Photography Ring Light V2
Published
Introduction: Photography Ring Light V2
Hello guys. The ring light is one of the most amazing lighting gears for portrait photographers. This is our second one we made. We thought it will be nice to share it with you and show you the steps how we made it.
Note:
This project was made in FABLAB Dhahran by Jafar Alobaid and Hussain Alhudhud.
Step 1: Requirements
For this project we will need:
  • Light bulbs (25). ( We used LED - 6500K)
  • MDF wood. ( we used 15mm thickness)
  • Light sockets (25).
  • Power switch. (optional)
and we will need a CNC machine to cut the design.
Step 2: 2D Design
For the design we made a circle with a diameter of 1 meter.
This circle will hold two sets of lights. The outer set will contain LED bulbs and the small circle will contain 10 LED bulbs.
Note:
  • Make sure to measure the diameter of the sockets correctly before you cut the design.
Step 3: Assembly
Once you finish cutting the body, it's time now to connect the lights together. This is really a simple circuit but it will take some time to finish.
Just take your time and be patient.
Step 4: Final Product
Here's our final product. We were very happy with the final result and the quality of the images we took :)
I hope like it :)
    • Clocks Contest
      Clocks Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    4 Comments
    Nice design, and it seems a formidable ring light! Just one thought: I'm sure the main design could also be cut out by hand using an electric jigsaw and working carefully. The holes can drilled with the appropriate size spade or Forstner drill bit.
    Thank you :)
    Yes, you are right .. I've some tutorials on youtube cutting it like that.
    Thanks you ,, yea it's really very great :)
