PiPlay a Raspberry Pi Aiplay Server
5,536
49
4
Posted
Introduction: PiPlay a Raspberry Pi Aiplay Server
Hello,
In this instruct able, I will be showing you how to make a raspberry pi airplay server.To start off, you will need to get a raspberry pi. The model A, B or B+ will work.To allow the raspberry pi to run, you will need to format an SD card. First of all go to www.raspberrypi.org and download the 'Openelec' image as the zip file. If you are using mac, you will need to download some free formatting software called apple pi baker . Link: http://www.tweaking4all.com/hardware/raspberry-pi/macosx-apple-pi-baker/ You will want to download the latest or recommended version. When you open the program it will ask you for an admin password, for this just type on the password that you use to log on to your computer. Once you have done this, it should look something like the first picture. Plug in your SD card and select it like shown. You will probably want to click the 'prepare for NOOBS' button to delete any data on the SD card. WARNING! MAKE SURE YOU HAVE SAVED ANY DATA ON THE SD CARD AS YOU WILL NOT BEA ABLE TO GET IT BACK AFTER THIS STEP! After this, click the 3 dots near the restore backup button. You now have to navigate to your downloads folder and find the image you just downloaded. Click on it then click open. To write it to the SD card, click restore backup. This will take about 5 minutes so just leave it to do it's business. Once a message comes up indicating success, eject the SD card. If not, try again.
Step 1: Setting Up the Pi
Now you have installed an operating system, plug the SD card into the raspberry pi and connect an ethernet cable, HDMI (or composite) (just for now), and power. Turn on the pi and monitor and proceed through the setup guide. Once that has finished. go to System, Settings, Services then airplay and make sure the circle is blue next to 'Allow Kodi to receive airplay content'. Once you have done this, watch the quick video to learn how to connect your apple product to the server
Step 2: Prepare the Enclosure
Once the raspberry pi has been set up, you will need to prepare an enclosure. I have gone for a black ABS enclosure which I bought from rapid. (Link: http://www.rapidonline.com/design-technology/abs-c... ). To drill the holes, I started with a smaller bit then swapped it out for a larger sized bit. I repeated this for the audio jack, the ethernet, the power and optimal HDMI. As you can see, the finished product looks very satisfying.
Step 3: Testing!
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
4 Comments
Hello JeremyG1,
Great instructable, I really want to make it...
Thanks.
Huu? In the title is "aiplay" or "aiRplay" ?
Great first Instructable. Thanks so much for sharing! I hope we see more projects from you in the future!
I'l try and post many more!
thanks for the positive feedback
