PiKon Telescope
61,375
498
29
Posted in Technology3D-Printing
Introduction: PiKon Telescope
About: Mark is the creator of the PiKon telescope. A 3D printed, Raspberry Pi powered astro-cam. He's also a Fellow of the Institute of Physics and Royal Astronomical Society.
The PiKon Telescope is a 3D printed, Raspberry Pi powered astro-cam. The design replaces the conventional eye-piece of a Newtonian reflecting telescope with a Raspberry Pi camera (lens removed). The telescope mirror is then used to focus an image on the Raspberry Pi camera sensor giving a field of view of about 1/4 degree. (The moon subtends 1/2 degree at the eye).
The PiKon was originally designed for Sheffield University's 'Festival of the Mind' to demonstrate what the 'citizen scientist' could do at home with new, disruptive, low cost technologies like 3D printing and Raspberry Pi computers. Since then, because of its popularity, the PiKon has been crowd funded, and also made available as open hardware.
Links:
PiKon blog - All the details about the PiKon
PiKon shop - Where you can buy some of the parts you'll need
Full PiKon instructions
PiKon .STL 3D Printer files (open hardware)
PiKon Instagram account See PiKon builds and results from users around the World
Step 1: Download and Print 3D Parts
As well as being available here, you can also download .STL 3D printing files from DropBox.
Pre-printed 3D parts are available from PiKon.online
Step 2: Making the Mirror Assembly
Do not attach the Mirror to the Mirror Mount with the double-sided tape pad until the Mirror Assembly has been assembled.
The Mirror Mount
and the Mirror Base are first connected together by placing three 8mm nuts through the Mirror Base. The three springs are then threaded onto the shaft of the bolts before the Mirror Mount is placed on the bolts and fastened by three 8mm nuts that are captured by hexagonal holes in the Mirror Mount. The Mirror Mount should be placed so that the hexagonal holes are facing away from the Mirror Base with the nuts visible after assembly.
Step 3: Mount the Mirror
The double-sided tape pad may then be stuck to the surface of the Mirror Mount and trimmed to size with a sharp knife.
Finally the Mirror is attached to the other side of the double-sided tape, taking care to get it central and aligned with the circumference of the Mirror Mount. The Mirror alignment may then be adjusted by rotating the 3 bolts. Ensure that the gap between the Mirror Base and the Mirror Mount is the same near all three bolts. This can be done by using a drill bit as a guage.
Step 4: Assembling the Spider (Camera)
The Spider Assembly provides support for the Pi camera on the axis of the telescope and a method of moving the camera backwards and forwards along the telescope axis to allow focusing.
The Pi Camera is mounted on the camera mount which already has a rubber gear rack attached. The first step is to prepare the Pi camera by removing the camera lens to expose the sensor. The lens unscrews from the camera body, but is set in place by a “Loctite” type sealant. Some force may be needed to initially break the seal to unscrew the lens. It is advised that the camera body be held as shown during this step. After separation the lens may be discarded.
It is also possible for the ribbon cable which connects the camera to the camera printed circuit board (PCB) to become disconnected during lens removal and it is worth checking that the ribbon cable is plugged into the PCB.The ribbon cable, which connects the Pi Camera to the Raspberry Pi computer, is then inserted into the Pi Camera.
The Pi Camera is then attached to the Camera Mount by 4 x 2mm nuts and bolts. (Note: bolts supplied may be shorter than those shown in the photograph).
Step 5: Spider Focus Device
The focus mechanism is assembled next. This consists of a cog connected to a screw threaded shaft and a Focus Knob attached to the threaded shaft by two locking square nuts and a lock nut. The cog is placed in the centre of the Spider as shown. The Threaded Shaft is then fed through a hole in the Spider circumference into the centre of the cog and locked in place with a hex grub screw. The Camera Mount assembly is then fed through the gap between the cog and the spider plastic. This may be stiff at first, but will ease by after a few passes. It is important that there is a tight fit for smooth focusing.The focus knob is attached by placing the square recess in the knob over two locking square nuts and holding it in place with a lock nut. Position the first nut on the treaded shaft and turn, checking with the depth of the Focus Knob so that there is enough length of shaft above the first nut to place the Focus Knob and lock nut. Then attach the second square nut and lock the two nuts together. Place the Focus Knob over the Threaded Shaft and engage the square recess in the Focus Knob. Finally, secure the Focus Knob in place with the lock nut.
