This recipe will make enough brine for 6 eggs. Simply double the amount of all the ingredients for a dozen eggs, quadruple for 2 dozen, etc.
As a general rule, 10 eggs fit into a quart mason jar*. Usually, it is desirable to get your jar as close to full as possible, so it may be necessary to vary batch size or jar size to keep the jars full.
*Even though mason jars happen to be the most common container for making pickled eggs, any properly sized empty container will work fine since the jars are not actually sealed. Old pickle jars work very well, as do most other glass containers.
Remove these ads by
Signing UpStep 1Gather Ingredients
Here is what you will need (again for a batch of 6 eggs):
Equipment:
- Large Pot
- Strainer
- Pitcher
- Measuring Utensils
- Knife
- Cutting Board
Ingredients:
- 2 Cups Vinegar (White Distilled)
- 2 TBSP Sugar
- 1 TBSP Pickling Spice
- 1 TBSP Canning or Pickling Salt
- 8 tsp Dry Minced Garlic*
- 1/2 Large Onion (Optional-But Great)
*You may substitute wet minced garlic for the dry by adding 1/2 as much wet minced garlic as the recipe calls for. Wet minced garlic is very potent stuff. Do not add too much, or the eggs will be inedible.
Arny
I found several, I'll try one.
One thing I have found is that when fresh eggs are hard boiled, they are hard to peel and the shells won't separate from the whites very well. If the eggs are older (close to the expiration date on the eggs), once they are hard boiled and cooled, the shells slip off of the whites very easily, in big pieces. Whenever I make deviled eggs, I buy my eggs plenty ahead of time and just let 'em wait for me in the fridge.
Thank you for posting this recipe!
Jim
Growing up in South/Eastern Pennsylvania Dutch region it was common to add beets to give the egg an red- violet color and sliced beautifully in a tossed salad.Look up pickle beet eggs. I grew up on them.
Though you mentioned it in Step 1, it's worth expanding:
In addition to chopping, adding whole cloves of garlic gives you extra goodies in the gaps between eggs.
Since you just made these, mind updating in a few week when they're 'ripe'? I'm interested in your results. Good luck
