Add an Image to Your PCB
2,454
49
6
Posted
Introduction: Add an Image to Your PCB
This tutorial will guide you to place an image/logo on your PCB .
The tutorial is tailored work with the manufacturer I use to have my boards made OSH Park which is a great organization that offers low cost PCB batches of 3 boards based in the USA.
Step 1: Find an Image You Like
Working with image that is vector style or silhouette style-like will help ensure your image gets converted from it's original (jpg,jpeg ) form into a BMP file
Step 2: Resize Your Image to Fit the PCB
Most images will be too large to fit into the board which is why it is recommended to use an image resizing editor which will take a couple( or a load of) tweaking to fit the desired space on your PCB.
  • Just upload your file to your favorite image resizer and adjust as fit
  • Then download the file to your computer
Here is the image resize Editor I use
Step 3: Convert the File to a BMP Format
Next convert the file from it's (jpg, jpge etc) file into a BMP file
  • Upload the resized image to the editor
  • Under color select Monochrome
The image will be turn into a crisp black and white
Here is the link to the JPG to BMP online converter
Step 4: Import the BMP File Into Eagle
There is an existing script that allows a BMP file to be transferred into EAGLE
Open up your board file in Eagle then select:
  • File--> RUN ULP
  • import-bmp.ulp
Find your BMP image file
Select the color white (which is the default color used by OSH Park)
IMPORTANT
Make sure to have the settings !
Format Select: DPI (dots per inch )
Dots Per Inch: 300 the number OSH Park recommends
Layer : 21 Is the layer of the board where you want the image to be I choose layer 21 (layer for the top name of my board)
*Note you can change the layer to whatever layer you want !
Select the Run Script Button
Step 5: Successfully Imported File
If your file imported you should now see your image in Eagle CAD
I uploaded a couple times since I did not get the size correct a couple (or a lot ) of times
Step 6: Locate the Image to the Desired Area
Moving an image could be tricky at first but follow these steps:
  • Select the Group icon
  • Highlight the image so it turns from grey to black
  • Select the Move Icon
  • Hold down the control+right click
  • Select Move group
You should be able to move the image fully
If you move eagle line separately the image starts to become distorted
Step 7: Finished!
If your image is a bit bigger than the dimensions of your PCB don't worry OSH park automatically only prints whatever is with in the bounds of your board
Go to OSH Park and upload your .brd file and you will be shown what your PCB looks like
as well as receive a quote for 3 of the PCBs
link to OSH PARK
Enjoy!
I would love to see what you make tweet me @NemesisContrer8
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Gluten Free Challenge
6 Comments
Very good. just wanting to point out that if you have a photo editor (gimp, photoshop) that can do the resizing and converting as well. Nevertheless, I like online tools: no need to use space on my computer
Thanks for pointing that out!
I've tried to use GIMP but was turned off by the GUI just seemed too messy
i totally agree on GIMP
Sweet. I've been looking around for how to do this. Thanks a lot.