Step 6: The Raspberry Pi Case Mount
The Raspberry Pi case will be attached to the Spider by the Raspberry Pi mount and a single self-tapping screw. A hole should be drilled through the Raspberry Pi mount (4mm) to clear the self-tapping screw. On kits with printed parts supplied there is a mark (solder iron dab) at the correct position. For those printing their own plastic, template dimensions are below. A 2.5 mm is made in the Spider circumference the 3.5mm self-tapping screw will tap. The hole is made over one of the legs of the spider so that the self-tapping screw does not protrude. The Raspberry Pi case is transparent and in two parts. The camera ribbon cable is threaded through the lid before being inserted into the CSI Camera connector on the Raspberry Pi board. The two parts then clip together and finally insert into the Raspberry Pi Mount.
Step 7: General Assembly and Tripod Mount
Before assembling the telescope, you may wish to improve its performance by painting the inside of the Tube with matt black paint.
The tripod mount is located at the centre of gravity of the tube. This is determined by pressing the Spider and Mirror assemblies into position on the tube. It is recommended that they be held in place with Gafa (Duct) tape while doing the next stage.
Then balance the telescope on an object or your hand to determine the centre of gravity. Mark this on the tube and then use the Tripod Mount to mark the position of two drill holes needed to fix the tripod mount.
Remove the Mirror and Spider assemblies before drilling out the two holes with sufficient clearance for the two nuts provided. Then attach the Tripod Mount with the two nuts and bolts.
You may now replace the Mirror and Spider assemblies.
Do not fix the spider permanently to the tube until after your first trial of the PiKon so that the exact orientation of the camera can be established.
The spider and Mirror Base are permanently held in place with the 3.5mm self-tapping screws provided. A 2.5mm drill is provided to drill trough the tube into the side of the Spider and Mirror Base. It is recommended that initially the spider should be secures by Gaffa tape and the orientation of the camera set on the first trial before drilling the tube.
Step 8: Setting Up the Raspberry Pi
The Raspberry Pi will require a power supply, USB keyboard, HDMI display and Mouse for graphic user interface (GUI). A VGA monitor may be used with a HDMI to VGA adaptor.
The Raspberry Pi is supplied with a pre-programmed micro-SD card. On power up the on screen instructions will take the user through the stages needed to set up the Raspberry Pi.
It is recommended that the Raspian operating system be installed. The PiKon image capture is performed using command lines, so it is more convenient to select boot up to command line during set up, than boot up to GUI.
Command Line Syntax
A full set of Raspberry Pi Camera commands can be found here:
https://www.raspberrypi.org/documentation/raspbian/applications/camera.md
For image capture use:
Raspistill –o test.jpeg –t 30000 –hf
“Raspistill –o test.jpeg” …. Takes an image in jpeg file format called “test” with a short default on screen preview.
–t 30000 …. Sets the on screen preview time before the image is taken. Units are in milliseconds, therefore this command would use a 30 second preview.
-hf …… flips the image horizontally. The image at the camera sensor is a mirror image.
Step 9: Setting Up the Telescope for Observations
Because the PiKon does not have an eye piece, setting up the telescope is done on screen.
Initially, use a “Raspistill –o test.jpeg” command, just to make sure everything is working and that the camera is correctly attached.
Next, focus the telescope on a distant object. Extending the time (-t) command can give useful extended preview time:
Raspistill –o test.jpeg –t 120000 –hf
Once focus point is established, remove the Gaffa tape from the Spider and rotate the Spider in the Telescope Tube until the image is upright. If satisfied, the Spider can then be fixed with the self-tapping screws.
