3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Photography for Dummies!
     As digital SLRs are popularizing, many people are getting into photography that normally wouldn't have. Not only is this because of the ease of using a digital camera, but also because of the enormous cost savings compared to film cameras. DSLRs do not require expensive film to be bought and developed, which allows you to take more pictures, and learn to shoot better, faster.
     In this instructable, I will teach the basics of photography, which include:
-Camera basics
-Rule of Thirds
-Manual vs Auto Exposure
-Lighting Techniques
-Sport shots
-Portraits
-Night Shots
Step 1Camera Basics
Camera Basics
In this instructable I will be referring to DSLRs only. This is because the quality achieved on a DSLR, and the control gained from it is huge versus a normal point and shoot. And while spectacular photographs can be taken from a standard point and shoot camera, most interested in photography use a DSLR.
First and foremost, the basics. We'll start off by exploring what a DSLR actually is. DSLR stands for Digital Single Lens Reflex. Basically, what this means is that what you see through the viewfinder, is almost exactly what the lens sees, and what will end up in the picture. One of the reasons that the quality is so much better on a DSLR than a PandS (Point and shoot) is that the sensor size is so much larger. The sensor is what records the light coming into the camera. The larger the sensor, the more light it can record. This makes the quality very good in low light situations. Another reason that the quality is higher is because of the lenses, also referred to as glass. When you are trying to essentially record light, one of the main goals is not to distort it. This is achieved by using better designed, better manufactured lenses. Think of it this way, if you have light going through a dirty window, you are not going to be able to see very well through the other side. However if the window is clean and built right, then you will be able to see perfectly.
     Now lets cover the basic settings, starting with shutter speed. Shutter speed is the speed at which the shutter moves. The shutter is what stops light from hitting the sensor. The slower the shutter speed, the longer the shutter is open. On the other hand, the faster the shutter speed, the less time the shutter is open. Using this basic concept is what allows photographers to not only properly expose, but also freeze, or blur, their pictures. But we'll get to that later. The main thing that shutter speed controls is how much light gets into the camera. If your picture is too dark, slow down the shutter speed. If it is too light, speed up the shutter speed. Next, ISO.
     The ISO is the speed at which light enters the sensor. This means that a low ISO, will record light more slowly than a fast ISO. Then wouldn't it make sense to use the highest ISO possible? No. This is because the higher the ISO, the more "Noise" or "Grain" your photograph will get. Although grain is sometimes desired by a photographer, for the most part it lowers the overall quality of the picture. A good ISO to stay at is around 200.
     Finally, we get to aperture. The aperture, is the size of the hole in the lens. The bigger the hole, the larger the aperture, and the more light that gets in. The smaller the hole, the smaller the aperture, and less light gets in. This is recorded with f-stop. This is the confusing part however, because, the smaller the f-stop number (such as 1.8) the WIDER the hole/aperture. The higher the f-stop number (such as f22) the smaller the hole/aperture. This means that f1.8 will let in more light than f22. So why not just open the aperture all the way? Well again, just like ISO, there is a catch. The wider the aperture, the less depth of field you get. Depth of field, is basically the amount of the picture that is in focus. Therefore, a picture taken at f1.8 will have barely anything in focus, while a picture taken at f22 will have most of the picture in focus.
     Now that we have covered exposure settings, I think it's time we quickly skimmed over white balance. White balance can be pretty simple, all you need to do is to look around you. See what type of lights are lighting the area you are in. They might be incandescent light bulbs, fluorescent lights, the sun, or you might even be in the shade. Read your manual, and find out which symbols symbolize which type of lighting. Once you have figured out what type of lighting you have, set the white balance to that type of lighting (incandescent bulbs are often called Tungsten). So if it is sunny out, set it to (most likely) the small picture of the sun. Or if it is cloudy, set it to the picture of a cloud. You need to do this because different light will have different "temperatures" which are measured in Kelvin. You want to adjust so that you are set to pure white light. This means that if you held up a piece of paper that was absolutely purely white, that your camera would record it as such. You can get something called white cards, and set your camera using that (which will give you much more accurate white balance) but for the sake of this instructable, using the presets is much easier.
     These settings can be confusing at first, but mastering them is key to obtaining good photos. Play around with them to learn the kind of picture that can be gained from a certain combination of settings.
25 comments
Nov 25, 2011. 12:38 AMCMAINA says:
Thanks for this. Page bookmarked, very easy to follow.
Still need some time to get the aperture, shutter speed and the like all sorted out in my mind though.
Aug 23, 2011. 1:33 PMmarty2116 says:
Thank you so much. I took notes! :)
Mar 28, 2011. 10:47 AMsk3lton says:
Thanks for the great tips I now have this page bookmarked incase i need to go back and re-read. I only recently got into photography and your I'ble is very clear and easy to understand
Jan 12, 2011. 11:48 AMBlueray03 says:
Wow, What a picture!
