Pi and Arduino Setup and First Run
Published
Introduction: Pi and Arduino Setup and First Run
for you!!!
Step 1: Insert the Sd Card
Step 2: Erase the Sd Card
open disk utility
call it boot
change drop down to ms-dos (fat)
Step 3: Download and Install PiBakery
Step 4: Get the PiBakery Setup File From Google Drive 1.xml
it called 1.xml
Step 5: Import 1.xml in to PiBakery
change the Network to your network
change the pass to the Network password
leave the Key the same, that is the password that I will use when I say PI_PASS
Step 6: Write the Card
write to BOOT SD card
with the Raspbian Full Operating System
Step 7: Wait Until It Has Written Successful
Step 8: Put Sd Card in Pi
connect hdmi
connect mouse
connect keyboard
connect power
Step 9: Wait Until It Boots to the Gui
can take I while, Keep the faith!!!
Step 10: Find the Ip Address of the Pi
open a LXTerminal window
sudo ifconfig
in my case the ip address is 192.168.2.50
if it is 127.0.0.1 then check that it is connected to your wifi
Step 11: Setup Ssh to the Pi From Your Mac
go back to your mac
open a terminal window
ssh to the pi with this .. ssh pi@pi ip address
in my case it is
ssh  pi@192.168.2.50
enter < yes > for the key fingerprint
enter the PI_PASS password
you should now be login in as pi@highChair:~ $
Step 12: Add a Folder for Openframeworks
make a folder
mkdir openframeworks
cd into it
cd openframeworks
should be /home/pi/openframeworks
Step 13: Great
Step 14: Go to Goole Drive Download OpenFrameworks_high_chair.dmg on the Mac
download openFrameworks_high_chair.dmg
Step 15: Open the Dmg (mount It)
it has all of openframeworks and the code for the app in it
it is imported that the dmg is mounted for future steps
Step 16: Copy Dmg to the Pi
copy the content of the dmg to the openframeworks folder on the pi
open a terminal window on the mac
scp -r /Volumes/openFrameworks/ pi@pi ip address :/home/pi/openframeworks
in my case
scp -r /Volumes/openFrameworks/ pi@192.168.2.50:/home/pi/openframeworks
enter the PI_PASS when prompted
wait a long time.......... .. . ... ... ..
Step 17:
Step 18: Install the Dependencies on Pi _ssh_
cd /home/pi/openframeworks/openFrameworks/scripts/linux/debian
sudo ./install_dependencies.sh
say Y wen asked
then wait about an hour
then say Y again
wait about 2 mins then done
Step 19: Plug the Usb From the Arduino in to the Pie
Step 20: Run the App!!!
cd /home/pi/openframeworks/openFrameworks/examples/empty/emptyExample
make run
Step 21: Push the Buttons on the Keyboard
so on the pi keyboard keys are
q = play
a = pause
z = stop
w = rewind
s = SelTrack // hafe working, need a path, we need to chat about how you want it to work
x = status
e = getAllPaths
on the ardunio these are the commands that you need to trigger to do something are....
play
sendToPi("P");
pause
sendToPi("p");
stop
sendToPi("s");
rewind
sendToPi("r");
selTrack // this path is not valid
sendToPiChangeTrack("t","sounds/test10.mp3”);
status
sendToPi("S");
getAllPaths
sendToPi("W");
Step 22: Get the Latest Version From Bitbucket
go to the folder
git fetch && git checkout master
git pull
the password is PI_PASS from before
then make the app this will take time as it need to compile openframeworks
make
then
make run
Step 23: The Webapp Is Up Too
webApp
the credentials are in the google drive in the heroku doc
Termail
$ heroku login
See the logos
heroku logs --tail
Update the web app with git
git add .
git commit -m "whatever"
git push heroku master
Step 24: The Location of the Web App
    • Oil Contest
      Oil Contest
    • Planter Challenge
      Planter Challenge
    • Casting Contest
      Casting Contest
    Thanks for sharing :)