And now you are ready for the night sky. It is suggested that your first object should be the moon. This will help familiarize you with the operation of the PiKon.
Your images can be viewed on the Raspberry Pi. I have found that the most convenient way to transfer images to an external computer is to use Dropbox from the Raspberry Pi.
  • Make it Move Contest
  • Microcontroller Contest
  • Woodworking Contest
    Woodworking Contest
29 Comments
In the old days... we used hypersensitized film and Schmitt Cameras to take the best deep sky astrophotographs. The telescope's design was very similar to this idea, a Newtonian without a diagonal (albeit with a corrector). Although your images may look crude they do show an interesting approach to the instruments we use today. Maybe a commercial variant that uses a high quality CCD in this configuration should be introduced. Is there really any need for that secondary mirror today? Hmmm... I really like this.
"Maybe a commercial variant that uses a high quality CCD in this configuration should be introduced."
Celestron already makes a telescope that is solely for astrophotography, the Rowe-Ackermann Schmidt 11" f/2.2 astrograph, the camera mounts to a fitting on the corrector plate, the scope can't be used for visual observations.
Thanks for your encouraging comment. You seem to have a history in astronomy that goes back as far as my interests in photography. The idea behind the project was to show what could be done on the cheap with new technologies like the Pi and 3D printing. I now work with a 3D printing company who also make 3D printers and do laser cutting. We've been taking about PiKon 2 exactly on the lines you suggest.
Has anyone tried a pi zero w for this. Is there any reason I cant think of not to.
Hi,
It is something we are looking at, so please have a go. In computer terms, the Pi is on very light duty and taking a photo with the Pi camera is something the Zero could easily do.
From our point of view, Pi Zeros are hard to come by in quantity so we'd think hard before supplying them. But the cost of the standard Pi is slowly going up, making the project more expensive. If you do try, please let us know how you get on.
Best wishes - Mark
I'll give it a go and see what I can do
This link gave me some ideas for mounting the pi
https://core-electronics.com.au/raspberry-pi-zero-w-camera-kit.html
Would a regular camera tripod work? Choice of mount hasn't been discussed in detail in The Instructable.
Is there any reason a section of PVC pipe wouldn't work for the tube?
We're planning on using PVC Pipe too. Will we run into any issues?
Can you use the
Raspberry Pi Noir Camera Board V2 or do you have to used the plain camera?
Where is the stl for the raspberry pi cover. It is clear in the pictures but I'm not bothered if it isnt clear.
http://pikon.online/spare-parts/23-full-printed-kit-with-pi.html
The Pi is in a commercially available case and clipped to the spider. If you need one, please let me know. Pretty much any case can be mounted on the spider.
Then what is the part for the pi case in the stl. Isnt it the bottom of the case? I just printed it expecting the top to also be available. I have printed other cases for my pi's in the past so do I just use them instead of the stl provided.
Oh wait, it holds the clear case so depending on my case I should redesign the holder to suit. Deerrrrr. Sorry I get it now, I got fixated that it was the case.
Beautifully done! I've wanted to do this myself on SCTs.
Now with the Pi Zero having wifi and a small cross section, you might be able to move the PI behind the camera. Run power down two of the spider legs. Would also be neat if the pi could auto-focus by moving the focus mechanism and motor into the spider stack as well.
Well, these ideas might be better for a larger aperture scope that would require a 2 inch diagonal or so to give you some working room for the mechanics!
Keep up the good work!
I like that idea!
Is the focus in the picture above of the moon as good as it gets?
Stringstrecher mention using a higher quality CCD. Does that mean the PI camera isn't good enough?
Get project. Thanks
Cheers.
I think we could do a bit better. I just tried lining the tube with a black velvet sticky back plastic. That improved the contrast a lot.
Nice! I'm wondering if I can modify my Meade to do this? it looks to be about the same size. it's just the spider is in a different locations for the focal point.
I'm not sure. The main difference is that the Pi camera would have to be a little bit further away from the mirror.