Nov 24, 2010. 7:29 PMthe.texas.trucker says:
There is only one thing I would have added in your instructable. I'm new to photography so I wont be able to explain this too well, so hopefully someone can brush it up a little.
The topic is about "leading lines". You have a great example of it in your last set of photos, the second photo in the group where the couple is walking on the road away from the camera. The road not only follows the rule of thirds (starts along the right vertical line, then transitions into the diagonal line you spoke of) but it also creates a very nice leading line.
When you look at that pic, the first thing you typically notice is the couple, then your eye is drawn down to the road they're on, and your eye follows the road into the rest of the picture.
Leading lines are a great way to tie subjects into the rest of the picture.
Sep 24, 2010. 7:25 AMcherrygreen says:
Thanks so much for this instructable! It was very helpful, I learnt a lot :-)
Jul 1, 2010. 1:19 PMaplauche says:
this is a kickass photo right here. i'd say its my favorite of the ones you posted... almost looks surreal like a painting
Aug 11, 2010. 6:21 PMgtrachel says:
I agree, it does look like a painting. Fantastic.
Jul 12, 2010. 10:46 AMwats-a-username says:
excellent instructable explained alot for me as i have decided to become a photographer and this just gave me a leg up to get started on so 5* and keep up the great work
Jul 9, 2010. 6:57 AMiamunique127 says:
Good basic Instructable. Just the right amount of detail for an intro. It was all clearly explained (but then I've got a pretty good understanding already). I've been a photographer for 30 years and read this to see if I could pick up any new tips or techniques. I don't often do night shots so I did learn a few things there. Well done. Thanks
Jul 8, 2010. 8:54 PMSilence says:
I just got a set of expansion tubes for macro, would a narrow aperture increase the depth of field in such cases ?
Jul 1, 2010. 4:22 PMbovlch says:
The lens flare in the fourth picture could be easily confused for a UFO sighting.
Jul 8, 2010. 8:47 PMSilence says:
Or ghosts.... Orbs as they're termed :P
Jul 2, 2010. 5:42 PMsolarblade90 says:
lol
Jul 8, 2010. 3:56 PMmdog93 says:
yeah, really nice, almost looks computer generated. It also reminds me of something out of harry potter or something like that. :)
Jul 8, 2010. 12:15 PMMelty Mcface says:
Good work. I knew the technical stuff about aperture and shutter speed, but not so much about lighting and the Rule Of Thirds (tm). I feel I've learned some good basics to get my photos looking a lot more professional now! Thanks! Joe
Jul 8, 2010. 11:30 AMhorseflesh says:
In the section on exposure, I suggest better explaining how the camera's auto exposure works. The camera assumes that whatever you are shooting at is sort of neutral grey, and exposure is calculated based on that. If you are shooting at something that is, indeed, kind of neutral in tone, all is well. But what if you are shooting at snow? It comes out too dark. What if the subject is a black cat? It comes out too light. That's when you use the exposure compensation control. When you shoot at something light, you add EV to overexpose a little. Shoot something dark, spin to -EV to underexpose a little. Once you really understand this, photography makes a lot more sense. It was a true AH-HA! moment for me. Then you can begin studying the different metering modes the camera offers. Soon you will be able to look at a scene and know how the camera sees it. Ultimately you can then master manual exposure, for maximum control.
Jul 4, 2010. 10:16 PMbrosiaholic says:
I learned a lot from your instructable ledzeppie. Thank you very much! :)
Jul 2, 2010. 12:00 PMnf_x20 says:
vancouverite? am i correct? :) good stuff you wrote
Jul 2, 2010. 11:46 AMsolo.card says:
Very nice, and without getting too much into the nitty gritty detail!
Jul 2, 2010. 6:09 AMDries von weidtz says:
Ledzeppie Great tips . Thank you .You explain stuff nicely (and english isnt even my home laguage) Where can i contact you for more photography info ? (e mail adress maybe) Thanks Dries
Jul 2, 2010. 12:48 AMteoeva says:
is this the NYC's skyline, fron Brooklyn side? I think i was on this bench two weeks ago ;)
Jul 1, 2010. 11:52 PMallesflex says:
Very well done, very clear explained in a few words!
Jul 1, 2010. 6:55 PMhuang.wencong says:
Great Instructable! After reading this I borrowed my friends EOS 40D, and here is a portrait photo: http://farm5.static.flickr.com/4011/4659853696_1e2604c032_b.jpg
Jul 1, 2010. 11:24 AMmikeasaurus says:
good job explaining the rule of thirds, a biggie when it comes to composition. a more advanced concept regarding composition I've also seen used is the golden ratio
also, nice to see my favourite city looking so good!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
46
Author:teaaddict314
