3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pickup Truck Ballast Rack
  • last photo ←
My wife's GMC Sonoma (codenamed "Rustbucket"), like most rear-wheel drive pickups, gets better traction during the winter when counterweights are in the cargo bed.
In past years I lashed plastic cat litter containers filled with sand in place, but these would slide, and sometimes break open. This year I still used the cat litter containers, but built a wooden base to keep the containers stationary. It worked so well, I thought it was worthy of becoming my first Instructable.
Step 1Get Stuff
Get Stuff
Parts:
2x4s (at least 20 feet worth)
suitable nails
three plastic cat litter containers with tight-fitting lids
enough small rocks (1" to 1-1/2") to fill the containers
polyethylene rope
Tools:
Saw
drill
drill bits
hammer
Surform or other sander
10 comments
Feb 27, 2012. 6:44 AMabstracted says:
the weight should be dirrectly over the axels, and use weight that has another use come spring...like soils, cat litter if u have cats, i have used sand blasting sand to be used later in my blaster
May 21, 2011. 11:13 PMlonemeno says:
not to be a drag but i fill my bed with snow and 4 sand bags and they dont move the plus side of it i can make blocks for a snow wall or igloo
May 9, 2011. 11:58 PMdirtrdforester says:
I built one of these for my last Dodge. While I don't have the snow problem in the South, the rear end did "creep" on washboard roads. I use hydraulic oil buckets. They are readily available if you are in a mechanized logging area. I fill the buckets with gravel from creek crossings. As an added benefit, I fill holes in the driveway with the gravel. Great instructable and kudo's for the re-purposing on the litter buckets. I also use litter buckets in the tool box for tow chains/straps. It keeps the rust off the other junk in there, as well as making it easy to get them out without risking beating up the side of the truck as you feed it over the bed or tailgate.
May 5, 2011. 4:43 PMRoflolommo says:
Very nice. It looks far superior to my bungie cord sandbag contraption.
May 4, 2011. 5:42 PMjustin.jackson says:
this would be perfect in my bedliner since it already has slots for 2x4 dividers
May 3, 2011. 8:46 PMcrash landing says:
don't worry about that fender, it will buff right out
Apr 27, 2011. 8:27 AMcriswilson10 says:
I've been dealing with the same sliding bucket problem in winter as well and I love this solution. Great idea!
Apr 25, 2011. 2:20 PMEsmagamus says:
Nice idea. Unlike many instructables, yours shows something truly useful. I just hate driving with loads running around the boot of my car.
Hope you're enjoying your membership. Share your ideas with the world.
P.S.: Stop that rust before it stops your truck.
Apr 25, 2011. 5:59 PMcatsnw says:
That rust isnt going to hurt the truck other than the quarter panel...
Apr 25, 2011. 3:21 PMCivicalized says:
I have the same type of bedliner in my Ram. I love it but hate it. Things slide around like its ice back there. This could easily be modified (simply not using the gravel) to keep things in place. I also have a bunch of those litter buckets sitting around, so I may just have to build something similar! Nice post!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:TheOlMaestro
