PicAxe Serial Download Cable (homemade From Scrap)
Published
Introduction: PicAxe Serial Download Cable (homemade From Scrap)
I decide to make my PicAxe Serial Download  (Programming) Cable as i had all the needed parts.
It is very cheap to buy that cable but if you already have the scrap parts needed..
Step 1: Parts & Tools Needed...
Parts:
1 x Female Din9 serial connector (DB9)
1 x Audio stereo jack (I take out one of my old pc front panel..)
1 x Audio stereo cable Male to Male
Tools:
Soldering Iron
Solder Wire
Hot Glue Gun (optional. I use instant Glue)
Step 2: Prepare Components
Open the DB9 and solder small wires to pin2, pin3 & pin5 just like in the photo..
Identify the pins of the jack with a multimeter..
Step 3: Time to Solder Them Toggether & Measure It..
Soldering:
1 photo 1.000.000 words..
 Measurement:
Use Continue Tester to check for bad soldering or short out..
Remember: Shaft = Orange(Rxd), Ring = Red(Txd), Tip = Brown(GND)
Step 4: Glue It!!
Step 5: Finished Cable..
Finished Cable ready to program PicAxe Microcontrollers...
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Clocks Contest
      Clocks Contest
    7 Comments
    Hi.Can you help me.please. what i must to do for connection between Picaxe and usb without DB9?
    yes,.... i did tis cable but what abt the drivers to be installed...... tis cable is not detected in my PC... :(
    Would this work with a usb-serial converter?
    although it is an easy to build project i haven't find any guide here and i couldn't wait 3 days untill the shop bring it so i build one..
    i build it that way so i can easilly change the audio cable with a bigger one if i need..
    A neat little unit.  Of course, make sure you have a serial port available on your PC before building - A lot of laptops don't nowadays.
    (If not, you could always use a USB to serial converter.)
    thats not too far off wat i did XD
    tho i havent attached a connector to the pic end of the wires yet :P been breadboarding it..
