webcam but small enough to nicely fit the image circle. The webcam's image sensor is so small that it makes for a little too much magnification (I suppose one could put in a focal reducer, though).
There are two problems I've read about with using a lensless SLR on a normal microscope. First is that typically the image sensor is way to big for the image circle that the microscope projects. Second is that it may not be possible to focus because the image sensor is set way back in the camera behind the mirror. <br>Micro 4/3 cameras may work, as they have smaller sensors as well as a shorter flange focus distance (no mirror.) I don't think I've looked into this since the micro 4/3 system was out though.
I like it very cool.<br>The first part involving the camera on the microscope is quite similar to something I have been doing for a few years for wildlife photography; I'll be entering an 'ible about it as soon as I have selected a few pictures to accompany the text.<br>Oddly my better half said she unpacked a really nice microscope in the charity shop she volunteers at today, guess who is going to buy it in the morning? ;-)<br>
I assume you mean that you've been hooking up the camera to the eyepiece of a spotting scope? Yes, I've been finding that what what works for telescopes tends to work for microscopes. I've done it with the last total <a href="http://prussastro.blogspot.com/2010/12/lunar-eclipse.html">eclipse of the moon</a>&nbsp;and <a href="http://prussastro.blogspot.com/2010/11/clavius.html">Clavius</a>&nbsp;and a <a href="http://www.flickr.com/photos/pruss/3399046722/">crescent moon</a>&nbsp;(and Venus and Jupiter, but the results were poorer), though I think most of these are with the camera hand-held.
I just posted the 'ible I mentioned if you are interested take a look here:-<br> <a href="https://www.instructables.com/id/Close-Up-Wildlife-Photography-Without-Hi-Tech-Equi/">https://www.instructables.com/id/Close-Up-Wildlife-Photography-Without-Hi-Tech-Equi/</a><br>
Not exactly..... :-)<br>I will be posting the 'ible soon you will see what I mean then.<br>I do like the idea though, now all I have to do is get hold of a suitable scope.
I wonder if you would get even better results with stacking and a webcam if you had the sample on a slowly movable stage and moved it slowly, the way astronomical images on a non-tracking telescope do.
I must say, this is actually a very useful and informative Instructable. Very well done and lots of description and photos to back it up! There's so many instructables coming out now that are pure BS.
Cool method and great photos!
I am from Argentina. I will try your method. Its awesome, thanks.
Cool!<br>
About This Instructable
43,596views
136favorites
License:
More by arpruss:Use 3D printer as a plotter/cutter Finger extensor exerciser 3D printable cookie cutters with Inkscape and OpenSCAD
Add instructable to:
