Here's how to make a photo within itself. It's easy to get started. This is what you'll need: -Camera -Picture Frame -Image-Editing Software(Photoshop...
In Photoshop, open a new file. (File-New-Blank File...) Open the properties window of your photo. (Right click on photo-Properties-Details tab) Match ...
Tweak sharpness, exposure, and other settings with the dropdown menus. For example: (Enhance-Adjust Lighting-Brightness/Contrast...-OK) I increased t...
Make a copy of your current layer. (Layer-Duplicate-OK) In the Layers window, drag the copy layer below the original layer. Resize and rotate the copy...
(Ctrl+Click all layers-Layer-Duplicate-OK) Drag these copied layers to the bottom of the layer stack. (This puts them underneath all other layers.) Re...
Now you'll want to get your image out of Photoshop and into a regular file. Export the entire image as a JPEG, PNG, or any other desired file. (File-...
-Camera
-Picture Frame
-Image-Editing Software(Photoshop, GIMP )
This is known as the Droste effect after a Dutch CoCoa brand that had this effect on the label. Actually you can get a free plugin for Gimp called MathMap that has code for doing Droste that allows you to do this effect very easily with great control. (There is a free one for Photo Shop CS4 too). The plugins also allow you to do spiral forms like Escher used. You can find lots on this if you search for "Gimp Droste" for example: http://www.flickr.com/photos/joshsommers/378056770/
Thanks! I'm having it printed, hopefully tomorrow, then I'll put it in that actual frame and hang it there. I'll post a picture of the setup when it's completed.
OK, I printed and hung the actual picture in place tonight; here are the kids admiring their modeling/acting skills before going to bed. No, really, this is not just another virtual level!
There is! Take this example of Stephen Colbert. Now, he had this painted for himself, but you could emulate it by scanning a portrait with a picture frame somewhere on the canvas. Just replace whatever's in the frame.
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
This was quite a fun project!
Thanks,
CJ
