Pi Slideshow Display
Published
Introduction: Pi Slideshow Display
This Instructable shows how to create a slideshow that will stream photos from a connected USB or file directory on the Pi
Step 1: Setting Up the USB
Before installing the program on the Pi that would run the slideshow, create a file on the USB for the photos to be stored in.
If you do not want to use a USB, you can create a directory on your Pi to store the photos you want displayed.
The file directory should be noted of. It will be needed later when creating the program.
Step 2: Installing the Program
The program that will be used to run the slide show is called FEH. To install it, type "apt-get install feh" into the terminal and run it as an administrator using "sudo" as shown in the picture above.
Step 3: Creating the Program File
On the Pi, create a program using nano as the editor. Put the file in an easy to find location such as the pi/home/ directory. Make sure to put ".py" at the end of your file name.
Step 4: The Code
Next go into the program file and insert the following code shown on the picture above.
Replace "/media/" with the directory to the USB in where your photos are located.
If you are not using a USB you can use a directory on your Pi that contains photos you would like to display.
feh -Y -x -q -D 5 -B black -F -Z -z -r /media/
feh at the beginning of the line calls the command to run the slideshow
The letters with a "-" in front are settings for the slide show. The list of these commands are displayed below:
  • Z Auto Zoom
  • -x Borderless
  • -F Fullscreen
  • -Y hide pointer
  • -B image background
  • -q quiet no error reporting
  • -z Randomise
  • -r Recursive search all folders in folders
  • -D Slide delay in seconds
Step 5: Make the File Executable
To make the file executable, go into the terminal and type the following code using "sudo". This is also shown in the picture above.
sudo chmod +x slideShow.py
Step 6: Running the File
To easily run the file, create a shortcut to the program on your desktop.
Double click the file and select "Execute" when the pop up appears.
Step 7: Running
The slideshow should now be running. To close the slide show, press ESC on your keyboard to return to the desktop.
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Microcontroller Contest
    2 Comments
    Great project!! Thank You.
    I was thinking that a Pi might be a good way to make a diy digital picture frame.
