Introduction: PiMSO - a Raspberry Pi Based Wi-Fi Oscilloscope
PiMSO, is a Raspberry Pi controlled 200 Msa/S mixed signal oscilloscope. Depending on your application, it can be configure to use the Midori browser on the Pi GUI or access remotely via the internet. Since the PiMSO GUI is web based, You can also control it from a browser on your tablet or smart phone. But what happens when you are at a location that there are no convenient access to a network? For this project I'll demonstrate how to build a Raspberry Pi based oscilloscope that is also a Wireless Access Point.
As a bare minimum you'll need the Raspberry Pi and a Ralink RT5370 based Wi-Fi dongle. For this project I used the Tenda W311M from MicroCenter, primarily because it is Access Point capable and inexpensive. An even less expensive dongle that based on the same Ralink RT5370 chip from Comfast can be purchased from Aliexpress for less than $5 inc S/H. A quick search on Aliexpress for RT5370 should yield a few other options. If you don't have a MSO-28 you can still try it out, the WebMSO28 GUI will run regardless if you have the MSO-28. It'll just show "NO DSO".
If you don't want to roll your own, you can grab a pre-configured Raspian distro from here and skip to Step 6. Otherwise here is how to roll your own on top of your favorite distro.
Update: An Intel Edison based oscilloscope is available here https://www.instructables.com/id/Edison-Scope/
Step 1: Setting Up the Raspberry Pi
2. Boot up the Raspbian and set the it to boot into command line.
Step 2: Package Installation
2. Update the package list.
3. Install the necessary packages.
4. Go to the home directory.
5. wiringPi is not necessary if you don't have PiLCD, but it is nice to have for future I/O control.
cd wiringPi
./build
6. Grab and install the WebMSO-config.git so the Pi will recognize MSO-28 and MSO-19
git clone git://github.com/tkrmnz/WebMSO-config.git
cd WebMSO-config
cp /home/pi/WebMSO-config/74-linkmso.rules /etc/udev/rules.d/.
7. At this point plug the MSO-28 into the Raspberry Pi, you should see it listed under /dev as MSO-28-0.
Step 3: Setting Up the Web Server
Change the nginx default root directory to /var/www
2. Also add the following block for fcgi port forwarding.
include fastcgi_params;
fastcgi_pass 127.0.0.1:9000;
3. Copy the proxy.conf to /etc/nginx
The content of the proxy.conf is shown below.
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
client_max_body_size 10m;
client_body_buffer_size 128k;
proxy_connect_timeout 90;
proxy_send_timeout 90;
proxy_read_timeout 90;
4. Check to see if the gzip is enabled in the /etc/nginx/nginx.conf
un-comment gzip on;
gzip_disable "msie6";
5. Create the webpage folder
6. Grab and install the WebMSO28fcgi javascripts content
git clone git://github.com/tkrmnz/WebMSO28fcgi.git
cd WebMSO28fcgi
cp -rf * /var/www/.
7. Start the nginx web server.
At this point nginx should start serving the web page. ifconfig to get your ipv4 address and access it via a browser from a different computer on the same network.
Step 4: Setting Up the FCGI Server
2. Create a temporary ram drive for the mso28 fcgi driver to store the captured data.
mount -t tmpfs -o size=20m tmpfs /mnt/tmp
ln -s /mnt/tmp /var/www/fcgi-bin/tmp
3. Grab and install the spawn-fcgi and mso28ctl.fcgi
git clone git://github.com/tkrmnz/mso28fcgi.git
copy spawn-fcgi-1.6.3.tar.bz2 to /home/pi and unzip the spawn-fcgi
cp mso28fcgi/spawn-fcgi-1.6.3.tar.bz2 .
tar -xvjf spawn-fcgi-1.6.3.tar.bz2
Install the spawn-fcgi
./configure
make
make install
cp src/spawn-fcgi /usr/bin/.
Copy the init script from /home/pi/mso28fcgi to /etc/init.d
chmod +x /etc/init.d/spawn-fcgi1
4. Compile and copy the mso28ctl to /www/var/fcgi-bin
touch main.c
sh makemso2.sh
sh msocpy6.sh
5. You can test the installing by starting the spawn-fcgi using
You should be able to see the blinking indicator next to the '''Stby''' above the timing window of the WebMSO28 client page.
If you see No MSO, then your spwan-fcgi is not running.
To stop the spawn-fcgi '''ctrl-z''' and kill the process
6. To auto start spawn-fcgi on boot.
To remove spawn-fcgi from auto boot.
At this point server works with ethernet cable.
Step 5: PiMSO Access Point Setup
2. Copy the various conf files to their directories.
cp dnsmasq.conf /etc/.
cp hostpad.conf /etc/hostapd/.
cp hosts /etc/.
cp interfaces /etc/network/.
Add DAEMON_CONF=”/etc/hostapd/hostapd.conf” to /etc/default/hostapd
Look for DAEMON_CONF="", insert the following
Enable the hostapd and restart dnsmasq
/etc/init.d/dnsmasq restart
Step 6: Connecting to PiMSO
you should be able to see the WebMSO28 web client.
If you have a PiLCD, go to Step 7, otherwise you are done.
Step 7: PiLCD Setup
One application is for a headless Raspberry Pi with a Wifi dongle to scan, select and connect to nearby Wifi Access Points.
The PiMSO project demonstrates how the PiLCD module can be used to provide a convenient way for the user see the Access Point and URL info of the PiMSO, it will also display current IPV4 address of the Ethernet connection.
1. In addition to wiringPi, you will also need nslookup, which is available in the dnsuitls package.
2. Grab and install the PiLCD project from Github
git clone git://github.com/tkrmnz/PiLCD.git
cd /home/pi/PiLCD
3. Copy the LCDinit scrip to init.d
cd /home/pi/wiringPi/examples
make /home/pi/PiLCD/lcd_ip2.c
chmod +x /etc/init.d/LCDinit.sh
4. you can test PiLCD by typing
You should be able to see the Wifi AP and URL information and Ethernet IPV4 by spinning the knob.
The LCDinit will execute the lcd_ip2 driver from PiLCD directory.
To run the LCDinit.sh on boot, do the following
To remove it from boot
